#277961 - 20/03/2006 14:07
Hijack - Installed now player won't boot !!!
Loc: Hong Kong
Well I knew there was a risk but everyone said it was minimal, plus I needed hijack to run my Sony stalk Controller. I used Tony's Logo Editor to flash the Kernel with the latest version to my Mk II player. Now it boots confirms hijack is present gets as far as trying to load the database and says: "hda: disk error: irq timeout" What gives?
Empeg MkII
Rio MKIIa
Long term Empeg user; newbie to the forums !!!
#277962 - 20/03/2006 14:22
Re: Hijack - Installed now player won't boot !!!
[Re: bad]
That message is NOT related to Hijack.
Things to do:
(1) Don't Panic. Nothing bad has happened yet, so don't try and make something bad happen!
(2) Reflash Hijack again, and see if that cures it.
(3) Revert back to the original empeg kernel, and see what that does (available from the Hijack site) -- there is no need to reinstall the empeg software.
#277963 - 20/03/2006 14:51
Loc: Hong Kong
Nah, I didn't panic, but I'm more worried about how I am going to install the Sony Stalk Controller if I can't get Hijack to work.
First of all, it is interesting that you said this isn't Hijack related. After I got my Empeg player back after the digital sound card install and booted it, I noticed that it took a long long time to boot after reaching the Loading music databases screen.
I reflashed the kernel and no dice. then reinstaled the original 2.00 consumer software release and no problems at all. Went back and tried to reinstall Hijack and exactly the same thing. It installs without any problem, gets to the loading music databases part and pops out with:
"hda: hard disk error: irq timeout"
But it only happens after installing Hijack not with the original Rio consumer software.
Any ideas? I realize hijack isn't essential, but I just had two Sony Controllers drop shipped to Hong Kong from the States by a friend so that I could install them with my players and two radio modules.
Paul.
Empeg MkII
Rio MKIIa
#277964 - 20/03/2006 16:02
[Re: bad]
Are you able to get into the hijack menu? (Hold the knob in for about one second) You might play with the hdd detection setting.
#277965 - 20/03/2006 17:25
[Re: bad]
You still have not reported on the steps I suggested.
#277966 - 20/03/2006 17:26
[Re: bad]
Quote: I'm more worried about how I am going to install the Sony Stalk Controller if I can't get Hijack to work
If you're talking about the wired Sony StalkController that plugs into the radio module, you don't need Hijack for that.
#277967 - 20/03/2006 17:49
#277968 - 20/03/2006 17:56
[Re: RobotCaleb]
Question / Observation: I notice that you mentioned that you are running the empeg consumer version. Could it be a software mismatch? Have you tried loading the empeg developer version in place, and then tried hijack?
#277969 - 20/03/2006 18:29
[Re: RobotCaleb]
Quote: I thought he had done?
He probably thought so, too. But not.
#277970 - 20/03/2006 19:48
Quote: I reflashed the kernel and no dice. then reinstaled the original 2.00 consumer software release and no problems at all. Went back and tried to reinstall Hijack and exactly the same thing. It installs without any problem, gets to the loading music databases part and pops out with:
Quote: (1) Don't Panic. Nothing bad has happened yet, so don't try and make something bad happen!
Ah. I guess you want him to install the original kernel as downloaded from your site instead of reinstalling the consumer kernel. Correct?
Is there anything in hijack that would depend on the installation / software load of the full developer fileset instead of the consumer fileset? I know the kernel should not matter, but perhaps any of the other files? Just curious.
Edited by pgrzelak (20/03/2006 19:56)
#277971 - 20/03/2006 19:53
Perhaps you should clarify what you mean, then.
#277972 - 20/03/2006 20:05
[Re: bad]
Also, make sure your download of Hijack is good. Delete the one on your hard drive and download it again just to be sure.
#277974 - 24/03/2006 07:22
[Re: schofiel]
Loc: Hong Kong
Okay,
First of all Mark, I'm sorry if anyone gave you a hard time, your steps are actually quite clear and it was I that misread them. I also appreciate that you do know exactly what you are talking about. Unfortunately these still have not solved the problem.
Reflashing Hijack hasn't worked.
Reflashing the original kernel from the Hijack site works.
Reflashing Hijack after installing the original kernel from the Hijack site still results in the same error.
I haven't yet tried the developer software version. Should I?
Hijack is installed, and I can enter the menu. I did not however find anything re HD Settings. Is it under another heading in the Hijack menu or is it therefore missing and could that have anything to do with the error.
