#173450 - 02/08/2003 08:24 amp(s) draining battery
bjoern
Loc: Regensburg, Germany
I have a dual amp setup (one on each side of my Miata trunk). Both amps get power directly from the battery post. One amp (Memphis ST3004) grounds where the battery grounds (chassis), the other (Majestic 120W 4ch) on chassis on the other side. The remote turn-on lead goes from the harness to the first (Memphis) amp and where it is tied into that amp, I tied the remote turn on from the other amp (Majestic). What first raised my suspicions was that there was a spark when I put the fuse into the power lead for the Memphis amp. I then noticed, that when the speaker wires touch (I mean the blank ends during installation), it engages the safety circuit of the Memphis amp. Also, I get a loud thump from the speaker powered by the Memphis when I plug the empeg into the harness. Lastly, the green power diode was glowing even when the empeg wasn't in the sled (but I understood the manual to say that that was normnal).
Now, a week later with no movement of the car, the battery is drained. What could I have made wrong? Does that sound like some common mistake that happens to a lot of people?
32MB, serial: 10101626
#173451 - 02/08/2003 08:33 Re: amp(s) draining battery [Re: bjoern]
mtempsch
Sounds like that amp is always on... I doubt that the green LED should always be on - most amps (can't comment on you specific one as I've never even seen one) will use that as an indicator that the amp is on - and that would/should only happen as the amp remote turn on wire is high.
Try disconnecting the remote wire from the amp, plug in the empeg and see if you get sound out of the speaker attached to it. If so, then it's on without a remote connection...
That most likely points to a broken amp turn on circuitry inside the amp...
#173452 - 02/08/2003 10:23 Re: amp(s) draining battery [Re: mtempsch]
bjoern
I'll have to wait until the car is charged to test it, but if that were the case, would it work to install a relay into the power lead and have that relay be operated by the turn-on lead? Or is the current in the turn-on lead not enough?
#173453 - 02/08/2003 14:05 Re: amp(s) draining battery [Re: bjoern]
mtempsch
Well, the internal operation between the power lead and the remote turn on is in effect the same as a relay (small current controls larger...)
So if the fault is in the amp, and it stays always on, a relay on the +12V line, controlled by the remote turn on wire should work fine - just get a relay capable of handling the current the amp demands. Normal automotive relays are typically capable of 30A, though I've seen 20A and 40A as well.
You might want to connect the other (functional) amps remote turn on terminal to the switched terminal of the relay, so that the relay is the only thing powered by the remote turn on lead. If the relay doesn't come with a diode across the coil, consider installing one (1N400x diode should be fine), or some other protection.
#173454 - 02/08/2003 17:30 Re: amp(s) draining battery [Re: mtempsch]
bjoern
Hey, thanks for your detailed replies! Great stuff! With my trusty little multimeter I now found out that there is an increasing voltage on the turn-on lead of the majestic amp. It goes from 0.5V to over 1V within abnout 1-2min. I guess that's the culprit. I've taken the majestic amp off for now and its turn-on lead is also disconnected. Now I don't get any thump anymore, so I guess that's fixed now. Is there a permanent solution to the problem other than exchanging/repairing the majestic amp? Any ideas for stop-gaps?
#173455 - 03/08/2003 01:12 Re: amp(s) draining battery [Re: bjoern]
mtempsch
In what situation is that? With or without the remote connected? Both?
Sounds like you have something leaking power somewhere in the amp - maybe a failing cap - but the symptoms are weird...
Workaround: hmmm... I'd try running both the BAT+ and remote terminal off a relay controlled by the real remote wire (gives positive control of the remote terminal as well) if you can find a relay that can handle the current. You might get thumps - haven't ever wired an amp that way... and different amps act differently when it comes to thumping anyway.
Any warranty left on the amp?
#173456 - 03/08/2003 10:53 Re: amp(s) draining battery [Re: mtempsch]
bjoern
The amps are in really tight spots, so I could only test it with the remote wire out of the memphis amp, i.e. only connected to the empeg-remote.
Sounds like a possibility. I'll probably try that.
Shouldn't be a major deal, since that amp only powers the small, mid-high frequency speakers anyway. Bigger deal will be to get to all the wires and get good connectivity, the way everything is installed now LOL
Bought it used off Ebay...
Thanks for your help!
