#243685 - 09/12/2004 15:34 Info on digital boards?
Ladmo
Loc: Oklahoma
I was wondering what advantage the digital output boards give the user? I see posts on these pop up on the board, and have seen them for sell from Eutronix, but if someone could explain it (and use small words, as I AM a conservative!) I would very thankful!
thanks
Ladmo
#243686 - 09/12/2004 17:37 Re: Info on digital boards? [Re: Ladmo]
mtempsch
Potential to use a even more high end D/A (digital to analog) converter than the one built into the empeg, or direkt into an amplifier with digital inputs (hopefully containing a good D/A) lessening/eliminating problems with induced noise in RCA-cables and or ground loop noise as digital sigals are less susceptible to noise (or rather, easier to reshape back to original shape/interpret correctly even though there's some noise)
#243687 - 10/12/2004 01:35 Re: Info on digital boards? [Re: Ladmo]
If you don't own an amplifier with a digital input, none at all.
#243688 - 10/12/2004 05:32 Re: Info on digital boards? [Re: tfabris]
genixia
Nonsense. There's always Bragging Rights(tm).
#243689 - 10/12/2004 06:23 Re: Info on digital boards? [Re: tfabris]
or don't own a better D/A converter...
#243690 - 10/12/2004 08:41 Re: Info on digital boards? [Re: Ladmo]
Happy Birthday bonzi
I think that elimination of ground loops alone makes the digital out worth it.
#243691 - 10/12/2004 10:00 Re: Info on digital boards? [Re: Ladmo]
crazymelki
Loc: Switzerland
hi,
I am using since a cupple of month the optical output of the Eutronix board in my car together with the DSP 5800 form XETEC. There is no more ground loop comming out from your speaker.
But you still need the RCA cable for the tuner. This does not work over the optical connector.
You will find the Tohuwabohu in the attachment.
bye
