#194001 - 18/12/2003 00:31 C code to find empegs IP
mcomb
Loc: San Carlos, CA
Does anybody have a snippet of C code to find the empegs current IP address (or a reference on how to do this under linux)? I have daapd and a simple multicast dns responder basically working on the empeg. This allows all the mp3s on your empeg to automatically show up as shared files for anyone running iTunes on your local network so people can browse and stream from your collection. It seems to work pretty well, but I want to make it a little more user friendly before I release it.
-Mike
#194002 - 18/12/2003 00:45 Re: C code to find empegs IP [Re: mcomb]
Daria
At minimum you should be able to steal code from ifconfig, since it enumerates interfaces and prints said info.
#194003 - 18/12/2003 02:42 Re: C code to find empegs IP [Re: Daria]
mcomb
Loc: San Carlos, CA
Duh! That would be way to obvious. I dug around and found something that I think will work.
Thanks,
-Mike
#194004 - 18/12/2003 09:42 Re: C code to find empegs IP [Re: mcomb]
You could look at the FindEmpeg source code for how to construct the UDP broadcast packet to search for an empeg. You'll have to excuse the massive unwieldy code though, I hacked it together in about a day or so.
#194005 - 18/12/2003 11:47 Re: C code to find empegs IP [Re: tman]
You guys are talking all Linux/Cygwin, though. My dream would be a self-contained Windows DLL version of FindEmpeg...
I was going to write some VB code to do it as part of EmpegFace, then discovered that the Winsock OCX won't do broadcast packets, and therefore I was down to coding in raw API calls again. So I skipped it...
#194006 - 18/12/2003 12:09 Re: C code to find empegs IP [Re: tfabris]
siberia37
Loc: Tacoma,WA
That would be cool, if I have some extra time over my xmas break (gotta love working in education) I'll try to hack up an ActiveX control to do this. Then you could even make an ASP/PHP web page to find empegs on your network and other fun stuff...
#194007 - 18/12/2003 12:10 Re: C code to find empegs IP [Re: tfabris]
Hmm. I'll have a look at it. It always compiles fine under MinGW.
#194008 - 18/12/2003 12:10 Re: C code to find empegs IP [Re: mcomb]
I hadn't heard of DAAP before. That's well cool. It's a pity all the toolkits seem to be GPL (or Java); if there were a nice BSD-licensed library, and if I had anything to do with it, that stuff would be going in the stock Empeg and Karma firmware.
Presumably Apple decided that UPnP MediaServer was too much like hard work?
Edit: and to answer your question, get an Emptool distribution and look for lib/net/ipaddress.cpp's GetAddressForInterface(), passing "eth0". Or look up SIOCGIFADDR in your nearest W Richard Stevens book.
#194009 - 18/12/2003 12:17 Re: C code to find empegs IP [Re: tman]
mcomb
Loc: San Carlos, CA
Thanks, but I actually needed the opposite. I need to get the ip from a piece of software that actually runs on the empeg.
-Mike
#194010 - 18/12/2003 12:20 Re: C code to find empegs IP [Re: mcomb]
Ohhh. In that case then yeah, get the ifconfig code Or if you can wait, I can dig out the snippet I wrote ages ago that does the same thing.
#194011 - 18/12/2003 12:21 Re: C code to find empegs IP [Re: mcomb]
OH! That's a different thing altogether.
Isn't there something in /proc already? A nice loose file you can just read and parse? Either by default, or via the Hijack kernel?
#194012 - 18/12/2003 12:25 Re: C code to find empegs IP [Re: peter]
mcomb
Loc: San Carlos, CA
It actually looks like it wouldn't be too tough to implement from scratch. You need a multicast DNS responder (I started with this), the actual daapd deamon isn't much more than a webserver.
-Mike
#194013 - 18/12/2003 12:26 Re: C code to find empegs IP [Re: siberia37]
(Siberia)
(Tman)
Hey, cool, guys. Doesn't need to be as complicated as an ActiveX, just a simple DLL with a few exposed functions would be enough. Ideally, you'd want it to (a) automatically find the hosts file on the appropriate system, which is different depending on which windows version your're running, and (b) optionally write the designated hostname/ip to the hosts file, or simply return the requested IP address without writing to the hosts file.
