#255483 - 05/05/2005 13:40
Empeg Problem
Hiya. My 30 gig mk2a was in the process of synching when the power was accidentally disconnected from the unit. Now when I plug it in, it gets through Building Music Database but gets stuck on Building playlist database. I hear no more hard drive activity once it gets to this point, it just hangs there.
I'm trying to synch it again but Emplode can't find the player. I havn't tried USB yet. I'm running software version 2.00. How can i fix this?
#255485 - 05/05/2005 13:52
Re: Empeg Problem
[Re: visuvius]
#255486 - 05/05/2005 13:52
Re: Empeg Problem
[Re: eliceo]
I'm pretty sure its not a cable connection problem or anything like that. I have not yet tried Jemplode and have to wait till I get home from work to try usb and serial.
#255487 - 05/05/2005 13:57
Re: Empeg Problem
AH. Sorry. Shoulda known the faq would have it. Hopefully I can get it to connect with USB at home since ethernet is not really working.
#255488 - 05/05/2005 14:43
Re: Empeg Problem
[Re: visuvius]
The solution involves neither USB nor Ethernet. It requires serial shell access.
#255489 - 05/05/2005 15:21
Re: Empeg Problem
Oh, I must have misunderstood.
"Usually, you need only to synch once with Emplode to cure the problem. If synching once with Emplode doesn't solve the problem, you can force it to rebuild the database as follows:"
I thought I might be able to try synching with USB, then if that failed I'd try going through hyperterminal instructions.
I havn't got the developer version of the player software installed though. Do you know if I'll have any problems installing the developer version while something is wrong with the database?
#255490 - 05/05/2005 15:25
Re: Empeg Problem
[Re: visuvius]
Right, you already said you couldn't connect with Emplode, thus you're stuck with the shell prompt solution now.
#255491 - 13/05/2005 16:02
Re: Empeg Problem
Ok. So I fnally got around to trying to fix this but I'm having some issues. You linked me here which had a link to filesystem errors, which is I think more of my problem. As explained by the line "This error can also be caused by rebooting the player during the middle of a synch operation, either on purpose or accidentally because of a crashed synch", which is what happend to me. Now mine hangs on "Building Playlist database..." I was able to connect to the empeg with HyperTerminal and verified that I had the developer image of the 2.00 beta 13 player software. To correct the problem, I'm trying to follow these instructions: "To correct this error, make sure you're using the developer firmware on the player, use hyperterminal to get to a shell prompt with either a Q or a Ctrl-C command, then enter the following at the shell prompt: ro umount /dev/hda4 umount /dev/hdc4 swapon /swapfile fsck -fay / fsck -fay /dev/hda4 fsck -fay /dev/hdc4 swapoff /swapfile sync " My problem is with Quote: use hyperterminal to get to a shell prompt with either a Q or a Ctrl-C command
. When I power on the empeg in Hyperterminal, it goes through a whole bunch of stuff then pauses for a while after the following:
empeg-pump v0.03 (19980601) Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly. change_root: old root has d_count=1 Trying to unmount old root ... okay Freeing unused kernel memory: 4k initempeg init 0.8 I see this is a developer image! Mounting proc Mounting first music partition Tried to mount /dev/hda4 as reiserfs but got error 19 Mounting second music partition Tried to mount /dev/hdc4 but got error 6 Error mounting partitions (possibly already mounted) Remounting first music partition read-only Remounting second music partition read-only No secondary hard disk Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player Hijack: intercepting config.ini
khttpd: listening on port 80 kftpd: listening on port 21 player.cpp : 385:empeg-car 2.00 2003/04/01. ! tags.cpp : 61:Failed to open tags (0xc0041002).
