#222973 - 28/03/2003 23:47
New server software: Rio Grande
Loc: California
I've taked Jeff Mock's code, cleaned up it, organized it, added documentation, and put it here: http://homepage.mac.com/pauljlucas/software/rio_grande-0.9.tar.gzThe complete set of changes is: - Reorganized the directory structure:
(a) Moved CGIs to a cgi-bin directory. (b) Moved the database out from under the web server's document root. (c) Moved non-CGI (e.g., ssdp) code out from under the web server. - Rewrote all CGIs majorly cleaning up the code.
- Playlist support has been added to the CGIs.
- Half of the "favourites" Rio request has been implemented: the Rio can now request "/favourites/all" and get the contents of a plain text file back.
- The "build" CGI has been rewritten as a command-line program and also:
(a) Now builds playlist files from directory names. (b) Colons are now allowed in track names. (c) Added optional warnings. - The "ssdp" daemon has been cleaned up and also:
(a) Now takes command-line options. (b) If started as root, gives away its root privileges. (c) Added proper setting of SO_REUSEADDR socket option. (d) Can now alternatively run under (x)inetd. (e) Logging is now optional. - Added sample a dhcpd.conf, a (correct) httpd.conf, an NFS exports, inetd.conf, and xinetd files.
- Removed the web interface. (Sorry, I don't care about it. I edit my MP3 files' ID3 tags using other software anyway, e.g., Apple's iTunes.)
Suggestions (including a better name) welcome.
- Paul
#222974 - 29/03/2003 09:12
Re: New server software: Rio Grande
[Re: pauljlucas]
If you give that a page I can link to (I don't see it on http://homepage.mac.com/pauljlucas/software for example), I'll add it to the FAQ entry about third-party servers.
#222975 - 29/03/2003 09:30
Loc: California
A web page is coming (as soon as I can think of a nifty graphic logo for the top ![](/images/icons/wink.gif) I'd also really like to think of a better name. I don't like the one it has now, but I needed to call it something. The only other thing I've thought of is YARS: Yet Another Rio Server.
- Paul
#222976 - 31/03/2003 08:55
[Re: pauljlucas]
I'd also really like to think of a better name. Deriode? Deriosion? Derion? Riodicule? Cariocature?
Ooh! Spurious!
(If you can't tell, which is likely, I'm finding similar words to ``mock'' and forcing ``rio'' into them.)
#222977 - 31/03/2003 09:47
[Re: pauljlucas]
I still think we should have called the Central "Rio Grande".
#222978 - 31/03/2003 15:57
[Re: pauljlucas]
When I finally finish writing (on my own time) my replacement Rio server (to atone for my sins writing the stock one), I'm thinking of calling it ARSE (Another Rio Server), but I can't figure out what the E should stand for...
#222979 - 31/03/2003 16:32
[Re: Roger]
Effort ?
#222980 - 31/03/2003 22:18
[Re: Roger]
When I finally finish writing (on my own time) my replacement Rio server...
I really have only one wish for the Rio Receiver right now, and unfortunately, it would need to be a combination client/server code change. It would also have to be implemented server-side on the Jupiter, because that's the server I'm using.
It's the simple feature of saving the receiver's settings across a power loss. We lose electricty here, briefly, several times a month. Each time, I have to fiddle with the receiver to reset the bass and treble, turn on shuffle/repeat, and select a playlist. This sounds simple, except for the fact that I don't always know the power has screwed up the receiver when I just want to turn it on and listen to it. The times when this happens, I'm either at the dining room table in the middle of a meal, or I'm in the hot tub, and I'm using the remote. So having to get up, walk to the receiver, and peer at the display to reset it is a Big Deal in those situations.
If it weren't for that little problem, the receiver would be essentially a zero maintenance music player, a true "appliance". As it stands right now, that problem makes it continue to be a fiddly little computer-type gadget that "crashes" sometimes, instead of an appliance.
#222982 - 31/03/2003 22:21
Sounds like you really need a UPS Tony...
#222983 - 31/03/2003 23:24
Rio Grande --> YARRS
[Re: pauljlucas]
Loc: California
- Paul
#222984 - 01/04/2003 00:51
That's why the Rio Receiver is supposed to send "State!" packets to the server every now and then. When it boots, it's supposed to send a "State?" packet to the server to retrieve its state. I don't recall whether everything that you want to store would have been passed in those packets, though.
As I recall, we didn't get around to actually implementing it, and the "third party OEM" weren't that bothered about it.
#222985 - 01/04/2003 05:57
[Re: Roger]
Do you have any plans to extend the existing protocol?
It'd be really cool if you could do stuff like list all the albums for a particular artist.
Paul
Paul
(the tRio guy)
#222986 - 01/04/2003 06:12
Re: Rio Grande --> YARRS
[Re: pauljlucas]
Oops sorry, that post of mine should have been in reply to Paul, not Roger.
Paul
(the tRio guy)
#222987 - 01/04/2003 10:17
[Re: pauln]
Loc: California
I can't extend the protocol since that's detemined by the client.
- Paul
#222988 - 01/04/2003 10:47
[Re: pauljlucas]
It shouldn't be too difficult to alter the replacement clients (RRR, RioPlay and tRio) to support new stuff though. If it's done the right way, you'd still be backwardly compatible with the original clients - they'd just not make use of the new calls.
Paul
(the tRio guy)
#222990 - 01/04/2003 14:54
Client-side software
[Re: pauln]
Loc: California
Well, that presupposes I have an interest in writing client-side software. Currently I don't; but even if I did, I don't have that kind of time right now.
I'm fairly happy with the stock client player. My only complaint is that, when I select a track to play, the Rio plays it and stops. What I really want is it to play from that track forward (just like my CD player currently does).
- Paul