A few anomolies for you:
Even though I installed the Hijack Kernel with the "boot with Rio personality" option chosen, the player still boots as Empeg with our little penguin friend.
Whilst I was in the process of checking this thread, I realized that if left long enough, the error message actually disappears and the player 'appears' to be fully functional including the Hijack menu. So is it just a glitch that I should ignore?
Empeg MkII
Rio MKIIa
#277975 - 24/03/2006 18:06
[Re: bad]
Oh good. Now, with the stock kernel, show us a boot log.
I'm asking for this, because I do know that Hijack is fussier about having working hardware than is the stock kernel -- so I want to see if there's anything failing to initialize..
#277976 - 25/03/2006 16:46
Loc: Hong Kong
Alright, you've got me. I've been forced to show my ignorance. How do I show a boot log? Imagine you are explaining to the stupidest newbie on here and then imagine I have about 50% of that intelligence.
Also you said stock kernel, so do you want me to reflash using the original kernel from the Hijack site or the OEM software from the old Empeg site?
Step by step instructions please !!!
Paul.
Empeg MkII
Rio MKIIa
#277977 - 25/03/2006 17:10
[Re: bad]
Loc: Triangle, VA
Use this to connect and copy all that shows up at boot time...
-D
#277978 - 25/03/2006 23:17
[Re: bad]
Either, in this case. But thanks for asking! Other people here can help you with obtaining the boot log.
#277979 - 27/03/2006 16:46
Loc: Hong Kong
I'm sorry. I can't figure this out. I connect my player up and reflash the kernel to the original which gives me no problems, I understand that. Now with the player still connected by serial I go into hyperterminal ... then what. Rebooting the player doesn't seem to do anything. Is there something I need to do in hyperterminal that initiates the reboot?
Paul.
Empeg MkII
Rio MKIIa
#277980 - 27/03/2006 16:50
[Re: bad]
From where you just described, just unplug the power from your empeg, and then plug it back in again.
#277981 - 27/03/2006 16:58
[Re: bad]
Quote: Rebooting the player doesn't seem to do anything.
Rebooting the player by pulling its plug should make a bunch of text flow down the screen in hyperterminal. If it doesn't, then something is wrong with your serial connection or with the way hyperterminal is configured.
#277982 - 07/04/2006 04:44
Loc: Hong Kong
Hyperterminal Readout which suggests there is a problem. Can anyone suggest what it might be?
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kerne l. Linux version 2.2.14-rmk5-np17-empeg52 (rob@aphex) (gcc version 2.95.3 20010315 (release)) #11 Tue Apr 1 18:49:59 BST 2003 Processor: Intel StrongARM-1100 revision 11 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 40103248) Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init) Dentry hash table entries: 2048 (order 2, 16k) Buffer cache hash table entries: 16384 (order 4, 64k) Page cache hash table entries: 4096 (order 2, 16k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea Universit NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 16384 bhash 16384) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Linux-IrDA: IrCOMM protocol ( revision:Tue May 18 03:11:39 1999 ) ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 ) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0004080). empeg RDS driver initialised empeg power-pic driver initialised (first boot) RAM disk driver initialized: 16 RAM empeg single channel IDE Probing primary interface... hda: FUJITSU MHL2300AT, ATA DISK drive hdb: FUJITSU MHL2300AT, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63 hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:b 0 Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00 20 03/04/01. hda: irq timeout: status=0xd0 { Busy } ide0: reset: success hda: irq timeout: status=0xd0 { Busy } ide0: reset: success hda: irq timeout: status=0xd0 { Busy } ide0: reset: success hda: irq timeout: status=0xd0 { Busy } end_request: I/O error, dev 03:03 (hda), sector 4939 hda: status timeout: status=0xd0 { Busy } hda: drive not ready for command ide0: reset: success Prolux 4 empeg car - 2.1434 Mar 26 2003 Vcb: 0x4086d000
Empeg MkII
Rio MKIIa
#277983 - 07/04/2006 06:33
[Re: bad]
You wouldn't happen to be having this problem, would you?
#277984 - 07/04/2006 15:55
Loc: Hong Kong
Tony,
Some of those have happened in the past but few with any frequency save possibly the starting at a different song and I believe this is due to a wiring problem in the car which I have to isolate. That said this looks like something it would be worth doing anyway so I'll follow all the steps sometime over the next week when I have time and let you know if it works out. If not then it looks like it might only need a new drive which wouldn't be the end of the world.
Paul.
Empeg MkII
Rio MKIIa