#194014 - 18/12/2003 12:29 Re: C code to find empegs IP [Re: tman]
mcomb
Loc: San Carlos, CA
Don't worry about it. I already dug something out of ifconfig.
-Mike
#194015 - 18/12/2003 12:37 Re: C code to find empegs IP [Re: mcomb]
Ferrrrrry eeeenterestink...
#194016 - 18/12/2003 13:22 Re: C code to find empegs IP [Re: mcomb]
matthew_k
This sounds like a really cool project, I can't wait to see how it works out... I use itunes occasionally, but it'd be great to use its interface for streaming. Can you filter based on ID3 tags like you can if things are in your library when you're in a shared library?
#194017 - 18/12/2003 13:43 Re: C code to find empegs IP [Re: matthew_k]
mcomb
Loc: San Carlos, CA
Yep, everything works just like local files except you can't modify tags or copy files out of itunes.
-Mike
#194018 - 18/12/2003 19:20 Re: C code to find empegs IP [Re: tfabris]
Daria
Windows stuff. How quaint. Get a real OS and call me back.
#194019 - 09/06/2005 14:04 Re: C code to find empegs IP [Re: Daria]
Greetings!
Was anything published out of this project? I had someone ask me about iTunes and daapd today, and I did a search / found this thread. Thanks!
#194020 - 09/06/2005 15:31 Re: C code to find empegs IP [Re: pgrzelak]
Daria
Well, there's a mini ifconfig with the gpsapp/gpsd stuff, but IIRC it ups 127.0.0.1 and doesn't get the ip of the real net.
I could make it do so. But is that what you want?
#194021 - 12/06/2005 15:50 Re: C code to find empegs IP [Re: Daria]
mcomb
Loc: San Carlos, CA
I'm assuming Paul was asking about daapd not ifconfig. Anyway, I never quite got it working to my satisfaction. I had memory issues (not enough of it) and never found a multicast responder that didn't suck. Now that many of us have memory upgrades and daapd appears to have mDNS builtin it is probably an easier proposition, but I haven't had time to look into it again. Someone (tonyc?) also sent me a PM a while back asking about it and it sounded like he was going to try and get it working, not sure if anything ever came of that.
Once the new car smell wears off ('05 Mustang GT getting delivered on Wednesday) and I get an empeg installed I may try to find time to get it working again.
-Mike
#194022 - 21/09/2005 00:53 Re: C code to find empegs IP [Re: mcomb]
Daria
So did you ever get anywhere with this? I'm sort of tempted to put daapd on my empeg but if you already have (mostly) done work I see no reason to duplicate it.
#194023 - 21/09/2005 17:37 Re: C code to find empegs IP [Re: Daria]
mcomb
Loc: San Carlos, CA
Nope sorry, never got a chance to look at it again. If you feel motivated to work on it, I wouldn't wait for me. I don't have the code from the first time I tried to get it working and daapd has changed a lot since then anyway.
-Mike
#194024 - 21/09/2005 19:04 Re: C code to find empegs IP [Re: Daria]
Is the idea here to have a way for a program *running on the player* to determine the player's IP address for the player's ethernet port?
#194025 - 21/09/2005 19:59 Re: C code to find empegs IP [Re: mlord]
No. That part is already done.
#194026 - 21/09/2005 22:10 Re: C code to find empegs IP [Re: mlord]
mcomb
Loc: San Carlos, CA
Nah, asked and answered. Now we are talking about a daap (iTunes music sharing protocol) server for the empeg. It would allow all your music on the empeg to show up to any iTunes clients on your network and stream from the empeg to iTunes.
-Mike
#194027 - 22/09/2005 07:02 Re: C code to find empegs IP [Re: mcomb]
This would be cool.
Peripherally cool would be some kind of iTunes plug in that would allow it to read and stream songs off of a Rio Central server.