#173457 - 04/08/2003 07:08 Re: amp(s) draining battery [Re: bjoern]
bjoern
Hmm, maybe my battery is still not fully charged, but my empeg blanks the screen and comes back up with the battery icon every time I break (the interior lights and headlights dim when I do that, too). The voltmeter also shows a dip of about 1V (to about 12.5V) with a negative spike going a little further down. If it persists after I verified full battery charge, do I have to change the permanent power source to a direct connection from the battery (oem harness for now), or is that a problem of the switched power supply? (I've read the FAQ)
#173458 - 04/08/2003 11:42 Re: amp(s) draining battery [Re: bjoern]
mtempsch
The ignition wire is only used for signaling to the empeg (much like the remote wire to the amp), power is drawn on the permanent line (at least for the MkIIa, the MkII, IIRC could pull power from the ignition wire as well...)
Does it dim whenever you let the RPMs drop, even if you're not brakeing?
If no - look at ground points. The current through/from the brake light might be raising the voltage at a [bad/corroded] ground point so that things get confused (charging regulator etc) Any similar effect if you turn on/off other heavy consumers like fan or rear de-mister?
If yes; sounds like your battery is far from full and/or your alternator is struggling...
I'd check the battery further - being drained completely is bad for starter batteries, especially if they're a couple of years old.
Measure the density of the acid in each cell; it may not show full charge yet (1.28 - 1.30 g/cm^3) but should at least be consistent across all 6 cells. If one cell is significantly different you battery may be broken. Take it to a shop for a load test (draw heavy current from it while monitoring voltage - you should be able to draw the CCA rated current for about 10 seconds without the voltage dipping below 9V (if the battery otherwise is reasonably charged). If it does dip, look down into the "odd" cell (glasses recommended!) - odds are good that you'll see it bubbling/boiling (a lot more than the others) - replace battery.
Also check you alternator: should at least give a bit more voltage than pure battery voltage when car is idling; increase RPMs to about 2000, voltage across battery should rise to at least 13.8V, but not over 14.4V. If not, most likely your charging regulator needs replacement. On most modern alternators it is combined in a unit with the graphite brushes (the reg might be OK, but the brushes worn out - should give low voltages)
#173459 - 04/08/2003 15:17 Re: amp(s) draining battery [Re: mtempsch]
bjoern
Cool stuff in that reply! Thanks a lot, I'll test it out tonight!
Only when I break, switch on the fan, blinker, lights, etc.
Any ground points in the involved circuits or only those close to the alternator?
Yes! The amount of the drop varies, but I get it basically in all electrical consumers. With the blinker for example the effect is so small, I can only see it if the rpms are at idle. I really think it's because the battery is not full, yet. I'll check all that again tonight. It read 12V when I left the car last night. I'll see what happens now.
The battery is a Westco dry battery, only a few months old. I'm not quite sure if I should trickle-charge it or not. I usually tend to leave it to the alternator and only charge it with a charger if it is absolutely necessary.
It shows just under 14V on the highway (3-4k rpm).
If the problem persists even with a full battery, I'll have it checked out.
Thanks again for your help!
#173460 - 04/08/2003 16:01 Re: amp(s) draining battery [Re: bjoern]
schofiel
A dry cell battery in a car? Are you sure about this? These usually can't deliver the cranking current needed the way a wet lead/acid can. Are you sure that your battery is not meant to be a wet battery that has not received an acid solution?
#173461 - 04/08/2003 16:02 Re: amp(s) draining battery [Re: mtempsch]
schofiel
This is an excellent piece and should go into the FAQ as a good diagnostic for battery state. Tony?
#173462 - 04/08/2003 18:24 Re: amp(s) draining battery [Re: schofiel]
Rob: A dry cell battery in a car?
Bjoern: The battery is a Westco dry battery
Could it be a battery patterned after the Optima line of Gel-Cell batteries? These batteries are not of the normal "lead plates immersed in liquid sulphuric acid" construction, but have spiral-wound plates sealed in an acid gel.
The "Red Top" model in particular is known for being able to produce phenomenal current flow, both on output and recharge. In fact, this battery has revolutionized my snow plowing. The electric lift on the snow plow pulls a huge amount of current, and even though I have a 200 ampere alternator, a conventional battery cannot absorb electricity anywhere near as quickly as it can discharge it. So with a conventional battery I am limited to about two hours of plowing before I run out of juice. The Red Top, even though it has only half the capacity, will let me plow indefinitely because it recharges so quickly.
