#238094 - 18/10/2004 17:10 Completely useless... ASCII Art converter with color
A completely useless but fun ASCII Art Converter.
Unfortunately, it uses "color=" instead of "color:", so a quick search-and-replace is required before it works on this particular BBS.
888888888888888888888888888888888888888888888888888888888888888888888888888
8
8
8
8
8
8
8
8
88
88
88888888888
8888888888888888888
8888888888888888888
#238095 - 18/10/2004 17:13 Re: Completely useless... ASCII Art converter with color [Re: tfabris]
heh. Cool. That's a pretty good pic of the empeg you know
#238096 - 18/10/2004 17:43 Re: Completely useless... ASCII Art converter with color [Re: tfabris]
Aww. It ought to be using different characters and different colors. What's wrong with them?
#238097 - 18/10/2004 17:46 Re: Completely useless... ASCII Art converter with color [Re: wfaulk]
It can do either. I chose to use all the same character and only vary the colors. You could also do just characters, or both characters and colors.
#238098 - 18/10/2004 17:53 Re: Completely useless... ASCII Art converter with color [Re: tfabris]
Nah, it seems to just be using said characters randomly. It ought to be using them based on the amount pixels they produce as well as the location of said pixels. Old-school B&W-only ones do that properly. Actually, it does it that way when you select "ASCII" mode, but not when you select colored mode. Weird.
#238099 - 18/10/2004 17:55 Re: Completely useless... ASCII Art converter with color [Re: wfaulk]
No, it's not random, it works the way you expect. Here is the same picture as ASCII characters only. Not as cool looking, but here it is...
,,,,,,,,,,,,,,,,,,,,,,,;;titjiii;;;ittttt;;;,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,
,,,,::::::::::ittjLLGDDDDDWWWWDDDDDDEEEEEEEEEEDDWWWWWDWGLLffjjjjjtttti,,,;,
,;;;;,,,,,,,,,;;;;iittjjjffffffffLLLGGGGGWDDDDEEEDDDDDDWWWWWWWWWWWWWWGLLLL,
,;;;;;,,,,,,,,::::::,,,,;;;;iiiiittjjjjjjttttjjjjjjjjfffffffLLLGGGGGGGWWWf,
,,i;,,GGt:....................::::::::,,;iiitjjjjjjjjjjttttttttfjGWWDWWDWj,
,,::,;jjt;:,,:.:.::,,,,,,;;;,,,,,,,,,,,::,;;,::::,;;ittttjtttttfjDDDDDWDGt,
,,iiGWWGWWLtt:.::,,,,,,,;Lttftjiittiii;;,,,;ii;:::::.:,i,tjtiiitjDEEEEDGLi,
,,,;ijjLLt;:.....:,,,,,;;LjfjiLtfjtftiiii;,,:;jj;:::::.:,,ii;;;ifEEDEEELG,,
,,::,;tGGii;;,,:.:::::,,;i;tt;jijjtLjiiiii;,::,tjti;,:::..:,,;;;fEEEEEWGD,,
,,::,,:tt::,,;tjjti;;,::::::::,,,,;;;;;;;;;::;GEEKKDGj;:...::,;iLEEEEEWt,,,
,,,,:::::::,,,,,;;;itjjtii;;;,,:::::::,,,,:::GDDWDEKKft:..::::;iGEEEEL,,,,,
,,,,,,,,,,,,,::::,;,:::,,;iittjjjtttiii;;,,::LEEDDDEKfi,;ii,::;iWDDfi,,,,,,
,,,,,,,,,,,,,,,,,,,,,,,,:::::::,,;iiittttttiitLWDDDGf;iiii;,::;iWGi,,,,,,,,
,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,::::,,:::::::::::,,;,,,,,;it;:::;;;,,,,,,,,,,
Edit: Oh I see what you're saying. When you combine color and ASCII, it's not doing the same thing as it did when it was just ASCII. Hm.
#238100 - 18/10/2004 17:59 Re: Completely useless... ASCII Art converter with color [Re: tfabris]
Thinking about it, I understand conceptually why they do it that way. When in colorized mode, each character is merely a pixel, and the character color governs the value. When in ASCII mode, each character is a brightness value. There's no way to combine both without deliberately throwing away the usefulness of assigning each pixel a color.
#238101 - 18/10/2004 18:05 Re: Completely useless... ASCII Art converter with color [Re: tfabris]
Not true.
