#169359 - 06/07/2003 22:48 Sony memory stick ?
I have a question about the difference between a magic gate memory stick and a regular one. Are the two interchangeable ?
I have a sony 40xbr800 tv with a memory stick slot it just says memory stick and I have a sony u101 laptop that has a magic gate slot.
I know the magic gate stuff enables some kind of copy protection but I'm not sure what kind to get if I want to use it in both slots. (copy pictures onto the stick in the laptop and view them on the TV)
#169360 - 06/07/2003 23:56 Re: Sony memory stick ? [Re: msaeger]
MarkH
I believe that Memory Stick is Sony's non-compatible proprietary over-priced regular flash memory, whereas Magic Gate is Sony's non-compatible proprietary over-priced flash memory that additionally supports ATRAC3 and copy protection. I think you can use the regular Memory Sticks in both your devices without problems, presumably you want to transfer JPEG photos to display ? You can't play a Magic-Gate-with-protected-content back in your Memory-stick-only slot, but you can play a Magic-Gate-without-protected-content in it.
Regards
Mark
#169361 - 07/07/2003 05:57 Re: Sony memory stick ? [Re: msaeger]
Correct. My P800 came with a 16MB Sony Memory Stick Duo (crap), and I added to that with two 128MB Sony Memory Stick Duos w/ Magic Gate "technology" (multiple crap).
I have a deep hatred for Sony and their memory sticks. Do you know what's even worse about it all? I can't upgrade to a higher capacity Duo when they come out. Apparently they wanted to make the format so proprietary, they excluded some of their own devices!
If I hadn't wanted this phone so badly, I would have passed on it just because of the memory stick. Cursed format!
#169362 - 07/07/2003 06:32 Re: Sony memory stick ? [Re: Dignan]
I'm not a fan either and never thought I would want to buy one but now I ended up with a laptop and a tv with slots so I have to try them out.
