#308579 - 26/03/2008 17:49 hdb: irq timeout while running fsck
jondle
Loc: San Diego, CA, USA
I was trying to upload some new music and I got irq timeout on the display. So I logged into the console to run a fsck. I ran it on /dev/hda4 and it came back clean. Then I ran it on /dev/hdc4 and I ran into the irq errors.
I'm using hijack 440 prebuilt by Mike Comb with ext3 support on my MKII.
Below is the capture of the boot and the fsck. Does this look like a bad hard drive or something worse? What is hdb? I haven't done Linux admin in about 3 years, but I seem to remember that hda1 where "a" is the drive enumeration and "1" is the partition enumeration. Why is the Toshiba drive set to hdb while booting, but the /drive1 comes from hdc?
Thanks in advance for any help you can provide.
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the kernel.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v440 (mcomb@grovepc) (gcc version 2.95.3 20010315 (release)) #5 Fri Sep 30 14:44:26 PDT 2005
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30103119) 16MB DRAM
Command line: mem=16m
Memory: 14952k/16M available (1044k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP, IGMP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: TOSHIBA MK4025GAS, ATA DISK drive
hda: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: TOSHIBA MK4025GAS, 38154MB w/0kB Cache, CHS=4864/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0c:2f
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
Tried to mount /dev/hda4 as reiserfs but got empeg-EXT3: changing mount type for:/dev/hda4
error 19
EXT3-fs: mounted filesystem with ordered data mode.
empeg-EXT3: changing mount type for:/dev/hdc4
Starting player
Timezone: PST8PDT
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x40894000
q
Restored terminal settings
Player exited normally: 0
Starting bash.
empeg:/empeg/bin# cat /etc/fstab
# /etc/fstab
# <device> <mountpoint> <filesystemtype> <options> <dump> <fsckorder>
/dev/hda5 / ext2 defaults,ro 1 1
/dev/hda4 /drive0 ext3 defaults,ro 1 1
/dev/hdc4 /drive1 ext3 defaults,ro 1 1
none /proc proc defaults
empeg:/empeg/bin# umount /dev/hdc4
empeg:/empeg/bin# e2fsck -c -f /dev/hdc4
e2fsck 1.29 (24-Sep-2002)
Checking for bad blocks (read-only test): 0/ 38965657
2512/ 38965657
38964128/ 38965657
done
Pass 1: Checking inodes, blocks, and sizes
Inode 65662 has illegal block(s). Clear<y>? yes
Illegal block #41 (429496no room for private writable mapping
7295) in error: -12
inode 65662. CLEARED.
error: -12
Error allocating block bitmap (3): Memory allocation failed
e2fsck: aborted
/dev/hdc4: ***** FILE SYSTEM WAS MODIFIED *****
/dev/hdc4: 5503/304448 files (24.4% non-contiguous), 14212196/38965657 blocks
VM: do_try_to_free_pages failed for e2fsck...
hdb: irq timeout: status=0xd0
ide0: reset: success
end_request: I/O error, dev 03:44 (hdb), sector 2
hdb: status timeout: status=0xd0
hdb: drive not ready for command
end_request: I/O error, dev 03:44 (hdb), sector 16386
end_request: I/O error, dev 03:44 (hdb), sector 49154
end_request: I/O error, dev 03:44 (hdb), sector 81922
end_request: I/O error, dev 03:44 (hdb), sector 114690
end_request: I/O error, dev 03:44 (hdb), sector 147458
end_request: I/O error, dev 03:44 (hdb), sector 409602
end_request: I/O error, dev 03:44 (hdb), sector 442370
end_request: I/O error, dev 03:44 (hdb), sector 802818
end_request: I/O error, dev 03:44 (hdb), sector 1327106
end_request: I/O error, dev 03:44 (hdb), sector 2048002
end_request: I/O error, dev 03:44 (hdb), sector 3981314
end_request: I/O error, dev 03:44 (hdb), sector 10240002
empeg:/empeg/bin#
Mark IIa -- #30103119 -- 70 gig w/ ext3 fs-- Eutronix Light Kit -- Greenlight buttons
#308587 - 26/03/2008 18:45 Re: hdb: irq timeout while running fsck [Re: jondle]
Because we cheated, to make things the same between Mark 1 (which has hda and hdc) and Mark 2 (which has hda and hdb). The second drive in a Mark 2 "is" hdb, but the device nodes /dev/hdc* are the ones which would normally refer to hdb.
You should enable swap ("swapon /swapfile") before running fsck, you'll get out-of-memory errors like that one otherwise. However, that's not your main problem; it couldn't cause those IRQ errors. Either the second drive is failing, or -- much more likely -- there's a problem with the IDE cable, perhaps where it's attached to the second drive. Dismantle the player and check all the connections are bedded-in properly.
#308588 - 26/03/2008 19:17 Re: hdb: irq timeout while running fsck [Re: peter]
jondle
Thanks for the quick response.
Ah....the little things you forget when you haven't logged into the console of your empeg in a couple years.
I've replaced the cable before, but it was mailed to me from support. Do you know where to get a pre-made one now, or do I have to find a laptop one and cut it down? Either way, I'll take it appart when I get home from work and just double check the seating.
Thanks again.
#308595 - 26/03/2008 20:28 Re: hdb: irq timeout while running fsck [Re: jondle]
AndrewT
Loc: Oxford, UK
Don't forget to check the IDE header connector on the mainboard for dry joints - link.
#308598 - 26/03/2008 22:15 Re: hdb: irq timeout while running fsck [Re: jondle]
oliver
Eutronix has replacement IDE cables.
#308639 - 27/03/2008 18:55 Re: hdb: irq timeout while running fsck [Re: oliver]
jondle
I took the unit apart. I checked for dry joints (thanks AndrewT) by using a multi-meter and testing connectivity from the tip of the solder to the top of the pin. All pins checked out.
I then used a small mallet and beat the connectors on the ide cable together to make sure the connectors were making good contact with the wire. Then I reseated everything, obviously since I had to pull the cable to beat on it.
After putting it back together, I ran the fsck again and it came back with a lot of bad blocks. The drive is probably going bad as well, but it looks like the reseating everything fixed the irq issue, at least for now. I haven't had time to add songs or do any write tests. The fsck didn't finish last night so I had to put the player back together this morning so I could have music on the way to work.
