Ok. All done:
Starting bash.
empeg:/empeg/bin# ro
empeg:/empeg/bin# umount /dev/hda4
empeg:/empeg/bin# umount /dev/hdc4
umount: /dev/hdc4: not found
empeg:/empeg/bin# swapon /swapfile
Adding Swap: 16028k swap-space (priority -1)
empeg:/empeg/bin# fsck -fay /
Parallelizing fsck version 1.19 (13-Jul-2000)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda5 is mounted.
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
/dev/hda5: 1512/4096 files (0.5% non-contiguous), 9996/16384 blocks
empeg:/empeg/bin# fsck -fay /dev/hda4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
/dev/hda4: 18364/762368 files (13.2% non-contiguous), 58979168/97578810 blocks
empeg:/empeg/bin# fsck -fay /dev/hdc4
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hdc4 is mounted.
fsck.ext2: Device not configured while trying to open /dev/hdc4
Possibly non-existent or swap device?
empeg:/empeg/bin# swapoff /swapfile
empeg:/empeg/bin# sync
empeg:/empeg/bin#
Then, unplugged and plugged:
_______________
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v429 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue May 10 20:39:19 EDT 2005
Added temporary pagedir entry for flash memory access
Checking for extra DRAM:
c1000000: wrote ffffffff, read e2811004
empeg-car player (hardware revision 9, serial number 40103216) 16MB DRAM
Command line: mem=16m
Memory: 15012k/16M available (984k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x98b7c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005580).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHU2100AT, ATA DISK drive
hda: FUJITSU MHU2100AT, 95396MB w/8192kB Cache, CHS=12161/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0c:90
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
No secondary hard disk
Starting player
Timezone: MET
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Using non-standard cache size 90 (adjustment 10)
player.cpp : 564:empeg-car 3.00-alpha7 2004/02/13.
Prolux 4 empeg car - 2.1490 Feb 13 2004
Vcb: 0x40693000
_________________
So, look at the bold lines. Still needs to check the disks, and I got those errors.
![](/ubbthreads/images/graemlins/frown.gif)
Does anybody know what that means?
Thank you!
