#260996 - 20/07/2005 16:12 Mk2a wont power up in car/dock, but fine in ac
StigOE
Hi, all.
When I put my spare Mk2a in the dock I bought from Boxer (thanks, Boxer!) after having put on some Greenlights buttons, the only thing that happened was the blue light flashing. This was the first time I have tried it on dc power (I might have tried it in the car a long time ago). When I applied ac power it booted up normally, so I tried it in the car in case there was something wrong with the dock wiring, but the same thing happened in the car...
When I connected up the serial and applied power (in the dock), I got:
, quick boot
Power down
Power down
Power down
Power down
Power down
The bootlog in ac is normal. I also reflashed it to 2.01 developer (was 2.00 developer) and installed Hijack 434, but no change.
Anyone have any good ideas?
Stig
#260997 - 20/07/2005 16:54 Re: Mk2a wont power up in car/dock, but fine in ac [Re: StigOE]
schofiel
Bootlog, please....
#260998 - 20/07/2005 17:43 Re: Mk2a wont power up in car/dock, but fine in ac [Re: schofiel]
StigOE
The bootlog from when I plugged in the power in the dock is what I wrote in my previous post.
Bootlog when powered in ac:
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v434 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Thu Jun 23 22:37:21 EDT 2005
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10101202) 32MB DRAM
Command line: mem=16m
Memory: 31232k/32M available (984k code, 20k reserved, 528k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 32768 bhash 32768)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004800).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T060ATCS05-0, ATA DISK drive
hda: IC25T060ATCS05-0, 57231MB w/1768kB Cache, CHS=7296/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:04:b2
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... &#8226;Ô¿'¤S«¹Ñ&#8226;&#8216;&#65533;Û½½Ñ&#65533;¡*áÑÉ&#65533;2¥±&#8226;ÍåÍÑ&#8226;µ¥&#402;&#8217;&#8226;&#8230;&#8216;½¹±å¹{jþchange_root: old root has d_count=1
Mounting proc
No secondary hard disk
Starting player
Timezone: CET
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 374 (bonus 16Mb, adjustment 0)
player.cpp : 385:empeg-car 2.01 2004/07/06.
Prolux 4 empeg car - 2.1434 Jul 5 2004
Vcb: 0x4176d000
To me it looks normal...
Stig
#260999 - 20/07/2005 20:00 Re: Mk2a wont power up in car/dock, but fine in ac [Re: StigOE]
Hmmm... Have you tried it in a different car sled or one of Mark's docks? That would isolate an issue with the specific sled.
Edit: Hmmm... rereading your first post, it happens in both a dock and a sled. That implies something bad on the power lines of the player itself or the connector, specifically on the DC link.
#261000 - 21/07/2005 20:54 Re: Mk2a wont power up in car/dock, but fine in ac [Re: StigOE]
StigOE
Hmm, this was strange. I opened the player to see if I could see anything obviously wrong (which I didn't), when I remembered Tony had some problems with his ac sensor. But I didn't remember what the symtoms were, so I did a search and found this post, which looked to be the same problem as mine. When I connected the sled connector from my spare sled and applied power to check the diode, it powered up properly... even in the sled and after I had re-assembled the player... So now it works again. Maybe the electrons were flowing in the wrong direction or the phase of the moon was a bit wrong or something the other day...?
Stig
#261001 - 21/07/2005 21:07 Re: Mk2a wont power up in car/dock, but fine in ac [Re: StigOE]
matthew_k
So to recap, it works in one sled but not in another sled, but your Empeg MkII works in both sleds?
EDIT: Never mind, I reread your orginal post, and we're not talking about a blown sled fuse as you're using a ML Dock.
Edited by matthew_k (21/07/2005 21:19)
#261002 - 21/07/2005 21:16 Re: Mk2a wont power up in car/dock, but fine in ac [Re: matthew_k]
So to recap, it works in one sled but not in another sled, but your Empe MkII works in both sleds?
If that's the case, then his problem is very specifically this problem.
#261003 - 21/07/2005 21:20 Re: Mk2a wont power up in car/dock, but fine in ac [Re: tfabris]
matthew_k
Yeah, that's what I was getting at. But I reread the thread and I don't think that's it.
#261004 - 22/07/2005 05:02 Re: Mk2a wont power up in car/dock, but fine in ac [Re: matthew_k]
StigOE
Yep, you're right. It isn't... It wouldn't boot up in neither car nor ML dock, but no problems on ac.
Stig
