I was finishing a small syncronization when it failed. Now when my system powers on it gets stuck at the 'Building Music Databases..' screen and sits there.
Here is the bootlog..
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v355 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Sat Jan 17 08:49:36 EST 2004
empeg-car player (hardware revision 7, serial number 80000506)
Command line: mem=12m
Memory: 10960k/12M available (976k code, 20k reserved, 328k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x99380
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005f80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DISK drive
hdb: TOSHIBA MK3017GAP, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
hdb: TOSHIBA MK3017GAP, 28615MB w/0kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:10:01:f
a
Partition check:
empeg-pump v0.03 (19980601)
change_root: old root has d_count
empeg-preinit starting...
no /etc/preinit.d
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 741303692, count = 1
Remounting filesystem read-only
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 77260629, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3058524944, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3441024729, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3306893678, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3783874232, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3571661227, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4071233053, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1502258429, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4035187407, count = 1
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for block 122
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 575762003, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2483811584, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 606257696, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 669155846, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1724939990, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 962957291, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2723976511, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2709868630, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 967272756, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 97758202, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3033454255, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2325850392, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1236849446, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3876792741, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 977685435, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 799298804, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3755490225, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3034084740, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3524514878, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1250527015, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3038024858, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2862387962, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 829839319, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3798571922, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4057346782, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4046060553, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1463941338, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2626853730, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4227804527, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2164159634, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1567028228, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4064938475, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3428565277, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1410738493, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2893128689, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2345151397, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4134841864, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1145350552, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 855765404, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 713987330, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2433387852, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1080124042, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1785257394, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 508018013, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1313663686, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1238513048, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1897105152, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3773928630, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2920216562, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4074630337, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4072536955, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 180557902, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2187302257, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3108588202, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2484029992, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1926302028, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 713998993, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3978779918, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3704528862, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1969469842, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2514711923, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1990048613, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1235422706, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 390951554, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3557667179, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 948839439, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1948233615, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3932358294, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2984661836, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2381067511, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4092717811, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1211363602, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1187329770, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1746670127, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1659007888, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1871196113, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3703418351, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3604820751, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 456438106, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3089060334, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 790954854, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3687813641, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1197882555, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1844126353, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 293683027, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 832927679, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3754279754, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 4113574581, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 491037486, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 885097996, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 326102573, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1371900300, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 223941073, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2311177822, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 291670875, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1047868438, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2822496476, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3126563844, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 2709996223, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 1972281131, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 876203836, count = 1
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazone - block = 3425604981, count = 1
Any ideas on how to fix this??
