#21313 - 30/10/2000 02:27 duplicate default route
fvgestel
Loc: Netherlands
I don't know if this is a bug or not, but here is the situation.
I'm using a coax network at home with some sun's hp's and my linux server in the attic. On this coax network there's a coax repeater which has an aui port, where I connect an UTP cable which leads to my win2k workstation in the living room. To connect the empeg to the network, I've setup a sun sparcstation 5 running solaris 7 to act as a router between my internal network (192.168.11.0/255.255.255.0) and the empeg (130.144.236.0/255.255.255.0)
The empeg's IP-address is 130.144.236.58
I chose this IP-address because it is the same at work and DHCP doesn't work there.
When I restart player at work there isn't a problem.
When I restart player at home, a second default route is added and the empeg loses it's connections made to hosts outside the 130.144.236 network
output before restart :
empeg:~# netstat -rn
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
130.144.236.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
0.0.0.0 130.144.236.1 0.0.0.0 UG 0 0 0 eth0
output after restart :
0.0.0.0 0.0.0.0 0.0.0.0 UG 0 0 0 eth0
Does the player do some kind of route-detection (OSPF) when it is started up ?
here's the IP-section in config.ini :
[Network]
Gateway=130.144.236.1
Netmask=255.255.255.0
IPAddress=130.144.236.58
DHCP=0
Frank van Gestel
Frank van Gestel
#21314 - 30/10/2000 02:45 Re: duplicate default route [Re: fvgestel]
fvgestel
Loc: Netherlands
with restarting the player, I mean stopping the player executable and restarting it again...
Frank van Gestel
Frank van Gestel
#21315 - 30/10/2000 12:27 Re: duplicate default route [Re: fvgestel]
wvloon
Loc: Near Arnhem, Netherlands
I noticed the same thing. I'm allmost sure this route pops up when starting & quiting the player. I posted my findings in reply to this post (neigbour table overflow)
Walter
Reg:1934/Mk1:158-6Blue/Mk2:380-12Blue
W@lly.nl ------------------------ Reg:1934/Mk1:158-Blue(sold)/Mk2:380-Amber(sold)/Mk2a:3273-Blue
#21316 - 30/10/2000 16:01 Re: duplicate default route [Re: wvloon]
fvgestel
Loc: Netherlands
I made a bypass by doing an "ifconfig eth0 down" before starting the player again. network-connections stay intact...
Frank van Gestel
Frank van Gestel
