#183494 - 07/10/2003 19:31 Palantir 0.98 - Insert re-added + Tungsten bugfix
cushman
Loc: Erie, CO
Palantir 0.98 is on my webpage now. This version fixes a bug with searches and the Tungsten 5-way navigators. I've also re-added the Insert upload mode in the Playlist screen once discovering what enqueue really means.
Mark Cushman
#183495 - 21/02/2004 07:46 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
maurij
Hi mark,
just a quick question. when you got your palm TC you were contemplating palantir over wlan. any further thoughts or developments here? just curious. i use palantir all the time. its such a great tool. thanks for your work
Jason
#183496 - 21/02/2004 20:25 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: maurij]
cushman
Loc: Erie, CO
None so far. Different transports for Palantir data (could include serial, Bluetooth, wifi) will be considered after the Pocket PC port of the app, which is in the works. Considering other projects I'm working on, it will probably be a while. The app IS open source though .
Mark Cushman
#183497 - 23/02/2004 10:45 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
TigerJimmy
How can I get the source for the database builder program?
Thanks,
Jim
#183498 - 23/02/2004 11:57 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: TigerJimmy]
cushman
Loc: Erie, CO
The source is included in the .jar file you run to launch the program. You can extract it with unzip/winzip or the jar executable that comes with your jre.
Mark Cushman
#183499 - 23/02/2004 17:05 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
TigerJimmy
Oh. That's easy. Thank you.
The hard part is that I've never done anything in Java. Should be fun, though. I want to modify the program so it writes my .pdb file to mimic my playlist structure rather than using the tags.
Jim
#183500 - 23/02/2004 18:51 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: TigerJimmy]
russmeister
Loc: South Carolina
Let me know when you finish.
Russ
"The difference between a successful person and others is not a lack of strength, not a lack of knowledge, but rather a lack of will." Vince Lombardi
#183501 - 23/02/2004 19:12 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: TigerJimmy]
cushman
Loc: Erie, CO
The PDB creator could be re-written in any language, once you figure out the DB format.
Keep in mind that the app relies pretty heavily on the way the database is structured, and vice versa. You would have to have three levels of playlists before you hit songs, and only three. To get what you want (your playlists replicated on the Palm) you would have to re-write the app itself, and depending on how your playlists are set up, major database changes, too.
See this post to understand why different views would be difficult the current way Palantir does things.
Mark Cushman
#183502 - 23/02/2004 20:37 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
TigerJimmy
Thanks, Mark. Actually, I would settle for a subset of my playlists in Artist/Album/Song order. The reason that many of my tags are bad and I also have many classical or compilation discs. I'll take a look at the other thread and try to figure out how to make do with a 3 level database that comes from my "Artists" playlist rather than from the tags.
Thanks again,
Jim
#183503 - 24/02/2004 06:25 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: TigerJimmy]
cushman
Loc: Erie, CO
It might be easier to re-tag your music to match instead of re-writing anything. You would be accomplishing pretty much the same thing with no development.
Mark Cushman
#183504 - 24/02/2004 09:33 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
russmeister
Loc: South Carolina
Plus retagging will get them right on the empeg, thus killing two birds with one stone.
Russ
#183505 - 12/08/2004 16:02 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
Bump. I forgot how cool this program is and realized more people don't even know it exists!
#183506 - 13/08/2004 16:23 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
SE_Sport_Driver
I was confused while reading this... you mention "retagging" to get things to read properly into Palantir. But "tags" as in ID3 tags are not used by the empeg once the files are on the player. So, when you mention "fix the tags" do you really mean "fix the data in your database" or "fix the ID3 tags on the mP3 file and replace the file on the empeg"?
I'm still waiting for Sony to mail me my Clie's installation CD, so I havn't been able to play with this yet, but I imagine that even if I had a 50% larger file (as mentioned in another post) I'd consider it worth it if I could get Palantir to mimic my empeg's playlist structure. Of course, it's easy for me to say that since I wouldn't have to write anything!
Another petty request would be to have an install script ala emphatic, but your instructions are simple enough.
#183507 - 13/08/2004 16:30 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: SE_Sport_Driver]
I'll do you one better... The "Empire" server functionality will be built into emphatic in the next release, with the option to disable it for those who don't use Palantir. This will allow people to use Palantir and not have emphatic croak (due to Hijack popups) when you queue songs. The irattach program will be installed as well, and will be launched by emphatic when appropriate. Just doing some final testing before I release it.
