#227717 - 18/07/2004 00:14 Mk2a lockup with newer hijack installed
Micman2b
Loc: Central, NC, USA
I have a Mk2a that I got a memory upgrade for and when I try to load any of the newer hijack kernel the player locks up on reboot. If I downgrade to a version that has no memory support the player works great.
Any suggestions on how to fix this?
Boot Log...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v400 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Sat Jul 17 12:06:01 EDT 2004
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 10102049) 32MB DRAM
Command line: mem=16m
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
TCP: Hash tables configured (ehash 32768 bhash 32768)
Starting kswapd v 1.5
Signature is 67706d65 'empg'
empegr_state_restore: FAILED
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: FUJITSU MHR2030AT D, ATA DISK drive
hda: FUJITSU MHR2030AT D, ATA DISK drive
hda: FUJITSU MHR2030AT D, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHR2030AT D, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:08:01
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
Timezone: /usr/share/zoneinfo
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump... VFS: Mounted root (ext2 filesystem) readonly.
Freeing unused kernel memory: 4k initTimezone: /usr/share/zoneinfo/Atlantic/South_Georgia
Unable to handle kernel paging request at virtual address 00005c08
memmap = C0004000, pgd = c0004000
*pgd = c012f801, *pmd = c012f801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c0036508>] lr : [<c00354f0>]
sp : c01f7f98 ip : c01f7fb4 fp : c01f7fb0
r10: c0008580 r9 : 4401a11b r8 : c0100988
r7 : c0108794 r6 : c01040c0 r5 : 00000000 r4 : 00005c00
r3 : 00000000 r2 : 00000000 r1 : c01f7fb0 r0 : 00000000
Flags: nzcv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 0000001D
Process kupdate (pid: 3, stackpage=c01f7000)
Stack:
c01f7f80: c00354f0 c0036508 00000013 ffffffff 00000001 c01f6000
c01f7fa0: c0104024 c01f7fe0 c01f7fb4 c00354f0 c00364ec 00000000 00000001 c01f6000
c01f7fc0: c0104024 c0108794 c0100988 4401a11b c0008580 c01f7ffc c01f7fe4 c0035bd4
c01f7fe0: c00354e4 c0035b64 c012b84c c0100760 c0003fb4 c01f8000 c000b6ec c0035b70
Backtrace:
Function entered at [<c00364e0>] from [<c00354f0>]
r6 = C0104024 r5 = C01F6000 r4 = 00000001
Function entered at [<c00354d8>] from [<c0035bd4>]
r10 = C0008580 r9 = 4401A11B r8 = C0100988 r7 = C0108794
Function entered at [<c0035b64>] from [<c000b6ec>]
r6 = C0100760 r5 = C012B84C r4 = C0035B64
Function entered at [<02009bcc>] from [<02009bd4>]
Unable to handle kernel paging request at virtual address 02009bd0
*pgd = 00000000, *pmd = 00000000
CPU: 0
pc : [<c00e338c>] lr : [<c0019870>]
sp : c01f7e90 ip : c01f7e4c fp : c01f7ecc
r10: c00e8110 r9 : c01006e8 r8 : 0000000c
r7 : 00000000 r6 : 02009bcc r5 : bffffd54 r4 : c0003fb4
r3 : 60000093 r2 : c0102284 r1 : 00000001 r0 : c0003fa4
Flags: nZCv IRQs off FIQs on Mode SVC_32 Segment kernel
Stack:
c01f7e80: c0019870 c00e338c 60000093 ffffffff c01f7fb0 c01f7f98 00000001 c01f7f50
c01f7ea0: c01f6000 c00104dc 00005c08 c01f6000 c01006e8 00000002 c01f7f50 00000002
c01f7ec0: c01f7ef0 c01f7ed0 c00118ac c0010374 c01f7f50 00000007 c01f6000 c01f7f50
c01f7ee0: 00005c08 c01f7f28 c01f7ef4 c0011b64 c001184c c01006e8 00000000 00000000
c01f7f00: c01f7f50 00000007 00005c08 00000003 00000002 00000013 c0008580 c01f7f4c
c01f7f20: c01f7f2c c0012060 c00118d8 ffffffff c01f7f84 c01040c0 c0108794 c0100988
c01f7f40: c01f7fb0 c01f7f50 c0009e48 c0011f88 00000000 c01f7fb0 00000000 00000000
c01f7f60: 00005c00 00000000 c01040c0 c0108794 c0100988 4401a11b c0008580 c01f7fb0
c01f7f80: c01f7fb4 c01f7f98 c00354f0 c0036508 00000013 ffffffff 00000001 c01f6000
Backtrace:
Function entered at [<c0010368>] from [<c00118ac>]
r10 = 00000002 r8 = C01F7F50 r7 = 00000002 r6 = C01006E8
r5 = C01F6000 r4 = 00005C08
Function entered at [<c0011840>] from [<c0011b64>]
r8 = 00005C08 r7 = C01F7F50 r6 = C01F6000 r5 = 00000007
r4 = C01F7F50
Function entered at [<c00118cc>] from [<c0012060>]
r10 = C0008580 r9 = 00000013 r8 = 00000002 r7 = 00000003
r6 = 00005C08 r5 = 00000007 r4 = C01F7F50
Function entered at [<c0011f7c>] from [<c0009e48>]
r8 = C0100988 r7 = C0108794 r6 = C01040C0 r5 = C01F7F84
r4 = FFFFFFFF
CPU: 0
sp : c01f7d88 ip : c01f7d44 fp : c01f7dc4
Stack:
c01f7d60: c0019870 c00e338c
c01f7d80: 60000093 ffffffff c01f7ecc c01f7e90 00000001 c01f7e48 c01f6000 c00104dc
c01f7da0: 02009bd0 c01f6000 c01006e8 00000002 c01f7e48 00000002 c01f7de8 c01f7dc8
c01f7dc0: c00118ac c0010374 c01f7e48 00000005 c01f6000 c01f7e48 02009bd0 c01f7e20
c01f7de0: c01f7dec c0011b64 c001184c c01006e8 bffffd54 c01127a3 c01f7e48 00000005
c01f7e00: 02009bd0 00000003 00000002 60000093 c00e8110 c01f7e44 c01f7e24 c0012060
c01f7e20: c00118d8 ffffffff c01f7e7c 02009bcc 00000000 0000000c c01f7ecc c01f7e48
c01f7e40: c0009e48 c0011f88 c0003fa4 00000001 c0102284 60000093 c0003fb4 bffffd54
c01f7e60: 02009bcc 00000000 0000000c c01006e8 c00e8110 c01f7ecc c01f7e4c c01f7e90
Then it goes like this for days/hours....
Sean in NC
Edited by Micman2b (18/07/2004 00:38)
#227718 - 18/07/2004 00:27 Re: Mk2a lockup with newer hijack installed [Re: Micman2b]
genixia
Boot log is needed, otherwise we are just guessing.
#227719 - 18/07/2004 10:51 Re: Mk2a lockup with newer hijack installed [Re: Micman2b]
Time to go over all of the new solder joints again. One or more of them is bad.
