#34153 - 08/07/2001 15:31 jemplode still stalling
crewe
I am still having no luck at all connecting my empeg to jemplode. The software sees the player and starts connecting to it, but it stalls on 'retrieving playlist'. I have tried leaving it for hours (overnight) and nothing happens. It is not showing anything in the progress bar.
I am running player software 1.02. How do I install 1.03 using a Mac? I know I upgraded from 1.1 to 2 easily last time, but can't remember how (is it with jemplode?).
I know people have said find a PC to borrow and hook it up and things will clear up, but this is not an option. If it was, I wouldn't be trying to make this work with a Mac. To be honest, as cool as the empeg is, if I'd known the lack of Mac support from empeg/Rio was this bad and would be this long-lasting, I probably wouldn't have bothered. Oh, and my volume knob doesn't work any more - it just spins round. I took it off and just use the metal bit.
#34154 - 08/07/2001 16:40 Re: jemplode still stalling [Re: crewe]
mardibloke
Loc: Penarth, UK
Just email the support people, they will post you a new knob FOC.
Rod, UK Mk2 64gig Red S/No.341 2xDell RioReceiver
Rod, UK
#34155 - 08/07/2001 17:12 Re: jemplode still stalling [Re: crewe]
dmz
Loc: Pasadena, California, USA
Sadly, there are some database problems that JEmplode just can't repair. The only way to fix it is to run Emplode on a PC or on Virtual PC (if you're using Ethernet or serial, it should work fine with Virtual PC; if you're using USB, it seems pretty much random whether it works or not), or perhaps to run the Linux tools.
Upgrades must be done over a serial port; Virtual PC works fine for upgrading, in my experience - JEmplode doesn't, both because we never put that in the software and because it doesn't support serial connections on the Mac. If you did it with a Mac before, you must have been using Virtual PC.
Daniel M. Zimmerman, Caltech Computer Science
Mk.2 #060000058, 36GB
Mk.1 #00101, 10GB
Daniel M. Zimmerman Mk.2 #060000058, 36GB Mk.1 #00101, 10GB
#34156 - 09/07/2001 17:12 Re: jemplode still stalling [Re: crewe]
...if I'd known the lack of Mac support from empeg/Rio was this bad...
Y'know, the easiest way out of your dilemma might be to just buy and old PC, use it only for updating empeg software. I know that you have already spent several thousand dollars just on the stereo in your wonderful car, plus uncounted thousands more in the car's restoration. A quick check of ebay shows literally hundreds of suitable used PCs priced at $50 or less, a pittance compared to what you have already spent.
I think it might ease your frustrations considerably. :-)
