Here's a really dumb question. How do you get hyperterminal to copy in Windows XP? Sometimes it will and sometimes it won't. Right now it's not.
I've selected all and hit control+c as well as selecting copy in the menu, but there is nothing to paste, even with a screen full of boot log! My only solution has been to be to a W2K computer.
Anyway, here it is:
e000 v1.03
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg43 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.2 19991024 (release)) #214 Sat Jun 23 16:38:57 BST 2001
empeg-car player (hardware revision 9, serial number 40104008)
Command line: mem=16m temp=N90
Memory: 15064k/16M available (960k code, 20k reserved, 332k data, 8k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004500).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:a
8
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 8k initEXT2-fs: ide0(3,4): couldn't mount because
of unsupported optional features.
empeg-car 1.03.
3bb31168 DHCP Our mac is 00:02:d7:28:0f:a8
3bb31168 DHCP Our address is 255.255.255.255
3bb31168 DHCP Broadcast address is 255.255.255.255
3bb31168 DHCP Current IP address is 255.255.255.255
3bb31168 DHCP Sending DHCP discover
3bb31169 DHCP Sending DHCP discover
3bb3116b DHCP Sending DHCP discover
3bb3116e DHCP Sending DHCP discover
3bb31175 DHCP Sending DHCP discover
3bb31184 DHCP Sending DHCP discover
3bb311a3 DHCP Sending DHCP discover
e000 v1.03
Copying kernel...
empeg state support initialised 0089/88c1 (save to d0004580).
8
Partition check:
empeg-car 1.03.
3bb311e5 DHCP Our mac is 00:02:d7:28:0f:a8
3bb311e5 DHCP Our address is 255.255.255.255
3bb311e5 DHCP Broadcast address is 255.255.255.255
3bb311e5 DHCP Current IP address is 255.255.255.255
3bb311e5 DHCP Sending DHCP discover
3bb311e6 DHCP Sending DHCP discover
3bb311e8 DHCP Sending DHCP discover
3bb311ed DHCP Sending DHCP discover
3bb311f8 DHCP Sending DHCP discover
3bb3120f DHCP Sending DHCP discover
3bb3123e DHCP Sending DHCP discover
Player received SIGINT, user interruption
Starting bash.
úShell exit
empeg-car 1.03.
3bb3124b DHCP Our mac is 00:02:d7:28:0f:a8
3bb3124b DHCP Our address is 255.255.255.255
3bb3124b DHCP Broadcast address is 255.255.255.255
3bb3124b DHCP Current IP address is 255.255.255.255
3bb3124b DHCP Sending DHCP discover
3bb3124c DHCP Sending DHCP discover
3bb3124f DHCP Sending DHCP discover
3bb31256 DHCP Sending DHCP discover
3bb31263 DHCP Sending DHCP discover
3bb3127e DHCP Sending DHCP discover
3bb312b4 DHCP Sending DHCP discover
e000 v1.04
Copying kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg51 (mac@aphex) (gcc version 2.95.3 20010315
(release)) #17 Wed Jul 24 18:23:20 BST 2002
empeg state support initialised 0089/88c1 (save to d0004980).
8
Partition check:
Freeing unused kernel memory: 4k init player.cpp : 385:empeg-car 2.00-be
ta13 2002/07/24.
! tags.cpp : 61:Failed to open tags (0xc0041014).
Vcb: 0x4086d000
e000 v1.04
Copying kernel...
l.
empeg state support initialised 0089/88c1 (save to d0004d00).
8
Partition check:
ta13 2002/07/24.
^T^T^TProlux 4 empeg car - 2.1434 Jul 24 2002
Vcb: 0x4086d000
0000 empeg-car (issue9) board test version 0.05 <hugo@empeg.com>
0100 ram test starting
0110 testing ic 1 (0-15mb, low word)
0120 testing ic 2 (0-15mb, high word)
01f0 ram test done
0200 ide detect
0210 command issued
0220 drive id FUJITSU MHL2300AT
02f0 ide ok
0300 dsp/i2c test
03f0 dsp/i2c ok
0400 temperature detect
0410 temperature is 00
04f0 temperature ok
0500 usb detect
0510 usb rev 1012
05f0 usb ok
0600 ethernet detect
0610 ethernet rev 334b
06f0 ethernet ok
0700 cs4231 detect
0710 cs4231 rev a0
07f0 cs4231 ok
00f0 tests complete
e000 v1.04
Copying kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v391 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed May 12 16:43:07 EDT 2004
Checking for extra DRAM:
c1000000: passed.
c1100000: passed.
c1200000: passed.
c1300000: passed.
c1400000: passed.
c1500000: passed.
c1600000: passed.
c1700000: passed.
c1800000: passed.
c1900000: passed.
c1a00000: passed.
c1b00000: passed.
c1c00000: passed.
c1d00000: passed.
c1e00000: passed.
c1f00000: passed.
c2000000: wrote ffffffff, read 00000000
empeg-car player (hardware revision 9, serial number 30102420)
Memory: 31240k/32M available (980k code, 20k reserved, 524k data, 4k init)
Dentry hash table entries: 4096 (order 3, 32k)
Buffer cache hash table entries: 32768 (order 5, 128k)
Page cache hash table entries: 8192 (order 3, 32k)
TCP: Hash tables configured (ehash 32768 bhash 32768)
Tuner: loopback=0, ID=-1
empeg state support initialised 0089/88c1 (save to d0005500).
hda: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:7
4
Partition check:
Timezone: /usr/share/zoneinfo
Freeing unused kernel memory: 4k initTimezone: /usr/share/zoneinfo/Atlantic/Azor
es
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
Vcb: 0x4086d000
