#261358 - 26/07/2005 08:01
Bugs in V3 A11
Loc: Switzerland
I think we should start a new thread with alpha11 bugs. Peter, is there a chance we see a new alpha soon?
Let's start:
AF does not work for predefined stations (it does not search for AF at all), but works perfect if you search by the left / right buttons.
Selecting a frequency by remote control (search button) still crashes my player in two of three cases. (sigkill)
I had a reboot (sigkill) on my short 10 minute trip today (in tuner mode)
#261359 - 26/07/2005 09:54
Re: Bugs in V3 A11
[Re: alex25]
Loc: Switzerland
Here is the tracedump for the sigkill event (changing frequency by remote control). Just in case someone can do something useful with it:
player(79): user memory violation at pc=0x02002d08, lr=0x02002d0c (bad address=0x00000029, code 2) pc : [<02002d08>] lr : [<02002d0c>] sp : bd3ffcb0 ip : bd3ffcc0 fp : bd3ffcbc r10: bd3ffcf8 r9 : bd3ffd08 r8 : bffffe38 r7 : bd3ffd0c r6 : 021e0a08 r5 : 021f43a8 r4 : 021f43a8 r3 : 00000001 r2 : 00000000 r1 : 00000001 r0 : 0225a6b0 Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user Control: D8E7517D Table: D8E7517D DAC: 00000015 Function entered at [<02002cf4>] from [<02052eac>] Function entered at [<02052e68>] from [<0206d248>] r5 = BD3FFCF0 r4 = 021E0A08 Function entered at [<0206d22c>] from [<0206d548>] r4 = BD3FFD08 Function entered at [<0206d380>] from [<0206d2a4>] r10 = 020DEA00 r9 = 021E0A08 r8 = 00004C14 r7 = 00000080 r6 = 00000014 r5 = BD3FFD4C r4 = 021E0A08 Function entered at [<0206d294>] from [<020dead4>] Function entered at [<020dea9c>] from [<020dea8c>] r5 = 021D40FC r4 = 021E0A08 Function entered at [<020dea00>] from [<0211c970>] r5 = 021E0A20 r4 = BD3FFE40 Function entered at [<0211c8a8>] from [<0215334c>] r4 = 00000000 Function entered at [<02151ac0>] from [<0211c6ec>] r8 = 021E9224 r7 = 021E9210 r6 = 020DEA00 r5 = 00000005 r4 = 00000000 Function entered at [<0211c63c>] from [<0215334c>] r5 = 00000000 r4 = 00000000 Function entered at [<00000074>] from [<021d1a28>] Function entered at [<e39ffff4>] from [<eb000a3f>] Function entered at [<2a00fef4>] from [<2a00ff00>] Unable to handle kernel paging request at virtual address 2a00fef8 memmap = D8E74000, pgd = c3e74000 *pgd = 00000000, *pmd = 00000000 Internal error: Oops: 2 CPU: 0 pc : [<c00e3d90>] lr : [<c00198f0>] sp : c2887f44 ip : c2887f00 fp : c2887f90 r10: 00000002 r9 : c3ecd0e0 r8 : 0000000c r7 : 00000000 r6 : 2a00fef4 r5 : 2a00ff00 r4 : ea000030 r3 : 60000013 r2 : c0104284 r1 : 00000001 r0 : ea000020 Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user Control: D8E7517D Table: D8E7517D DAC: 00000015 Process player (pid: 79, stackpage=c2887000) Stack: c2887f20: c00198f0 c00e3d90 60000013 c2887f40: ffffffff c3ecd0f8 c3ecc560 c2886000 c2887fb8 00000029 c0011b88 02002d0c c2887f60: 00000029 00000002 c2887fb8 0000000f 00000029 00000000 00000002 bd3ffd08 c2887f80: bd3ffcf8 c2887fb4 c2887f94 c00120e4 c0011928 c010297c 021f43a8 021e0a08 c2887fa0: bd3ffd0c bffffe38 00000000 c2887fb8 c000a0c8 c001200c 0225a6b0 00000001 c2887fc0: 00000000 00000001 021f43a8 021f43a8 021e0a08 bd3ffd0c bffffe38 bd3ffd08 c2887fe0: bd3ffcf8 bd3ffcbc bd3ffcc0 bd3ffcb0 02002d0c 02002d08 20000010 ffffffff Backtrace: Function entered at [<c001191c>] from [<c00120e4>] r10 = BD3FFCF8 r9 = BD3FFD08 r8 = 00000002 r7 = 00000000 r6 = 00000029 r5 = 0000000F r4 = C2887FB8 Function entered at [<c0012000>] from [<c000a0c8>] r8 = BFFFFE38 r7 = BD3FFD0C r6 = 021E0A08 r5 = 021F43A8 r4 = C010297C Code: ebfcd653 e2440010 (e5961004) e1a035a1 e59f20cc
#261360 - 26/07/2005 10:26
Re: Bugs in V3 A11
[Re: alex25]
After the upgrade, I've had trouble connecting to both players from emplode 2.10 via serial. I can connect fine through hyperterminal. Can anyone else verify this?
