#310515 - 27/05/2008 12:41
Re: more RAM+Harddisk errors
[Re: Roger]
Loc: Denmark, Odense
thanks roger
and it's ok to be drunk :-)
#310516 - 27/05/2008 12:49
[Re: Roger]
so i should do it for :
/dev/hda /dev/hdb /dev/hdc
#310517 - 27/05/2008 13:02
[Re: Boelle]
If you want to do both drives then hda + hdc. No hdb.
#310529 - 27/05/2008 20:13
[Re: tman]
why not hdb? i have seen hdb among the errors
#310533 - 27/05/2008 21:45
[Re: Boelle]
The Mk1 had two IDE channels so your two drives ended up as hda and hdc.
The Mk2/Mk2A had 1 IDE channel so your two drives ended up as hda and hdb. However to make it easier, the device nodes in /dev were changed around slightly so you could still refer to the 2nd drive as /dev/hdc.
#310536 - 27/05/2008 23:08
[Re: tman]
The Mk2/Mk2A had 1 IDE channel so your two drives ended up as hda and hdb. However to make it easier, the device nodes in /dev were changed around slightly so you could still refer to the 2nd drive as /dev/hdc. Yeah. Blame me (and Linus) for the skip naming, and blame Hugo for his twisted simplification (of empeg s/w) in taking advantage of it. ![wink wink](/images/graemlins/default_dark/wink.gif) The kernel refers to the second drive in a MkII/MkIIa as hdb, but the non-kernel software uses /dev/hdc for the same unit. This is a peculiar, yet normal, sort of thing for a POSIX style operating system to be able to do. EDIT: The purists would prefer that we should have used 3,0 and 3,16 in the kernel, instead of hda and hdb. But I argued against that, as being rather unfriendly for common uses and users. Cheers
Edited by mlord (28/05/2008 14:13)
#310544 - 28/05/2008 06:40
funny thing is that when i zero fill hda at some point it goes crazy and are writing stuff so fast that i cant read it.
if i reboot the player it hits me with a kernel panic
doing the disk build stuff and everything is normal again, but it is only stress testing hda....
#310545 - 28/05/2008 07:05
[Re: Boelle]
anyway cat /dev/zero > /dev/hdb can't be done, it tells me that /dev/hdb is read only
a little challange for mark: build a disk test thing in to hijack, with options to test and repair disk, and also stress all installed drives
maybe as a special version that only do that.. or maybe a "bug fix" hijack that can be used for fixing bugs and repairs ?
#310546 - 28/05/2008 07:46
[Re: Boelle]
anyway cat /dev/zero > /dev/hdb can't be done, it tells me that /dev/hdb is read only As I said above, don't do hdb. There is a finite number of spare blocks available on the drive to remap bad blocks. If your drive is really badly broken then you'll have to replace it.
#310547 - 28/05/2008 07:52
[Re: tman]
but there are errors on hdb... guess i can take them out of the player and zero fill them on my laptop
#310548 - 28/05/2008 08:20
[Re: Boelle]
but there are errors on hdb Errors on hdb get fixed when you "cat /dev/zero > /dev/hd c". If you open the player, count the drives carefully! there will be at most two, not three ![wink wink](/images/graemlins/default_dark/wink.gif) I think, Mark, your clarification itself contained a typo: didn't you mean: The kernel refers to the second drive in a MkII/MkIIa as hdb, but the non-kernel software uses /dev/hdc for the same unit. This is a peculiar, yet normal, sort of thing for a POSIX style operating system to be able to do. ..? Peter
#310549 - 28/05/2008 09:25
[Re: peter]
there are 2 drives, i installed the second one myself,
also i used some clear silicon glue on the ide connector on the drives, this becuase the silicon stays flexible and is easy to remove.. i used the clear type as it is the most weak of all types.. you can get greay, white and red types...
i prefered silicon to hot melt glue do to that vibrations could break of the hot melt glue as i cools down and get hard
#310550 - 28/05/2008 11:04
[Re: Boelle]
Hi,
Sometimes that type of silicone RTV will leech into the connector mating area and contaminte the gas-tight seal of the pin and socket.
Make sure this is not the problem too.
