#170564 - 14/07/2003 19:25 Mark 2 problem building databases?
lamer
Loc: Texas
After a WinXP crash during a sync I now cannot get past the "Building music databases..." comment. I have loaded the 2.00 release dev image (and hijack kernel) but am unable to get to the prompt to try this fix. One other questions: When prompted to enter q, why is there "0 seconds to comply"?
Anyhow, here is the serial output on a boot. This output is repeatable.
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v340 (root@ibbm) (gcc version 2.95
.3 20010315 (release)) #2 Wed Jun 18 18:40:14 EDT 2003
empeg-car player (hardware revision 9, serial number 40103994)
Command line: mem=16m
Memory: 15016k/16M available (976k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Tuner: loopback=0, ID=-1
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005e80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: FUJITSU MHL2300AT, ATA DISK drive
hdb: FUJITSU MHL2300AT, ATA DISK drive
hda: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
hdb: FUJITSU MHL2300AT, 28615MB w/2048kB Cache, CHS=58140/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:9
a
Partition check:
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...ԕjչѕɽсɁѕɕ)5chang
e_root: old root has d_count=1
Freeing unused kernel memory: 4k initqempeg init 0.8
Mounting proc
Starting player
qHijack: intercepting config.ini
hijack: removed menu entry: "Tuner RDS Control"
hijack: removed menu entry: "Serial Port Assignment"
khttpd: listening on port 80
kftpd: listening on port 21
! tags.cpp : 61:Failed to open tags (0xc0041002).
attempt to access beyond end of device
03:04: rw=0, want=519859964, limit=29219400
dev 03:04 blksize=4096 blocknr=-943776834 sector=1039719920 size=4096 count=1
03:04: rw=0, want=782784500, limit=29219400
dev 03:04 blksize=4096 blocknr=-1414916612 sector=1565568992 size=4096 count=1
03:04: rw=0, want=993534012, limit=29219400
dev 03:04 blksize=4096 blocknr=-288487410 sector=1987068016 size=4096 count=1
03:04: rw=0, want=1698163772, limit=29219400
dev 03:04 blksize=4096 blocknr=2035153678 sector=-898639760 size=4096 count=1
03:04: rw=0, want=84608716, limit=29219400
dev 03:04 blksize=4096 blocknr=21152178 sector=169217424 size=4096 count=1
03:04: rw=0, want=432155148, limit=29219400
dev 03:04 blksize=4096 blocknr=-428832126 sector=864310288 size=4096 count=1
03:04: rw=0, want=1947760272, limit=29219400
dev 03:04 blksize=4096 blocknr=1023810979 sector=-399446760 size=4096 count=1
03:04: rw=0, want=265262044, limit=29219400
dev 03:04 blksize=4096 blocknr=66315510 sector=530524080 size=4096 count=1
03:04: rw=0, want=1705136152, limit=29219400
dev 03:04 blksize=4096 blocknr=-647457787 sector=-884695000 size=4096 count=1
03:04: rw=0, want=577827932, limit=29219400
dev 03:04 blksize=4096 blocknr=1218198806 sector=1155655856 size=4096 count=1
03:04: rw=0, want=106772240, limit=29219400
dev 03:04 blksize=4096 blocknr=1100434883 sector=213544472 size=4096 count=1
03:04: rw=0, want=999072724, limit=29219400
dev 03:04 blksize=4096 blocknr=-1360844556 sector=1998145440 size=4096 count=1
03:04: rw=0, want=947018000, limit=29219400
dev 03:04 blksize=4096 blocknr=-1910729149 sector=1894035992 size=4096 count=1
EXT2-fs warning (device ide0(3,4)): ext2_free_blocks: bit already cleared for bl
ock 4429881
ock 4429881
ock 4429881
ock 4429881
EXT2-fs error (device ide0(3,4)): ext2_free_blocks: Freeing blocks not in datazo
ne - block = 1560657735, count = 1
Remounting filesystem read-only
ne - block = 3322813680, count = 1
ne - block = 184113030, count = 1
ne - block = 3163721723, count = 1
ne - block = 1076050864, count = 1
03:04: rw=0, want=1725699624, limit=29219400
dev 03:04 blksize=4096 blocknr=431424905 sector=-843568056 size=4096 count=1
EXT2-fs error (device ide0(3,4)): trunc_indirect: Read failure, inode=132342, bl
ock=431424905
03:04: rw=0, want=897831304, limit=29219400
dev 03:04 blksize=4096 blocknr=-312413087 sector=1795662600 size=4096 count=1
ock=-312413087
03:04: rw=0, want=1775376432, limit=29219400
dev 03:04 blksize=4096 blocknr=980715019 sector=-744214440 size=4096 count=1
ock=980715019
ock 4430918
EXT2-fs warning (device ide0(3,4)): ext2_free_inode: bit already cleared for ino
de 132342
Restored terminal settings
ock 4420368
ock 4420368
ock 4420368
ock 4420368
ne - block = 3351190462, count = 1
ne - block = 2880050684, count = 1
ne - block = 4006479886, count = 1
ne - block = 4294936511, count = 1
ne - block = 4294967283, count = 1
Kernel panic: EXT2-fs panic (device ide0(3,4)): load_block_bitmap: block_group >
= groups_count - block_group = 131071, groups_count = 223
*** End of output ***
MK2a 160GB
11 Years later, these Mk2a units still rock...
#170565 - 14/07/2003 20:04 Re: Mark 2 problem building databases? [Re: lamer]
cushman
Loc: Erie, CO
Wow, I had a very similar problem just tonight, but I was able to get to a command prompt to fix it.
One answer: The pause at the beginning of boot is not for you to hit q, it's for programs who wish to upgrade the flash (like if you install Hijack).
Edit: Ah, forgot what you were talking about.. I have the same question!
Edited by cushman (14/07/2003 20:06)
Mark Cushman
#170566 - 14/07/2003 20:50 Re: Mark 2 problem building databases? [Re: lamer]
I think that's a joke. If the player is working properly, Q works at any time.
#170567 - 15/07/2003 01:34 Re: Mark 2 problem building databases? [Re: lamer]
You need to press ^C (Control-C) to quit the player and get to a shell prompt. You might need to hit Control-C lots of times for the player to get the message, but, looking at that log, you should be able to get control at some point on or after the "player.cpp" line. Once you've done that, you need to manually run fsck on your music partitions (look for "e2fsck" in the FAQ).
Usually the player recovers from this sort of disaster at least well enough to connect Emplode and let it run fsck, but yours seems to be an especially bad one...
#170568 - 15/07/2003 20:54 Re: Mark 2 problem building databases? [Re: tfabris]
If I remember the early betas, they used to actually pause there, waiting for Q before starting the player. They later added the Q command to the player app for ease of getting to the shell.
#170569 - 16/07/2003 06:12 Re: Mark 2 problem building databases? [Re: peter]
lamer
Loc: Texas
Thanks, I have an operational player again . The 45 min drive to work (1 way) was getting a little boring without any distractions.
Thanks,
Cory
MK2a 160GB
