#277169 - 09/03/2006 15:50
random sigkill on boot
Loc: Regensburg, Germany
Since the temperatures dropped in fall I started getting random sigkill errors on boot. I have to reinsert the empeg several times until it boots fully. I thought it was a bad solder joint at the HDD connector and finally took it apart just 20 minutes ago and re-soldered the connector (i.e. liquified all solder points). Plugged it in and updated Hijack to v444. Pressed "reboot" just for the hell of it and there it was again, the dreaded sigkill eror. I have two HDDs, one fairly new, less than two years (one of the original ones had died). Please see the attached pics and video (made with my treo - requires Real player). Note the grabled graphics (but the connector is fine and once it boots, everything is ok). Any ideas?
277483-Video_030906_004.3gp (213 downloads)
32MB, serial: 10101626
#277170 - 09/03/2006 17:27
Re: random sigkill on boot
[Re: bjoern]
Have you installed any hardware in the box?
#277171 - 10/03/2006 07:21
[Re: schofiel]
No, there's no additional hardware (except additional RAM, but that was installed long before the errors came). I forgot to mention that sometimes the player settings get lost when the error occurs. It also seems to be somewhat temperature-dependent in that it appears to be less likely to occur when I bring the empeg to the car from inside, compared to when it's been locked in the cold trunk. But it's a fairly weak correlation. It also seems to happen less often if I start the car and the empeg has been running before, e.g. when it's been sitting in the garage with the empeg in its sled as opposed to when I put the empeg in the sled from outside. But that's also not 100%.
#277172 - 10/03/2006 08:40
[Re: bjoern]
I'd still check the RAM installation.
#277173 - 15/03/2006 15:31
[Re: schofiel]
Ok, I hooked the empeg up to record the bootlog. It seems to only start when 16M of RAM are detected, so you were right on. This is a bootlog when it booted normally:
CCC¡V
•µ…ɉ½½ÑÍÑÉ…ÁÙŹÁÉÉÁÁÁÅÅÁÙ¡¡Õ½•µÁ•¹½µ¥5)ÿIf there is anyone present who wants to upgrade the flash, let th
em speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v444 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Dec 2
14:42:18 EST 2005
Checking for extra DRAM:
c10000f4: wrote 00ff00ff, read 00ff00ff
empeg-car player (hardware revision 9, serial number 10101626) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005480).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATMR04-0, ATA DISK drive
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: IC25N040ATMR04-0, 38154MB w/1740kB Cache, CHS=4864/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:5a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘ɽ½Ñ¡•áÑÉ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5ÿchange_root: old root has d_count=1
Mounting proc
Starting player
àlayer redirected to /proc/ttyH
U««K½¹•éѱ…¹Ñ¥½M½ÕÑ¡}•½É¥…)5ÿ*K+kkKJ¹Ñ•É•ÁÑ¥¹½¹™¥¹¥¹¥)5ÿ¡øEmpire: Version 0.40 starting...
khttpd: listening on port 80
kftpd: listening on port 21
IrDA: Registered device irda0
And this is the bootlog with the sigkill-error:
e000 v1.04
Copying kernel...
14:42:18 EST 2005
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10101626) 32MB DRAM
Memory: 31232k/32M available (984k code, 20k reserved, 528k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
TCP: Hash tables configured (ehash 32768 bhash 32768)
kmem_alloc: Bad poison (name=size-65536)
kmem_alloc: Bad poison (name=size-128)
Unable to handle kernel paging request at virtual address 0000547c
memmap = C0004000, pgd = c0004000
