#179773 - 17/09/2003 19:57 Drive builder won't find the player
I am trying to install a new drive in a MK2a and when I run the drive builder it won't find the player. I have tried both builders.
The player shows up in hyperterminal. Here is the log.
˙If there is anyone present who wants to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v325 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Apr 2 17:15:11 EST 2003
empeg-car player (hardware revision 9, serial number 40104261)
Command line: mem=16m
Memory: 14996k/16M available (996k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
Based upon Swansea Universit
IP Protocols: ICMP, UDP, TCP
IrCOMM protocol (Dag Brattli)
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Found custom animation at offset 0x99b78
Tuner: loopback=0,
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DARA-212000, ATA DI
hda: IBM-DARA-212000, ATA DISK drive
hda: IBM-DARA-212000, 11513MB w/418kB Cache, CHS=23392/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:10:a
5
Partition check:
hda: unknown partitio
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...dev 03:05 blksize=1024 blocknr=1 sector=2 size=1024
count=1
EXT2-fs: unable to
e000 v1.04
Copying kernel...
l.
Tuner: loopback=0, ID=0
empeg state support initialised 0089/88c1 (save to d0005d00).
5
Partition check:
hda: unknown partition table
count=1
EXT2-fs: unable to
e000 v1.04
Copying kernel...
l.
e000 v1.04
Copying kernel...
l.
5
Partition check:
count=1
EXT2-fs: unable to
#179774 - 17/09/2003 20:04 Re: Drive builder won't find the player [Re: msaeger]
Is it just a single IBM 10GB drive in there?
Also the log is for the normal bootup as you've got hijack installed.
#179775 - 17/09/2003 20:07 Re: Drive builder won't find the player [Re: tman]
Yeah it's a 10GB it looks like the drive is being seen thats why I don't understand why the drive builder doesn't find the player.
#179776 - 17/09/2003 20:10 Re: Drive builder won't find the player [Re: msaeger]
What do you mean by "doesn't find the player"?
#179777 - 17/09/2003 20:14 Re: Drive builder won't find the player [Re: tman]
Well when I run the builder program it gets to finding unit apply power to your player now. I plug the player in and the program just stays at finding unit until it times out.
#179778 - 17/09/2003 20:16 Re: Drive builder won't find the player [Re: msaeger]
Is there anything else using the serial port when you're running the upgrader with the builder image?
#179779 - 17/09/2003 20:18 Re: Drive builder won't find the player [Re: tman]
Not that I know of is there a way to tell for sure ?
#179780 - 17/09/2003 20:24 Re: Drive builder won't find the player [Re: msaeger]
I guess it is working as you've got hyperterminal working. You are shutting Hyperterminal down before running the upgrader yet?
Are you using the latest emplode?
#179781 - 17/09/2003 20:36 Re: Drive builder won't find the player [Re: tman]
yep the terminal is closed It is the latest emplode also.
#179782 - 18/09/2003 04:10 Re: Drive builder won't find the player - Eh?? [Re: msaeger]
schofiel
Errr.....
There isn't a "Drive Upgrader program" - there is the standard Updater, and when it asks for the firmware upgrade image file, you point it to a builder image. You need to make sure you use the right one for your player - don't confuse the Mk2 and Mk1 versions.
Once the builder image is loaded, and as long as you have the new disk installed as master, the builder should reboot, find the unformatted disk and start formatting it. After this, you re-update your player to whatever version of the player software you want with the appropriate image file as before.
If you are having problems with the Upgrader finding the player, then it implies you are using a duff serial cable of some sort. Are you using your original? Are you feeding it through any kind of 9-25 adaptor? You should be using a Null Modem cable, not a DTE DCE or other pinning.
Which software version have you got on there at the moment, Developer or Consumer? If it's Developer, can you break the boot with a Ctl-C and get a shell prompt from Bash? If you can then there's nothing wrong with the cable. If you can't, then either you have your term software settings wrong (115k, 8N1, NO handshaking) or the cable is duff.
#179783 - 18/09/2003 06:28 Re: Drive builder won't find the player - Eh?? [Re: schofiel]
burdell1
Does it matter if hijack is installed?
#179784 - 18/09/2003 08:28 Re: Drive builder won't find the player - Eh?? [Re: burdell1]
schofiel
HiJack is just the kernel, not the player software. I have successfully loaded the builder image on a player that already had HiJack, with no problems. It includes it's own kernel.
#179785 - 18/09/2003 14:45 Re: Drive builder won't find the player - Eh?? [Re: schofiel]
burdell1
should the com port have any settings different than normal?
#179786 - 18/09/2003 14:48 Re: Drive builder won't find the player - Eh?? [Re: burdell1]
Theoretically, the upgrader application will set the com port settings for whatever it needs. But just in case, you can try going into the control panel and setting it to 115200 8n1 with no flow control.