#183508 - 13/08/2004 16:39 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
Well, I just find it's easiest to fix all my ID3 tags, then upload to the Empeg. If you like to modify the data in your database instead of making sure the ID3 tags are right, that's fine too, just as long as the data in the Empeg is correct. The export from jEmplode or Emplode exports the data in the database, so as long as that is correct you will get a good file for Palantir. I like to have everything neat and tidy, that way all my "tweak by" functions work correct and also the Palantir database is sorted.
You can't find a download of the Clie software somewhere? I'm sure you might be able to find it on some p2p networks.
Like I said before, Empire and Palantir are both open source, and I have posted information on the db format on this board, so you are welcome to modify them all you want. I prefer to have the Empeg's database correct for a few reasons:
1. You can use the auto-generated soup views in jEmplode to create your a-c -> Alice In Chains -> Dirt -> Would? tree view automatically, and update the playlists on the fly when you upload new songs. I have 0 user-defined playlists, they are all soup playlists generated by jEmplode.
2. Tweak by artist, source will always work correctly
3. Palantir works well out of the box.
I may think about this in the future.
Mark Cushman
#183509 - 13/08/2004 16:45 Re: Palantir 0.98 - Insert re-added + Tungsten bug [Re: cushman]
SE_Sport_Driver
Okay, good to hear. My database is very up-to-date. I'm anal about it. With the number of songs I have, it's been easier to update the database as I go rather than reload my music. So searches in emplode and tweaking all work fine. I just wanted to make sure my hard work wasn't wasted.
#183510 - 22/08/2004 15:37 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
My database is 1.5mb for the Palm... took like 4 minutes to transfer! (?) I was getting ready to email you the file to have it looked at!
#183511 - 22/08/2004 16:02 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
Hey Mark, I finally have this thing installed!
My Palm is timing out looking for the empeg though... It shows "Searching" for a while, then displays "Unable to find handheld device"... I'm aiming it right near the volume knob, about an inch away...
Is "supress_notify=1" effecting this?
I attached my config file.
230259-empireconfig.ini (251 downloads)
#183512 - 22/08/2004 16:16 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
Here is my boot log:
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v410 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Wed Aug 4 00:27:49 EDT 2004
Checking for extra DRAM:
c1000000: wrote ffffffff, read e91ba9f0
empeg-car player (hardware revision 9, serial number 30102609) 16MB DRAM
Command line: mem=16m
Memory: 15008k/16M available (984k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004280).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hdb: IC25N080ATMR04-0, ATA DISK drive
hda: HTS548080M9AT00, ATA DISK drive
hda: HTS548080M9AT00, 76319MB w/7877kB Cache, CHS=9729/255/63
hdb: IC25N080ATMR04-0, 76319MB w/7884kB Cache, CHS=9729/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0a:3
1
Partition check:
empeg-pump v0.03 (19980601)
Mounting proc
Starting player
Timezone: America/Detroit
hijack: removed menu entry: "Button Codes Display"
hijack: removed menu entry: "Button Illumination Level"
hijack: removed menu entry: "Font Display"
hijack: removed menu entry: "Show Flash Savearea"
hijack: removed menu entry: "Volume Level on Boot"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
start_empire: sleeping for 10 seconds...
start_empire: Starting Empire...
IrDA: Registered device irda0
irlap_driver_rcv(), Unknown frame ef received!
Vcb: 0x4086d000
#183513 - 22/08/2004 16:22 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: SE_Sport_Driver]
SE_Sport_Driver
Okay, after some trial and error, I was able to get "something" to happen. I guess I had to hold the Palm just right and "steady".
There was some contact, then the Palm displayed "Disconnected" and I never saw "empire" appear on the screen. Next, my Terminal showed the following and the player rebooted after the "Shuffle" screen appeared.... ?
Looks like I'm running out of memory too..