*pgd = c0131801, *pmd = c0131801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c002b078>] lr : [<0000547c>]
sp : c0187e78 ip : c1fa5fc0 fp : c0187e94
r10: c011a394 r9 : c0126438 r8 : c01f9b80
r7 : 00000015 r6 : 00000000 r5 : 00008124 r4 : c0183140
r3 : 00000007 r2 : a5c32f2b r1 : 00000015 r0 : 0000004b
Flags: nZCv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process swapper (pid: 1, stackpage=c0187000)
Stack:
c0187e60: 0000547c c002b078 60000093 ffffffff c010a82c 00008124
c0187e80: 00000006 00000000 c0187ebc c0187e98 c0059524 c002b00c c00f60f0 c1fa5340
c0187ea0: c010a82c c1fa5340 c012d8f4 c01f9ae0 c0187ed8 c0187ec0 c00a5c14 c00594d8
c0187ec0: c012d948 c012d8f4 00000001 c0187efc c0187edc c00a5d18 c00a5be0 c01f9b80
c0187ee0: c012d995 c012d840 c01f9ae0 00000000 c0187f20 c0187f00 c00a5dd0 c00a5cd0
c0187f00: c01f9ae0 00000000 c00f4ee8 ffffffff c009ac3c c0187f34 c0187f24 c00a5e1c
c0187f20: c00a5d74 c011df80 c0187f44 c0187f38 c00a06e8 c00a5dfc c0187f58 c0187f48
c0187f40: c00a0bf4 c00a06dc 000000ff c0187f84 c0187f5c c009c784 c00a0be0 00000001
c0187f60: c0102768 c0123a30 c010a788 c01246e4 4401a11b c0008580 c0187f94 c0187f88
c0187f80: c00a0c18 c009c6bc c0187fb4 c0187f98 c0046d10 c00a0c10 00000001 c0102768
c0187fa0: c0123a30 c010a788 c0187fdc c0187fb8 c0009ae0 c0046d0c 00000000 c0009ba8
c0187fc0: c012d9ac c0102760 c0102764 c0102988 c0187ffc c0187fe0 c0009bb8 c00099c0
c0187fe0: c0009ba8 c012d9ac c0102760 c0102764 c0101fd8 c0188000 c000b6ec c0009bb4
Backtrace:
Function entered at [<c002b000>] from [<c0059524>]
r7 = 00000000 r6 = 00000006 r5 = 00008124 r4 = C010A82C
Function entered at [<c00594cc>] from [<c00a5c14>]
r7 = C01F9AE0 r6 = C012D8F4 r5 = C1FA5340 r4 = C010A82C
Function entered at [<c00a5bd4>] from [<c00a5d18>]
r6 = 00000001 r5 = C012D8F4 r4 = C012D948
Function entered at [<c00a5cc4>] from [<c00a5dd0>]
r8 = 00000000 r7 = C01F9AE0 r6 = C012D840 r5 = C012D995
r4 = C01F9B80
Function entered at [<c00a5d68>] from [<c00a5e1c>]
r8 = C009AC3C r7 = FFFFFFFF r6 = C00F4EE8 r5 = 00000000
r4 = C01F9AE0
Function entered at [<c00a5df0>] from [<c00a06e8>]
r4 = C011DF80
Function entered at [<c00a06d0>] from [<c00a0bf4>]
Function entered at [<c00a0bd4>] from [<c009c784>]
r4 = 000000FF
Function entered at [<c009c6b0>] from [<c00a0c18>]
r10 = C0008580 r9 = 4401A11B r8 = C01246E4 r7 = C010A788
r6 = C0123A30 r5 = C0102768 r4 = 00000001
Function entered at [<c00a0c04>] from [<c0046d10>]
Function entered at [<c0046d00>] from [<c0009ae0>]
r7 = C010A788 r6 = C0123A30 r5 = C0102768 r4 = 00000001
Function entered at [<c00099b4>] from [<c0009bb8>]
r8 = C0102988 r7 = C0102764 r6 = C0102760 r5 = C012D9AC
r4 = C0009BA8
Function entered at [<c0009ba8>] from [<c000b6ec>]
r7 = C0102764 r6 = C0102760 r5 = C012D9AC r4 = C0009BA8
Function entered at [<c00096c4>] from [<c00098b0>]
Function entered at [<c00096dc>] from [<c0008080>]
r7 = C0123F00 r6 = C0123E54 r5 = C012E3E0 r4 = C012E3E0
Code: e2833001 e58c300c (e59e2000) e3520000 e58c2000
Do these bootlogs tell me where exactly I need to look?
Edited by bjoern (15/03/2006 15:32)
#277174 - 15/03/2006 16:16
[Re: bjoern]
This looks like a faulty block of memory.
#277175 - 16/03/2006 10:26
[Re: schofiel]
Yesterday, I re-soldered the main lead that goes from the memory to the strongarm chip and it recognized the RAM just fine. I put it into the car and it worked like a charm first try. Then I parked the car, put the empeg into the trunk and two hours later the problem was back! Any idea which of the four chips (I piggy-backed two extra RAM chips) it could be? Any suggestion as to how to fix the problem? Has anybody else with the piggy-back method had any problems?