It sits there while the empeg shows "Building Music database...". After its done churning through that, all of this scrolls:
ne - block = 1369660252, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only P E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo R Remounting filesystem read-onlyXT2-fs error (d change_root: E ne - block = 639504056, count = 1 ext2_free_blocks: Freeing blocks Remounting filesystem read-onlyly F E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozo empeg di R R Remounting filesystem read-only EXT ne - block = n ne - block = 3780988088, count = 1: ext2_free_blocks: Freeing blocks Remounting filesystem read-onlylyunt /dev/hda4 as reiserfs b E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozomusic partiti R R Remounting filesystem read-onlyied to mount /dev/hdc4 but n ne - block = 2073931063, count = 1: ext2_free_blocks: Freeing blocks Remounting filesystem read-onlyly
EXT2-fs error (device ide0(3 ne - block = 77788820, count = 1locks not in datazofs warning (d Remounting filesystem read-onlyonlybit already cleared for blc EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazoing filesystem read-onlyT2-fs warning (device ide0( EXT EXT2-fs error (device id ne - block = 1183085125, count = 1 blocks not in datazo Remounting filesystem read-onlyonlyk 2506924 = 1s not i EXT2-f EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazoing filesystem read-onlyem read-only EXT EXT2-fs error (device id ne - block = 1970661025, count = 1 blocks not in datazo2_free_blocks Remounting filesystem read-onlylyly EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in dmounting filesystem read-onlyt2_fr
Remounting filesystem read-onlyread-only E E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazoks not in dataz R Remounting filesystem read-only n E ne - block = 3521271761, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only ne - block E E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo Rem R R Remounting filesystem read-only n n ne - block = 2683314856, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only
EXT2-fs error (device ide0(3 ne - block = 95488133, count = 1locks not in datazo Remounting filesystem read-onlyonlyXT2-fs error (device ide0 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazog filesystem read-onlyly E EXT2-fs error (device ide0 ne - block = 3490082962, count = 1locks not in datazozo EX Remounting filesystem read-onlyonly E EXT2-fs err EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazog filesystem read-onlyly E EXT2-fs error (device ide0 ne - block = 268960908, count = 1blocks not in datazozo read-only Remounting filesystem read-onlyonlyly-f E EXT2-fs error EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in danting filesystem read-onlyonly
EXT2-fs error (device ide0(3 ne - block = 4116582678, count = 1cks not in datazoilure, inode= Rem Remounting filesystem read-onlydevice ide0(3,4 EXT EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazofilesystem read-only attempt to acc EXT EXT2-fs error (device ide0(3 ne - block = 2439359762, count = 1cks not in datazo98568, limit= Rem Remounting filesystem read-onlyfs error (devic dev 03:04 b EXT EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazofilesystem read-only E EXT EXT2-fs error (device ide0(3 ne - block = 1545604363, count = 1cks not in datazo3924, blo Rem Remounting filesystem read-only not in datazozoext2_free n EXT EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not inting filesystem read-onlyly attempt to access beyo
E EXT2-fs error (device ide0(3,4 ne - block = 2392889827, count = 1s not in datazozo EXT2-fs erro Rem Remounting filesystem read-only058887 error (devic Remount n n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazosystem read-onlyonly EXT2-fs error (device ide0(3,4)) ne - block = 1668131274, count = 1not in datazotazo(3 dev 03:04 Rem Remounting filesystem read-onlytor=977878112 size=4096 cou ne EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not inng filesystem read-onlyonly
Remounting filesystem read-only EXT2-fs error (device ide n E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazolesystem read-onlyly attempt to access be EXT2-fs error (device ide0(3,4 ne - block = 138890512, count = 1ks not in datazozo92, limit=292 R Remounting filesystem read-onlyly dev 03:04 blk E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazosystem read-onlylylyly ne Remounti EXT2-fs error (device ide0(3,4)) ne - block = 857741224, count = 1 not in datazozozozoblo Remounting filesystem read-onlylyly ide0(3,4)): ext2_free_bl n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in d filesystem read-onlyonlylylyo access beyond en
R Remounting filesystem read-only051324756 sector=-179336544 s n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazolesystem read-onlylyrror (device ide0(3,4)): tr E EXT2-fs error (device ide0(3,4 ne - block = 307517749, count = 1ks not in datazozobloc R Remounting filesystem read-onlyly4756 Remountin n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazolesystem read-onlylylyem read-onlylyle channe 0 EXT2-fs error (device ide0(3,4 ne - block = 38733058, count = 1cks not in datazozozo dev 03:0 Remounting filesystem read-onlyonlylyor=-1492972080 size=4096 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in danting filesystem read-onlyly
n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazofilesystem read-only2_free_blocks: attempt to acc E EXT2-fs error (device ide0(3 ne - block = 149002288, count = 1ocks not in datazo16809220, limit Remounting filesystem read-onlyly dev 03:04 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazog filesystem read-only2_free_blocks: Freeing bloc E E EXT2-fs error (device ide0 ne - block = 2950965806, count = 1locks not in datazode=33924, bloe Remounting filesystem read-onlyly_bl n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in ounting filesystem read-only2_ attempt to access bey
R Remounting filesystem read-only43168168 sector=-1844589248 s n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazolesystem read-only324296, limit=292194004)): trun EXT2-fs error (device ide0(3,4 ne - block = 2742038219, count = 1s not in datazoor=874648584 size=4 Remounting filesystem read-only168 Remounting E n EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazostem read-only33924, blo_free_blocks: Freei 0 EXT2-fs error (device ide0(3,4)): ne - block = 3241216623, count = 1t in datazozotaz Remounting filesy Remounting filesystem read-only87655512 size attempt to ne - EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not inilesystem read-onlyit=2921940
