#24314 - 08/01/2001 00:10 explorer cut/paste bug ?
amold
When I copy and paste files from explorer (on win2k), emplode always switches the first and last file in the selection. Is this a known bug ?
Also, when I'm dragging and dropping files in a playlist, to change the order, I don't see a way to scroll while dragging. I have to drag a file to the top/bottom, scroll the window, then drag it the rest of the way. am I doing something wrong ?
#24315 - 08/01/2001 04:35 Re: explorer cut/paste bug ? [Re: amold]
Yes. Windows does strange things with the ordering. Simple answer, select the first file, shift-select the last file, and then drag the first file into emplode. Usually works.
No. This is a bug. It should be fixed in v1.1
#24316 - 08/01/2001 09:15 Re: explorer cut/paste bug ? [Re: Roger]
phaigh
If you've got a mouse with a wheel, you can use the mouse wheel to scoll up whilst still holding down the left button to drag. Well, it works for me anyway.
Paul.
Paul Haigh, Reg. 4120
(mk1) 6GB, Blue, 00254
(mk2) 12GB, Red, 00357
Paul Haigh, Reg. 4120 (mk1) 6GB, Blue, 00254 (mk2) 12GB, Red, 00357
#24317 - 08/01/2001 09:41 Re: explorer cut/paste bug ? [Re: phaigh]
NEAT TRICK!
This should tide me over until 1.1. (That particular problem has bothered me for a while.)
Dionysus, stick that one in the tips-n-tricks FAQ.
#24318 - 09/01/2001 07:39 Re: explorer cut/paste bug ? [Re: tfabris]
phaigh
Thanks.
I found this by mistake actually - I'm a bit ham-fisted with my mouse (except during Q3 sessions)!
Paul.