#310554 - 28/05/2008 11:56
[Re: Ross Wellington]
i'm sure it's not the problem, i only applied so little that it would only touch the surface of the connector on the drive and on the ide cable
#310560 - 28/05/2008 14:14
[Re: Boelle]
Silicone uses an acid solvent, which can corrode contacts.
#310561 - 28/05/2008 14:15
[Re: peter]
I think, Mark, your clarification itself contained a typo Yup. Typo now fixed by an EDIT in the original post. Thanks.
#310563 - 28/05/2008 15:54
The purists would prefer that we should have used 3,0 and 3,16 in the kernel, instead of hda and hdb. I'd have preferred Solaris-style c0t0 and c0t1 namings. It's so easy to figure out what's what under Solaris in a way that it is not under most other Unices, Linux included.
#310564 - 28/05/2008 16:33
Silicone uses an acid solvent, which can corrode contacts. so it's 100% safe as long óne does not put it on the contact pins
#310570 - 28/05/2008 18:25
[Re: Boelle]
Silicone uses an acid solvent, which can corrode contacts. so it's 100% safe as long óne does not put it on the contact pins Vapours.
#310589 - 29/05/2008 08:45
i did some heavy vent. wkile i dried up
anyway after some diskbuilds and zero fills it all comes down to this:
empeg:/empeg/bin# cat /dev/hda > /dev/null empeg:/empeg/bin# cat /dev/hdc > /dev/null hdb: read_intr: status=0x59 { DriveReady SeekComplete DataRequest Error } hdb: read_intr: error=0x40 { UncorrectableError }, LBAsect=115459753, sector=115459753 end_request: I/O error, dev 03:40 (hdb), sector 115459753 cat: /dev/hdc: Input/output error empeg:/empeg/bin#
i will be fixing the temp sensor later, so the unit will get a very close inspection while i have it open
as for the Silicone i have only used it on the drive end of the IDE cable... i could never dream of using the stuff on the mainboard.. there is no need to either as the connector is more a theight fit than on the drives
#310591 - 29/05/2008 09:05
[Re: Boelle]
just loaded ver. 3 alpha 11.. i feel like an idiot, i can't find the auto eq feature
do i have to plug in the mic to have the menu option displayed?
#310597 - 29/05/2008 11:46
[Re: Boelle]
The smartctl program is the only real way to know if the drive is the issue.
I've placed a binary copy (for the empeg) on the Hijack site (links at top of this page and that page.
#310598 - 29/05/2008 11:52
how do i use the tool? sorry for asking stupid
#310604 - 29/05/2008 12:54
[Re: Boelle]
how do i use the tool? sorry for asking stupid Use it the same as you would on any other Linux system. The man page is here, courtesy of Google. The normal sequence is to do something like this: ## Enable the S.M.A.R.T. monitoring in the drive firmware: smartctl -s on /dev/hdc## Check current drive status. "-a" means "all", or "everything": smartctl -a /dev/hdcThen scour the output looking for error reports. (and post the complete output here for us to help with)If you don't see any errors, then do the "cat /dev/zero > /dev/hdc" thing again (sorry), and this time the drive will record errors for later retrieval with smartctl -aCheers
Edited by mlord (29/05/2008 12:55)
#310606 - 29/05/2008 13:01
i'm a windows man so i don't know much about linux, can you make a very quick step by step?
#310627 - 29/05/2008 14:38
[Re: Boelle]
i'm a windows man so i don't know much about linux, can you make a very quick step by step? The FAQ has a step-by-step here, but I haven't sanity-checked it in a long time, so it might be outdated. Worth a try though.
#310629 - 29/05/2008 14:48
i will say it does work or not
#310640 - 29/05/2008 16:02
[Re: Boelle]
damn.. i cant connect to ftp... :-( newest hijack installed
#310644 - 29/05/2008 16:45
[Re: Boelle]
still no go at the http or ftp in hijack
i installed ver 2.01 kernel and newest hijack
#310646 - 29/05/2008 16:49
[Re: Boelle]
still no go at the http or ftp in hijack i installed ver 2.01 kernel and newest hijack Check the ethernet connections. Go to the "about" screen on the empeg front-panel, and see what IP address it is using. You know the drill by now.. post a serial log here along with the IP address info.