#00002FAD0!
empire(20): memory violation at pc=0x4007db98, lr=0x7269746e (bad address=0x616c
617c, code 0)
pc : [<4007db98>] lr : [<7269746e>]
sp : bffffbd4 ip : 616c6170 fp : bffffbf8
r10: 4010e128 r9 : 00000003 r8 : 0000006c
r7 : 02009c10 r6 : 4010d01c r5 : 02009c00 r4 : 00000020
r3 : 4010d024 r2 : 616c6170 r1 : 00000010 r0 : 00000000
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: C046917D Table: C046917D DAC: 00000015
Function entered at [<4007da28>] from [<4007d9fc>]
r10 = 4010E128 r8 = 02009A10 r7 = BFFFFC6F r6 = BFFFFC68
r5 = 02009C00 r4 = 4010D01C
Function entered at [<4007d930>] from [<40024ee0>]
r10 = 4010E128 r5 = 02009A10 r4 = 00000000
Function entered at [<40024e98>] from [<40023180>]
r4 = 02009BE8
Function entered at [<40023150>] from [<40021bb8>]
r7 = 00000000 r6 = 02009C18 r5 = 00000000 r4 = 02009C18
Function entered at [<40021b8c>] from [<02000b24>]
Function entered at [<02000a84>] from [<02000bf4>]
r8 = 020091C0 r7 = 00000080 r6 = 00000002 r5 = 020091C0
r4 = 02009A10
Function entered at [<02000b94>] from [<02000ca4>]
r4 = 02009118
Function entered at [<02000c18>] from [<4002236c>]
Function entered at [<4002232c>] from [<40023f64>]
r4 = 02009118
Function entered at [<40023d14>] from [<40022580>]
r8 = 020091E0 r7 = 00000006 r6 = 02009118 r5 = 020091C0
r4 = 00000006
Function entered at [<40022460>] from [<4002389c>]
r9 = 02000CBC r8 = 02000DB0 r7 = 020007BC r6 = BFFFFD44
r5 = 02009118 r4 = 00000001
Function entered at [<40023744>] from [<40021974>]
r6 = 02008E78 r5 = 02008E74 r4 = 02008E78
Function entplayer(32): memory violation at pc=0x020c4a28, lr=0x020b6a54 (bad ad
dress=0x0223099d, code 2)
ered at [<4002195pc : [<020c4a28>] lr : [<020b6a54>]
sp : be1ffbd0 ip : be1ffb84 fp : be1ffcb4
4>] from r10: 0214d594 r9 : 00000000 r8 : be1ffce8
r7 : 00000000 r6 : 00000652 r5 : 00110100 r4 : be1ffce8
r3 : 0223099d r2 : 0214dff4 r1 : 00000020 r0 : 02178c20
Control: C0EF917D Table: C0EF917D DAC: 00000015
Function entered at [<020c4864>] from [<02026230>]
r10 = 00000000 r9 = 00000000 r8 = BE1FFCE8 r7 = 00000000
r6 = 00000652 r5 = 00110100 r4 = BE1FFCE8
Function entered at [<02026208>] from [<0204e7d0>]
r8 = BE1FFD30 r7 = 0219512C r6 = 00000652 r5 = 02195050
r4 = BE1FFCE8
Function entered at [<0204e1f4>] from [<0204df7c>]
r10 = 02195198 r8 = BE1FFD30 r7 = BE1FFD2C r6 = 0000000D
r5 = 02195050 r4 = 0219512C
Function entered at [<0204ded4>] from [<020ad4f0>]
r10 = 020AD438 r9 = 02195050 r8 = 0000300D r7 = 00000080
r6 = 0000000D r5 = 02195050 r4 = BE1FFD64
Function entered at [<020ad438>] from [<020b4824>]
r5 = 02195068 r4 = BE1FFE40
Function entered at [<020b475c>] from [<020e9bbc>]
r4 = 00000000
Function entered at [<020e8330>] from [<020b45a0>]
r8 = 02157EBC r7 = 02157EA8 r6 = 020AD438 r5 = 00000007
r4 = 00000000
Function entered at [<020b44f0>] from [<020e9bbc>]
r5 = 00000000 r4 = 00000000
Function entered at [<bffffcbc>] from [<021ae5c8>]
Restored terminal settings
Abnormal player termination
Player received signal 11
Starting player
Vcb: 0x4086d000
#183514 - 22/08/2004 23:12 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
Modify your config.ini file entry to do a:
;@EXEC_ONCE /bin/bash -c "/usr/local/bin/start_empire 12 &"
Note the 12 instead of a 10. This will start Empire after a 12 second delay. The delay is needed to allow the player app time to start up and sieze the IrDA port, just so we can sieze it back. The lines:
Vcb: 0x4086d000
mean that Empire has not successfully taken control of the IrDA port. The added delay may be the result of your player having to account for so many tracks (unless you also have other software starting up such as telnetd or a VNC server, etc). I have seen this happen before to people with over 15k or so tracks.
Mark Cushman
#183515 - 22/08/2004 23:22 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
Cool! Did you see the error message about memory? Is that something to be concerned about? A reserve cache setting is in order maybe (I have none setup)?