#277176 - 16/03/2006 11:23
[Re: schofiel]
Here's a boot-log of a successful 32MB boot sequence: Code:
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com) If there is anyone present who wants to upgrade the flash, let them speak now, or forever hold their peace...it seems not. Let fly the Penguins of Linux!
e000 v1.04 Copying kernel... Calling linux kernel... Uncompressing Linux..................................... done, booting the kernel. Linux version 2.2.17-rmk5-np17-empeg52-hijack-v444 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Dec 2 14:42:18 EST 2005 Processor: Intel StrongARM-1100 revision 11 Checking for extra DRAM: c1000000: passed. c1100000: passed. c1200000: passed. c1300000: passed. c1400000: passed. c1500000: passed. c1600000: passed. c1700000: passed. c1800000: passed. c1900000: passed. c1a00000: passed. c1b00000: passed. c1c00000: passed. c1d00000: passed. c1e00000: passed. c1f00000: passed. c2000000: wrote ffffffff, read 00000000 NetWinder Floating Point Emulator V0.94.1 (c) 1998 Corel Computer Corp. empeg-car player (hardware revision 9, serial number 10101626) 32MB DRAM Command line: mem=16m Calibrating delay loop... 207.67 BogoMIPS Memory: 31232k/32M available (984k code, 20k reserved, 528k data, 4k init) Dentry hash table entries: 4096 (order 3, 32k) Buffer cache hash table entries: 32768 (order 5, 128k) Page cache hash table entries: 8192 (order 3, 32k) POSIX conformance testing by UNIFIX Linux NET4.0 for Linux 2.2 Based upon Swansea University Computer Society NET3.039 NET4: Linux TCP/IP 1.0 for NET4.0 IP Protocols: ICMP, UDP, TCP TCP: Hash tables configured (ehash 32768 bhash 32768) IrDA (tm) Protocols for Linux-2.2 (Dag Brattli) Starting kswapd v 1.5 SA1100 serial driver version 4.27 with no serial options enabled ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UART ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UART Signature is 636f6972 'rioc' Tuner: loopback=0, ID=-1 Scheduling custom logo. empeg display initialised. empeg dsp audio initialised empeg dsp mixer initialised empeg dsp initialised empeg audio-in initialised, CS4231A revision a0 empeg remote control/panel button initialised. empeg usb initialised, PDIUSBD12 id 1012 empeg state support initialised 0089/88c1 (save to d0005b80). empeg RDS driver initialised empeg power-pic driver initialised RAM disk driver initialized: 16 RAM disks of 4096K size empeg single channel IDE Probing primary interface... hda: IC25N040ATMR04-0, ATA DISK drive hdb: IC25N080ATMR04-0, ATA DISK drive ide0 at 0x000-0x007,0x038 on irq 6 hda: IC25N040ATMR04-0, 38154MB w/1740kB Cache, CHS=4864/255/63 hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63 empeg-flash driver initialized smc chip id/revision 0x3349 smc9194.c:v0.12 03/06/96 by Erik Stahlman (erik@vt.edu)
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:5a Partition check: hda: hda1 < hda5 hda6 > hda2 hda3 hda4 hdb: hdb1 < hdb5 hdb6 > hdb2 hdb3 hdb4 RAMDISK: ext2 filesystem found at block 0 RAMDISK: Loading 320 blocks [1 disk] into ram disk... done. EXT2-fs warning: checktime reached, running e2fsck is recommended VFS: Mounted root (ext2 filesystem). empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...•Ô•j½Õ¹Ñ•‘ɽ½Ñ¡•áÑÉ™¥±•ÍåÍÑ•µ¥É•…‘½¹±å¹)5ÿchange_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Remounting first music partition read-only Remounting second music partition read-only Press 'q' now to go into development mode. You Have Zero Seconds To Comply... Starting pla player redirected to /proc/ttyH U««K½¹•éÕɽÁ•½ •É±¥¹)5ÿ*K+kkKJ¹Ñ•É•ÁÑ¥¹½¹™¥¹¥¹¥)5ÿ Empire: Version 0.40 starting... hijack: removed menu entry: "Hard Disk Detection" khttpd: listening on port 80 kftpd: listening on port 21 IrDA: Registered device irda0
Do the three logs I posted help me in any way to determine how to fix the problem?
#277177 - 03/04/2006 20:15
problem solved (so far)
[Re: bjoern]
The problem got worse and worse. Just last week I had to insert and pull out the empeg probably 30-40 times until it would boot. In a desperate attempt this weekend, I pulled out the old soldering iron and re-heated and/or resoldered every single contact on the memory chips - and so far it's been booting like new! So, just for the record/archive: the empeg worked fine for months after the piggy-back memory upgrade. Then random sigkill-errors appeared during boot. The cure: re-solder the memory pins. All of them.
I just hope the problem doesn't come back.
Thanks for all your help, Rob!