ne - block = 723786398, count = 1ocks not in datazofailure, inode= Remounting filesystem read-onlylyvice ide0(3,4)): trunc_indire EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazog filesystem read-onlytheir peace ck=934369330 to a E EXT2-fs error (device ide0 ne - block = 2294270980, count = 1locks not in datazoccess beyond en Remounting filesystem read-onlylyg ker 03:04: rw=0, EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazog filesystem read-onlyknr=1972513357 sector=-13997623 EXT2-fs error (device ide0 ne - block = 570896936, count = 1blocks not in datazo24, blormk5-n Remounting filesystem read-onlyonly): trunc_indirect: Read fai EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in dmounting filesystem read-only=1972513357s beyond
ne - block = 4227801764, count = 1: ext2_free_blocks: Freeing blocks Remounting filesystem read-only error (device ide0(3,4)): tr E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozompt to access Rem Remounting filesystem read-only927 Remounting n ne - block = 13656210, count = 1)): ext2_free_blocks: Freeing bl Remounting filesystem read-onlylylyly6 blocknr=-849050432 se 0 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozozozo dev 03:04 bl Remounting filesystem read-onlytor=-1701266504 size=4096 cou ne - block = 1496725764, count = 1: ext2_free_blocks: Freeing blocks Remounting filesystem read-onlyly EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazoure, inode=3392 Remounting filesystem read-onlylying (device ide0(3,4)): ext2_ E ne - block = 258059197, count = 1xt2_free_blocks: Freeing blocks n Remounting filesystem read-onlyly empeg ds attempt to access EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozo7212, limit=292 Remounting filesystem read-onlyly dev 03:04 blk ne - block = 3043552778, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-onlylyatazopport initialised 0089 E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozo, blo= 1RDS Remounting filesystem read-onlyd-onlyting filesystem read-only EXT ne - block = 3932087956, count = 1_free_blocks: Freeing blocks not i Remounting filesystem read-onlylypt to access beyond
Remounting filesystem read-onlyice EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozomp v0.03 (199
Remounting filesystem read-only898343646 sector=1403185424 siz ne - block = 1016325510, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-onlyrror (device ide0(3,4)): trunc_ EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozo ... okay R R Remounting filesystem read-only3646g unused kern Remounting fi ne - block = 3361360183, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-onlyly 03:04 EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo dev 03:04 blksiz Remounting filesystem read-only772886624 size=4096 count=1XT2- ne - block = 3533759290, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only ne - block = 1609920600, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazofailure, inode=33 Remounting filesystem read-only E n ne - block = 2518017916, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only attempt to EXT2- EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo8119988, limit=29 Remounting filesystem read-only
dev 03: ne - ne - block = 4109743380, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-only EXT2- EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo24, blo Rem R R Remounting filesystem read-onlyrocessor: Intel StrongA E ne - ne - block = 4294966215, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-onlyempt to access beyond
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo10000 (irq = R Remounting filesystem read-only7y Remounting filesy E ne - block = 270608015, count = 1xt2_free_blocks: Freeing blocks n Remounting filesystem read-onlylyng blocks not in datazo = 1 E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazozock = 499007626, Remounting filesystem read-onlylytom anima Remounting filesyst ne - block = 3187124226, count = 1ext2_free_blocks: Freeing blocks n Remounting filesystem read-onlylystom logo.
Remounting filesystem read-only74kB Cache, CHS=58140/16/63 E EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazoized Str R Remounting filesystem read-onlyvision 0x3349ce ide0(3,4)): e E ne - block = 42656903, count = 1: ext2_free_blocks: Freeing bloc Remounting filesystem read-onlylyly ne - block = 4204003876, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 3202909070, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 2700158126, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 1389728126, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 603594077, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 702078994, count = 1 Remounting filesystem read-only EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo ne - block = 4206532110, count = 1 Remounting filesystem read-only Kernel panic: EXT2-fs panic (device ide0(3,4)): load_block_bitmap: block_group > = groups_count - block_group = 131071, groups_count = 223
Sorry if that was too much info. My problem is that at no time can I get "q", "Ctrl-C" or "Ctrl-Break" to work. I can enter the commands but nothing happens. After that last chunk of text scrolls by, it just hangs there. The player shows "Building playlist database..." and I can't get HyperTerminal to respond to any commands. I hit q (enter) and it just shows a q on the screen, Ctrl-Break shows up as ^@.
Did I overlook some small step? Am I entering the commands into Hyperterminal the wrong way? I've never really used the program or had any issue like this before so it is unfamiliar terrirtory.
thx for the help.
#255492 - 13/05/2005 16:39
Re: Empeg Problem
[Re: visuvius]
Your problem is clearly much larger than a database rebuild now.
There is either hardware trouble, or your file system is severely messed up to the point where you can't even get a shell prompt.
You might be down to a nuke-and-pave at this point. Which, of course, won't do any good if the trouble is hardware.
#255493 - 13/05/2005 17:03
Re: Empeg Problem
Aww maaan. How the heck did I do this? From simply unplugging during a synch? If so that sucks. I really don't want to do any further damage and think I might have to send this in for repairs.
#255494 - 13/05/2005 17:56
Re: Empeg Problem
[Re: visuvius]
Another possibility is that you're simply not using Hyperterminal properly or it's set up wrong. For example, if the flow control is set wrong, you probably won't be able to do the Ctrl-C.
It's also possible that you're not pressing Ctrl-C soon enough.
#255495 - 13/05/2005 20:56
Re: Empeg Problem
woohoo.  Well I tried it one more time after lunch, but this time i spammed Ctrl-C. I was able to follow the instructions and a couple of synchs later we're in buisness. Thanks for your help and a great faq.
#255496 - 13/05/2005 22:25
Re: Empeg Problem
[Re: visuvius]
Ah, cool. Welcome. Glad you got it all fixed.
