#23895 - 26/12/2000 02:20 telnetd works only whren rw mounted ?
Happy Birthday Janosch
Loc: Berlin, Germany
Hi all,
yesterday i played a little bit around with my empeg an i love it more with every second i use it. FTP and the displayserver
are now working fine.
The only Problem is telnted. It just works fine as soon as i mounted the Partition read-write (command rw). If not
i get the following message when i try to connect :
"telnetd: getpty: Exec format error"
Has anyone got around this ? Again just typing rw and hitting
enter fixes this until the next reboot.
It ist also not possible to do more then one telnet session at the same time..... i created about 5 gtpy devices including the gtpyx device like described in the devices.txt file i found.
Same i did for the tty's. Any hints ?
Best regards
Janosch
....Loving his Empeg
#23896 - 26/12/2000 18:02 Re: telnetd works only whren rw mounted ? [Re: Janosch]
SuperQ
Loc: Berlin, DE
hrm.. I don't know how you have your telnetd setup.. i assume the folowing.. you started a telnetd alone, without inetd.. that meens you will only get one telnet session.. telnetd may also be trying to write other files on the disk, or change permissions/user info on the pty's
12gig red mk2 -- 080000125
80gig red mk2 -- 080000125
#23897 - 27/12/2000 03:43 Re: telnetd works only whren rw mounted ? [Re: Janosch]
fvgestel
Loc: Netherlands
I have a workaround for this :
- install inetd
- configure telnetd and rshd
- add an entry for root in the passwd file with homedir /root
- create a file /root/.rhosts with the ip of yout home PC
Now you can do a rsh commmand to mount the rootfs rw :
# rsh empeg rw
# rlogin empeg
or without mounting rw :
# rsh empeg /usr/X11R6/bin/xterm -display `echo $DISPLAY`
Frank van Gestel
Frank van Gestel
#23898 - 27/12/2000 08:40 Re: telnetd works only whren rw mounted ? [Re: fvgestel]
dionysus
Loc: San Francisco, CA
...my workaround was to make the "quit" command rw the disks... problem was remembering to r/o them afterwards ;p
...proud to have owned an Empeg since 00287