#261361 - 26/07/2005 12:12
Re: Bugs in V3 A11
[Re: alex25]
I was able to wedge the player twice by fast-forwarding in a song too long last night. When I go out again in a bit I will try again over more songs.
Said song was encoded with lame, uniform bitrate.
#261362 - 26/07/2005 12:57
Re: Bugs in V3 A11
[Re: Daria]
RTFRN:
* Known Issues
Long bursts of fast-forwarding or rewinding can cause a lockup.
#261363 - 27/07/2005 19:30
Re: Bugs in V3 A11
[Re: JBjorgen]
I'm now running A11 on my main unit, and I'm not positive if this audio glitch was in the previous alphas, but when toggling the pause mode on a mp3, I hear a faint pop in the audio playback. Can anyone else confirm this?
I've got crossfade on 0.5s, that's really the only 3.0 unique setting I've enabled.
Oliver
#261364 - 28/07/2005 03:19
Re: Bugs in V3 A11
[Re: oliver]
Loc: Switzerland
In Antwort auf: I'm now running A11 on my main unit, and I'm not positive if this audio glitch was in the previous alphas, but when toggling the pause mode on a mp3, I hear a faint pop in the audio playback. Can anyone else confirm this?
Do you use the players equalizer? If yes, please try to set it to flat and try it again. I had similar problems with earlier alpha versions (the first one with the auto eq feature). That's why I don't use the equalizer anymore, but rather the bass and treble settings.
#261365 - 31/07/2005 04:54
Re: Bugs in V3 A11
[Re: alex25]
Loc: San Jose, CA
The long down press in the playlist menu functionality seems to be borked in A11 (the "go back to last playlist menu" option).
The normal behavior is that when I'm at the playlists menu, a long downpress brings me to the last place I originally was browsing in the playlist (the last album, artist or song I select. From there, you can then select a new song/artist/album/whatever and then go into the enqueue/append/replace menu.
The behavior now skips the last playlist entirely and drags me straight to the enqueue menu, and in fact auto selects enqueue, resulting in a duplicated playlist. Looks like the intermediate keypresses are just "assumed"
-- Gary F.
Eeyore, Original Owner -- Mk II 80 Gb, Blue
S/N #090000803
Tigger, 2nd Owner -- Mk IIa, 80 Gb, Blue
S/N #40103789
#261366 - 31/07/2005 09:11
Re: Bugs in V3 A11
[Re: Foz]
Quote: The long down press in the playlist menu functionality seems to be borked in A11 (the "go back to last playlist menu" option).
This happened in one of the early betas also but wasn't there in v3a8 I don't think. The only workaround I've found is to only hold the button long enough to record a long keypress.
On my empeg it seems to happen when the drives need to be spun up. If they are already spinning the problem doesn't happen (or not as much at least).
#261367 - 02/08/2005 07:15
Re: Bugs in V3 A11
[Re: Shonky]
Loc: New York
how come i can use my emplode. It gives me a database error when trying to sync database of mkII.
#261368 - 30/08/2005 17:12
Re: Bugs in V3 A11
[Re: iopcool25]
I was just on my way into work, and I was listening to Del Tha Funkee Homosapien (Both Sides Of The Brain), and track 14 (Catch all This) came to an end and all I heard was some really nasty noise. I looked at the Seek Tool, and noticed it was about 5 seconds past the end of the track and still playing. So I skipped ahead, and the next track started to play. So I rewound back to the end of the previous track and it did the same thing again.
So I just skipped ahead to track 15 again, and was listening to that. However, at the end of that track the player completely froze (except hijack, did the reboot machine, I did check the Vital Signs before rebooting, and the player was at about 3.5, 3, 2 for the load averages) and played that track again. Same thing at the end of track 15 (Phoney Phranchise).
After I get home to my empeg power brick. I'll grab those songs off my empeg. What programs should I use to analyze these tracks? Or should I just upload them so the empeg guys can download them?