#173463 - 04/08/2003 21:34 Re: amp(s) draining battery [Re: tanstaafl.]
mtempsch
Another alternative is that it's a sealed acid cell battery. If so, then try peeling of any stickers on top - frequently you can find removeable lids underneath, so that you can get to the acid and measure density / check for bubbles under load.
#173464 - 04/08/2003 21:37 Re: amp(s) draining battery [Re: schofiel]
mtempsch
The benefit of 2.5 years working in Gothenburgs largest battery store...
#173465 - 04/08/2003 22:22 Re: amp(s) draining battery [Re: mtempsch]
V99
Loc: Phoenix, AZ
OEM Miata batteries are absorption glass mat.. Here's the WestCo replacement for it. Acid is suspended and immobilized in a fiberglass mesh between the plates. Small, light, lasts much longer than normal batteries, and they're safe, but they don't hold a hell of a lot of power. Since it's in the trunk, you don't want the acid of a normal battery leaking all over your stuff... and when a urban assault vehicle rear-ends you and crushes it, free acid flying everywhere or exploding on you wouldn't be good.
They require special treatment for charging, especially from a dead state.. low current (<= 1A) for long periods of time (18-24hrs); if you blast it with 20A like it's a regular battery you'll destroy it.
#173466 - 05/08/2003 06:44 Re: amp(s) draining battery [Re: V99]
bjoern
V99 is dead on it. I called it dry, because I remembered there was no acid floating around and no holes to peep through
The battery recovered over night, cranked fine and the empeg didn't blank out when I breaked.
However, on the way back, headlights on, after a few miles it started happening again: every break, empeg blanks out. Interestingly, it didn't do that for the first few miles, only as I got close to home. Is my for now single 300W amp drawing too much current together with the headlights? What if I switch the brights on? How about if I upgrade to overwattage bulbs? Do I need a bigger alternator? Bigger battery? Or do I just have to wait a few days until the battery has fully recovered from the drain?
#173467 - 05/08/2003 09:12 Re: amp(s) draining battery [Re: bjoern]
mtempsch
300W isn't very much; fan + rear de-mister would probably draw around that...
How many amperes can the alternator deliver, max?
To me it sounds as is the alternator isn't delivering; once started the alternator should provide all the current you need, as well as charge the battery. Did you have the battery on a charger overnight?
What are the voltages across the battery 1) at rest (car off) 2) car idling and 3) car at typical running RPMs?
#173468 - 05/08/2003 10:12 Re: amp(s) draining battery [Re: schofiel]
It sounds more like something for the CarTalk FAQ rather than the empeg FAQ.
#173469 - 05/08/2003 13:57 Re: amp(s) draining battery [Re: mtempsch]
bjoern
I thought so, too.
60, on paper. I'll have to check if mine still can do that.
No, I figured I'd wait until the next morning, as I have experienced batteries to recover a little over night.
The voltmeter I have installed (factory harness) says 1) 11.5V (ign. on), 2) and 3) are just under 14V, but drop about 1.5-2V with empeg and headlights.
I'm going to keep monitoring the behavior and measure accross terminals for a few days. I still think some more driving will restore the basically brand new battery in a few days and this weird behavior will subside. If it doesn't, I'll measure the max amps the alternator can deliver and replace it, if I have to.
Thanks for all your help, guys! Keep the suggestions coming!
#173470 - 06/08/2003 06:51 Re: amp(s) draining battery [Re: bjoern]
bjoern
OK, latest results: the voltmeter in the dash shows 13.8V if the engine is running and no electrical consumers. If I switch on headlights and empeg/amp it goes to under 12V idling and back to 13.8V when the rpms go up. With fan at full, headlights and empeg/amp on loud it shows under 12V, even at freeway rpms (3-4k). Do you think that if that behavior continues, I should have the alternator checked out or should I rather trickle charge the battery? Or both? With the engine off, the voltmeter showed just over 12V when I left the car last night.
#173471 - 06/08/2003 07:35 Re: amp(s) draining battery [Re: bjoern]
mrfixit
It sounds like to me you do have a bad alternator, the voltage should not drop to 12V especialy on the road. It sounds like it's somthing to do with the regulator in the alternator, I would have it checked.
Ben
hijacked
#173472 - 06/08/2003 15:23 Re: amp(s) draining battery [Re: bjoern]
It could be something as embarassingly simple as a loose alternator belt.
tanstaaafl.
#173473 - 07/08/2003 06:01 Re: amp(s) draining battery [Re: tanstaafl.]
bjoern
Possible. Given the way the Miata belts are tightened, I doubt it, though. I'll check it to make sure, however. It is getting slightly better each day, so I think battery charge playes quite a big role in this.