I have 22K tracks, so if 12 seconds doesn't work, I'll increase it some more.
My next experiment is to see if I can transfer the database to the Palm via my MemoryStick. Will be much faster if I can.
EDIT: It works! You have to name the file "Palantir Music Database.PDB" when you transfer it to the Memory Stick. The Palm will not be able to access the file from the card, so you'll need to transfer the file over to the internal memory.
Thank you!
Edited by SE_Sport_Driver (22/08/2004 23:30)
#183516 - 22/08/2004 23:44 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
I did see that... there is a bug in empire with some memory allocation (Tony C spotted that for me) :-/ that I could fix and you could possibly test for me, but I've never had it crash on me even with the bug. If the startup time adjustment doesn't work, we can try that. A ReserveCache setting would not cause or prevent that error.
Mark Cushman
#183517 - 23/08/2004 18:41 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
I bumped it up to 16 seconds for it to load properly. Now I just need to get better at having the Palm and empeg see one another. Palm keeps timing out at "Searching".
#183518 - 23/08/2004 18:50 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
SE_Sport_Driver
Does this look normal for the serial output?
erial_notify_thread.cpp: 180:@@ #5bd10 0:04:00
serial_no
tify_thread.cpp: 180:@@ #5bd10 0:04:01
serial_notify_thread.cpp: 180:@@ #5bd10
0:04:02
serial_notify_thread.cpp: 180:@@ #5bd10 0:04:03
serial_notify_threa
d.cpp: 180:@@ #5bd10 0:04:04
serial_notify_thread.cpp: 180:@@ #5bd10 0:04:05
serial_notify_thread.cpp: 180:@@ #5bd10 0:04:06
:@@ #5bd10 0:04:07
serial_notify_thread.cpp: 180:@@ #5bd10 0:04:08
serial_no
tify_thread.cpp: 180:@@ #5bd10 0:04:09
0:04:10
serial_notify_thread.cpp: 180:@@ #5bd10 0:04:11
serial_notify_threa
d.cpp: 180:@@ #5bd10 0:04:12
Keeps repeating. The Palm will keep "Searching" while I hold it close, but nothing happens (I think "once" it said "Sending Playlist", but then timed out). The "Searching" will appear for as long as I point it at the empeg. Once I pull away, I get the "Unable to find other device" on the Palm.
Edited by SE_Sport_Driver (23/08/2004 18:51)
#183519 - 23/08/2004 19:04 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: SE_Sport_Driver]
It's showing all those because you spelt suppress_notify wrong.
#183520 - 30/08/2004 15:19 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: tman]
SE_Sport_Driver
Nope, I had it spelled write.
Mark was nice enough to get in touch with me and give me a test version of empire. Now everything works great! I guess my database size had something to do with it. I also had to extend the startup delay to 16 seconds.
The program is amazing! Great converstation peice too!
Any chance of making a Palm based Remote? The Rio one isn't backlit.
#183521 - 03/09/2004 23:51 Empire 0.25 - fixes nasty memory leak bug [Re: SE_Sport_Driver]
cushman
Loc: Erie, CO
There is a new version of Empire up on my website. This version (0.25) fixes an memory leak that only arises when you are using much of the player's memory (like Brad was doing above). Grab it if you are having problems with Empire currently.
Mark Cushman
#183522 - 23/09/2004 02:35 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
JaBZ
Loc: NZ
errr i don't know if this has been asked before, maybe a wishlist feature?..
I'd like if palantir could save the current playlist view?
#183523 - 23/09/2004 10:35 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: JaBZ]
cushman
Loc: Erie, CO
Do you mean save the list of songs that are currently in the Playlist view?
So you could have multiple playlists available on the Palm? I would have to think about this one. If it is a playlist that you will use repeatedly, why not just make a playlist on the Empeg? OR, you could beam one playlist up in Replace mode, then Bookmark it on the Empeg.
Mark Cushman
#183524 - 25/09/2004 02:09 Re: Palantir 0.98 - Insert re-added + Tungsten bugfix [Re: cushman]
JaBZ
Loc: NZ
Yes, I was just thinking in situations where I don't have access to my notebook, or powered empeg. When I'm on holiday/roadtrip, I'd like to create playlists on my palm while in the comfort of the airplane seat, hotel room, toilet.. etc Some playlists I wouldn't want to save on the empeg, since it'd be the selection of songs my passengers would like to hear during the 8hr journey.