Edited by oliver (30/08/2005 17:14)
Oliver
#261369 - 30/08/2005 17:16
Re: Bugs in V3 A11
[Re: alex25]
Quote: I'm now running A11 on my main unit, and I'm not positive if this audio glitch was in the previous alphas, but when toggling the pause mode on a mp3, I hear a faint pop in the audio playback. Can anyone else confirm this?
Also, Sorry for the late reply. However, all the answers to those questions are No, my EQ is very flat, I've never used the autoeq, and the VolAdj feature is always disabled. Also the Tone settings in Hijack are set to Off.
Oliver
#261370 - 01/09/2005 08:15
Re: Bugs in V3 A11
[Re: alex25]
I've noticed a couple of problems since switching to v3a11.
1. When listening to the Tuner in the car the audio muting (for car phone etc) dosn;t work. It works perfectly when in player mode. I've note yet tried the tuner with any other versions of the software so can't really say if this is a bug specific to v3a11 or more of a "feature"
2. Some times the player randomly moves on to the next track part way through the current one. Going back to the skipped track normally results in it playing to completion
Mk2a 64mb 60gb
#261371 - 01/09/2005 10:47
Re: Bugs in V3 A11
[Re: russell]
ISTR that there's a setting for what mute does while in Tuner mode. Maybe that got reset? Or I could just be making stuff up.
#261372 - 01/09/2005 11:33
Re: Bugs in V3 A11
[Re: russell]
Quote: 2. Some times the player randomly moves on to the next track part way through the current one.
I've never seen that in any of the v3 alphas. What type of tracks (MP3, FLAC, etc.)? Does the length of the track displayed on screen agree with the length of the track as reported by another player (e.g. Windows Media Player)? What did you use to encode them? Are they constant or variable bitrate? What bitrate? Mono/stereo? Does it seem to be the same tracks all the time, or is it everything on the player?
#261373 - 02/09/2005 05:54
Re: Bugs in V3 A11
[Re: alex25]
Had an interesting bug I have not managed to pin down yet - doesn't appear to be connected to a particular track or playlist, and isn't repeatable deliberately, but sometimes when the end of the track is reached, something seems to hang.
Functionality appears perfect, except nothing plays - the song remains at the end, and the timestamp is the last second of the song. If it is at the end of a 3 minute 25 song, and I skip forward or back, it goes to 3:25 in the next song and does nothing. I have not yet managed to get a log as it has never done it when I have it hooked up at home (although in the dock it does think it is in the car)
Only solution is reboot through hijack which works every time.
#261374 - 15/09/2005 22:17
Re: Bugs in V3 A11
[Re: alex25]
Loc: Salt Lake City, UT
First time I have seen this bug(for A11), so I figured I better mention it. Yesterday I had the infamous source switching happen. First time with A11, which I've been running since it was released. It happened the same as when the bug was in previous alphas. Revoving, and reinserting the player fixed it.
-Michael
#261375 - 01/10/2005 15:13
Re: Bugs in V3 A11
[Re: alex25]
Long down press on 'Playlists' (to take you to the last selected playlist) seems to go too far (and select 'Replace') on my empeg with 3a11. Anyone else confirm this?
#261376 - 02/10/2005 03:12
Re: Bugs in V3 A11
[Re: Roger]
Yup. Although mine seems to Append rather than Replace. This isn't new in v3a11 though. I think it has existed in all the v3 alphas.
It doesn't always do it though. Sometimes it works OK. It seems to work better if the drives are already spun up.
#261377 - 19/10/2005 13:29
Bookamrks are not saved while player is caching music
[Re: alex25]
Loc: Qc, Canada
When the player is caching (small dark hdd icon in upper right), if I try to set a bookmark, it is not saved properly. When I try to go to that bookmark, I come up with an empty playlist. If I wait for the hdd icon to dissapear and then save the bookmark, it works every time.
Patrick
#261378 - 19/10/2005 13:35
Re: Bugs in V3 A11: sigkill error
[Re: alex25]
Loc: Qc, Canada
Changing volume while empeg is caching for the first time after startup often produces a sigkill.