But back to the original problem (the Majestic amp generating a voltage on the remote turn-on lead): Is it possible that a remote turn-on lead routed right next to the constant power wire could induce the increasing voltage? Or is the amp necessarily faulty? The amp does produce some noise (low level hum), but it's a cheap one and I never expected it to be perfect.
#173474 - 07/08/2003 10:01 Re: amp(s) draining battery [Re: bjoern]
mtempsch
Hmmm,
came to think of the reports of problematic electrical antennas that wouldn't go down efter the signal was removed...
Try wiring a 1kOhm, or so, resistor between the amp remote terminal and ground.
Might bleed off the buildup...
#173475 - 07/08/2003 11:18 Re: amp(s) draining battery [Re: mtempsch]
bjoern
Cool idea! I have the resistor right here next to me as I type this and am going to try it this weekend! Thanks!
#173476 - 07/08/2003 21:50 Re: amp(s) draining battery [Re: bjoern]
V99
Loc: Phoenix, AZ
Aha, I knew this sounded familiar
#173477 - 08/08/2003 06:12 Re: amp(s) draining battery [Re: V99]
bjoern
Sure I figured I had to ask the experts on both sides of the harness
#173478 - 10/08/2003 11:48 Re: amp(s) draining battery [Re: mtempsch]
bjoern
I put the resistor in there and it does bleed the buildup nicely. However, I measure quite some current going through the resistor. Problem is, while my multimeter works just fine for resistance and voltage, it gives me weird readings for current! If I set it to 10A it reads 0.57. If I set it to 2000mA it says 57, if I set it to 20mA it says 5.7???? That doesn"t make any sense to me at all. There is a big difference between 570mA and 5.7. The multimeter works just dandy in all other aspects, but that just throws me off. How much current is actually going throug the resistor "down the drain"? According to Ohm's law (I=U/R=12V/1000ohm) I shouldn't get more than 12mA, so should I assume it's only 5.7mA (which would be perfect)?
#173479 - 10/08/2003 12:09 Re: amp(s) draining battery [Re: bjoern]
julf
While you can measure voltage and resistance between two pins, current has to be measured through something. What you need to do is put the meter in series with the circuit you want to measure, not in parallel.
What you are measuring right now is the current through your multimeter (and yes, that varies depending on range, as the resistance is different on different ranges) instead of through your circuit!
#173480 - 10/08/2003 13:29 Re: amp(s) draining battery [Re: bjoern]
mtempsch
Julf is right on.
Use Ohms law to get to the current by measuring the voltage over the resistor instead.
5.7mA and 1kOhm should mean you have a voltage of 5.7V across the resistor - and on your turn on terminal/lead! That is quite a bit - if it actually is 5.7mA...
Considering you only measured about a volt on it before, you might be an order, or two, of magnitude off. (with the real current even lower, like 0.57mA or something like that...)
#173481 - 10/08/2003 15:45 Re: amp(s) draining battery [Re: julf]
bjoern
I did. I clamped the end of the wire to the mm and connected the other pole of the mm to ground.
IOW: reomote wire of the majestic amp is connected to an empty lead and a lead with the 1kOhm resistor. I measured the voltage on the empty lead with and without the resistor wire being connected to ground. After that, I switched the plug on the mm for current measurement and connected one end to ground and the other to the wire with the resistor. That's when I got the weird results. I'll do it again right now and see if I can make sense of it.
#173482 - 10/08/2003 16:50 Re: amp(s) draining battery [Re: mtempsch]
bjoern
Great idea! I should've known that myself!
/me hits myself repeatedly in the forehead
I now found out something even more interesting: the voltage on the majestic remote-turn-on lead actually goes to 11.5V immediately if I take the empeg out. It goes back to slowly increase, if I put it in and stays 0 if I ground the 1kOhm wire. All the time, the ignition is off and the empeg, therefore, is also off. The turn-on wire is not connected to either the empeg, nor the other amp. Thus, the only connection between the empeg and the majestic amp are the RCA cables. What does it mean that the voltage disappears, if the empeg is plugged into the sled, vs. it being out of the sled? The majestic amp is grounded to chassis with a very short wire (about 5 inches, 10-15cm). The "front" and "rear" RCAs go into a splitter at the Memphis amp and one end of the "Y" goes into that amp and the other into the majestic amp. I find that all very confusing...
