#316913 - 03/12/2008 17:23 Headlights
jcm
Folks,
My player intermittently will/won't adjust when I turn my headlights on. I know the wiring is correct because the other unit I have in the double DIN works correctly every time. I'm thinking it's hardware related. My current thinking is (when I have time - maybe this weekend) to find whatever /proc file is being read to get that state and add a hijack option to turn headlights on/off (just for the times when it doesn't figure it out for itself). Unless one of these already exists, and I'm missing it?
Jon.
#316921 - 03/12/2008 18:09 Re: Headlights [Re: jcm]
Are you sure your headlight line is actually an high/low signal? What is the other unit?
Also, are you sure it isn't the known problem with the dimmer for the empeg display?
#316925 - 03/12/2008 18:25 Re: Headlights [Re: jcm]
Also possible is the known issue with the AC adapter connection switch.