3.0a11 mk2a 32M 2x30G Hijack v440
Patrick
#261379 - 17/08/2006 18:48
Re: Bugs in V3 A11
[Re: alex25]
Loc: Plymouth, UK
I've been running a11for a couple of months I guess. Today it all went wrong. All was well when I went to work. On coming home the unit just kept rebooting. It would boot to showing the track playing (but not actually, and duration not changing, buttons unresponsive) and after a variable amount of time reboot. This it continued to do until pulled from the sled. The unit was very hot at this point. This behavior contued even fter the unit had been reinserted when cold. Same thing when plugged into the mains. V2 final now installed and all is well.
#261380 - 21/01/2007 15:21
Re: Bugs in V3 A11
[Re: Will]
Loc: Herts, UK
Running A11, has the same as the last poster, no big problem, just re-booted and fine.
Randomly the software hung at the end a track, manual reboot(read as taking out of sled live, and re-inserting), unit went through the boot sequence, then instantly hung on the track again. Manual reboots, and from within hijack do nothing. Had to bring it indoors and as soon as it booted up Pause it, then re-boot, then hold to standby, then pic another play list on resume. Unit was playing a 20 song mp3 playlist on shuffle.
Getting Old.
#309135 - 15/04/2008 13:51
Re: Bugs in V3 A11
[Re: alex25]
The 'xid' field is used by the client to match incoming DHCP messages with pending requests. A DHCP client MUST choose 'xid's in such a way as to minimize the chance of using an 'xid' identical to one used by another client. For example, a client may choose a different, random initial 'xid' each time the client is rebooted Unfortunately there is a bug in 3.00 alpha 11, Receiver Edition only, such that it doesn't do this -- it doesn't adequately randomise the xid on boot, so two Receiver Edition car-players on the same network both get the same xid, and thus any attempt by the DHCP server to assign an IP address to either one of them, is actioned by both, so both get the same IP address. Which is bad. There are some workarounds: - Give static IP addresses to Receiver Edition car-players. Note that you can't switch a car-player from DHCP to static while Receiver Edition is on it; you need to temporarily reinstate the Standard Edition.
- Partition the network somehow, so that broadcast packets don't reach both players; this is likely to need features that domestic switches don't have.
- Whenever you're powering-on a Receiver Edition car-player, temporarily unplug the others from the network.
- Using the serial port, Ctrl-C and restart the player on all the units (or, technically, all but one). When the player restarts, it will pick a new random xid and thenceforth[1] be capable of obtaining a unique address.
This bug was probably my fault, sorry ![frown frown](/images/graemlins/default_dark/frown.gif) Peter [1] Tanstaafl is right, using a word that the BBS hasn't seen before is harder than you'd think.
#309137 - 15/04/2008 13:54
Re: Bugs in V3 A11
[Re: peter]
Note that you can't switch a car-player from DHCP to static while Receiver Edition is on it; Even by editing config.ini directly?
#309138 - 15/04/2008 13:56
Re: Bugs in V3 A11
[Re: peter]
Also: What impact would this have on a network that contains both Rio/Dell Recievers, *and* one or more car players running Receiver Edition?
#309139 - 15/04/2008 14:03
Re: Bugs in V3 A11
Even by editing config.ini directly? That would work fine. I just meant that the "normal" car-player method of changing it, using Emplode, doesn't apply. Also: What impact would this have on a network that contains both Rio/Dell Recievers, *and* one or more car players running Receiver Edition? Receiver Edition only interferes with other Receiver Editions, not with real Receivers of either variety. And multiple real Receivers all DHCP'ing on the same network is extremely well-(at)tested. Peter
#309146 - 15/04/2008 15:02
Re: Bugs in V3 A11
[Re: peter]
Thanks for those clarifications. :-)
#309147 - 15/04/2008 15:34
Re: Bugs in V3 A11
[Re: peter]
Unfortunately there is a bug in 3.00 alpha 11, Receiver Edition only, such that it doesn't do this -- it doesn't adequately randomise the xid on boot, so two Receiver Edition car-players on the same network both get the same xid, and thus any attempt by the DHCP server to assign an IP address to either one of them, is actioned by both, so both get the same IP address. Which is bad. Can this be patched (one or two bytes) in the binary ?
Edited by mlord (15/04/2008 15:34)
#309157 - 15/04/2008 17:41
Re: Bugs in V3 A11
Can this be patched (one or two bytes) in the binary? I can't foresee so, no. Some extra code would need adding, there's no patch-one-instruction fix I can think of. And of course I don't have access to the source any more (it's not even clear who does -- probably Freescale), so even if I could figure out somewhere to logically patch, it'd be hard to convert that idea into an actual patch. For now (and there aren't AFAICT all that many users of Receiver Edition) it'll have to be the workarounds. Peter