The protocols are well-documented (it's just HTTP calls), and I even wrote a quick and dirty standalone Visual Basic program to do this very thing, it was simple. So I figure writing something similar as an iTunes plug-in would be a doddle. Once one knew how to write iTunes plug-ins, that is.
Alternatively, I wonder how easy it would be to use some sort of virtual windows emulator on my Mac to just fire up that VB program of mine. What are my options in that arena?
#194028 - 23/09/2005 00:59 Re: C code to find empegs IP [Re: mcomb]
mcomb
Loc: San Carlos, CA
Well, you guys talked me into it I guess. I got mt-daapd to compile (pretty straightforward) and made a few tweaks to get it to deal with the empeg's file system layouts rather than expecting everything to end in .mp3. You definitely need an empeg with extra memory to run this and the player at the same time. My 32Meg player seems to be pretty happy sharing about 30 gigs over daapd with the player running and a reservecache of 120, but sharing 60 gigs (both drives) seems to pretty much kill it.
At the moment you must have a drive mounted read-write for daapd's database file at all times. I'd like to see if I can do anything about that before I post it. Give me a day or two.
-Mike
Edited by mcomb (23/09/2005 01:14)
#194029 - 23/09/2005 01:05 Re: C code to find empegs IP [Re: tfabris]
mcomb
Loc: San Carlos, CA
I believe there is an iTunes peripheral plugin interface that you might be able to abuse to do this. Send me a Central and I'll think about it
Not many options that I know of. VirtualPC would be your best bet, but it is pretty painfully slow and I can't imaging running it just for that.
-Mike
#194030 - 23/09/2005 09:18 Re: C code to find empegs IP [Re: mcomb]
send me a Central and I'll think about it
You know, Mike Schrag's got one he was going to send to me after I got settled here in Seattle. If you're serious about that offer, it could be arranged to make a detour on the way here.
#194031 - 23/09/2005 09:28 Re: C code to find empegs IP [Re: mcomb]
The Central server protocol is just the Rio Receiver protocol, and if you were serious about developing an Itunes plug-in, you could use any third-party Rio Receiver server.
But IMO the right way to do it is to write a Receiver-to-DAAP republisher: that means you could also feed Roku Soundbridges and so on from a Central. Even cooler would be to write an aggregating DAAP/Receiver/MediaServer republisher, that combined music from all available servers of three protocols and republished it over all three protocols.
#194032 - 23/09/2005 09:32 Re: C code to find empegs IP [Re: peter]
As long as I didn't need a THIRD computer on which to run this republisher, sure.
One of the reasons I like the central is that it's 100 percent uptime with no fan noise. If I had to keep yet another server PC turned on to accompany it, that would be irritating.
I suppose there's nothing to stop such a republisher from running on the client PC alongside iTunes. That would solve my particular case, and also solve the Soundbridge cases for anyone who wanted to dedicate another box to the task.
#194033 - 23/09/2005 10:38 Re: C code to find empegs IP [Re: tfabris]
You'd run the republisher on the Central. (Probably. I can't remember how much control a random daemon would have over whether the player software spins the disk down.) It's just that solving the problem at the server end rather than the client end has more applicability to other situations.
Except that the client PC is already running a DAAP server if it's running Itunes. Depending on exactly how it works, it might not be possible to have two DAAP servers on the same IP address.
#194034 - 23/09/2005 14:08 Re: C code to find empegs IP [Re: tfabris]
mschrag
Loc: Richmond, VA
I have that and an OS X DVD to send to Loren that I promised him weeks ago ... I'm getting off my ass this weekend to mail out Loren's disc, so if you want me to send this out too, let me know.
#194035 - 23/09/2005 17:40 Re: C code to find empegs IP [Re: peter]
Ooo. that would be utterly awesome. So who's up for writing this little gem?
#194036 - 23/09/2005 17:51 Re: C code to find empegs IP [Re: tfabris]
mcomb
Loc: San Carlos, CA
Err, why write a republisher at all? Just run daapd on the Central. If I can get it running happily on the empeg I don't see why it wouldn't work on a Central. How much memory do those things have?
-Mike
