#206079 - 21/02/2004 17:14 Hijack v378: time_offset=xxx removed
Hijack v378 is out.
Two changes:
(1) the config.ini option for time_offset=xxx has been removed, which means some people will get a config.ini error at startup until they remove the use of this defunct option from config.ini.
(2) Hijack now calculates the correct (?) time_offset (for the Hijack clock feature) directly from the zoneinfo data for the currently selected player timezone setting.
#206080 - 21/02/2004 21:08 Re: Hijack v378: time_offset=xxx removed [Re: mlord]
newguy1
Loc: Massachusetts,USA
Don't know if it is related but I upgraded hijack thru jemplode and now I cant synchronize with emplode or jemplode. It fails while checking media.I have been uploading tunes all afternoon and saw this thread about the time zone problem so thats why I upgraded.Good news is it fixed the timezone problem.
MIKE 80Gb RIO
#206081 - 22/02/2004 00:32 Re: Hijack v378: time_offset=xxx removed [Re: newguy1]
It is unlikely to be related to Hijack. Please click here .
#206082 - 22/02/2004 10:17 Re: Hijack v378: time_offset=xxx removed [Re: tfabris]
newguy1
It does'nt actually freeze while checking disk integrity.The error code is 0xc0041010 if that helps.I did have the system check disabled with hijack.I only have the one 30gb drive.
Edit I just tried an older version 301 of hijack and it synchs ok.Then i installed 378 and wouldn't synch correctly.
Edited by newguy1 (22/02/2004 10:47)
MIKE 80Gb RIO
#206083 - 23/02/2004 21:18 Re: Hijack v378: time_offset=xxx removed [Re: newguy1]
newguy1
Ok I think I found the not synching reason.The player has v2.0b13 software but the newer hijacks only work with v2 final.So I upgraded the player to v2 final and then to the latest hijack 378 and it works.
If I want to keep b13 on the player which version of hijack can I use and where do I get it?
MIKE 80Gb RIO
#206084 - 23/02/2004 22:50 Re: Hijack v378: time_offset=xxx removed [Re: newguy1]
I dunno about that.. not that I'd want to use beta13 when v2final is available, but Hijack should work just fine with either version.
#206085 - 24/02/2004 21:23 Re: Hijack v378: time_offset=xxx removed [Re: mlord]
newguy1
Mark,you're right.I installed b13 back on the player along with v378 and it works.What i'm thinking now is that i had Emphatic installed with the original b13 and that it was conflicting with v378.Emphatic worked with v360.It got removed when I upgraded to 2 final and thats why I thought hijack 378 would only work with 2 final.
I haven't tried installing emphatic yet back on the player with v2 final and hj378 to verify this.Anyone else have this setup with emphatic, version2 and hijack 378?
MIKE 80Gb RIO
#206086 - 24/02/2004 21:35 Re: Hijack v378: time_offset=xxx removed [Re: newguy1]
If you were running emphatic and you couldn't synch, that's a known problem that has nothing to do with the version of hijack or the version of emphatic.
The problem is because, if you leave emphatic running and try to synch, the player will be unable to remount the disk drives because emphatic is using the song files and the disk cannot be unlocked. To prevent this from happening, you must run emphatic in DC mode only.
Note that you have probably messed up your drives and they are now in need of a manual FSCK per the FAQ.
#206087 - 24/02/2004 21:42 Re: Hijack v378: time_offset=xxx removed [Re: tfabris]
newguy1
I haven't noticed any problems now.The player synchs and plays fine.Would I notice anything if my drive was messed up?
MIKE 80Gb RIO
#206088 - 24/02/2004 21:54 Re: Hijack v378: time_offset=xxx removed [Re: tfabris]
The first couple versions of emphatic kept files open. v1.10 doesn't, and I had no problems syncing with it running (albeit not in the foreground state when I started the sync.) I don't run it from my music drive, though, and many people do, so maybe that's the difference.
Anyway, I would recommend using a ;@HOME/;@WORK tag instead of ;@AC/;@DC for those who think it's interfering with their syncs but still want to use it in AC mode.
#206089 - 24/02/2004 21:59 Re: Hijack v378: time_offset=xxx removed [Re: newguy1]
Yes. this would happen.
