#151336 - 29/03/2003 06:14 changing IP address
jane
Loc: Copenhagen SW, Denmark
Is this a bug?
When using emplode's "edit ini-file" to change the IP address, and then sync, Emplode thinks the empeg player has not rebooted properly, and insistes that my changes have not been updated.
Marius (Escort Cab + 2CV)
#151337 - 29/03/2003 08:12 Re: changing IP address [Re: jane]
Emplode must think it's not rebooting properly since the player would have changed IP address and disappeared.
To fix this I guess you'd need to parse the new config.ini and work out the new IP address and then use that afterwards.
I originally configured my player via the serial port and not changed it since
- Trevor
#151338 - 29/03/2003 08:21 Re: changing IP address [Re: tman]
SE_Sport_Driver
This makes sense because the "Network" tab in "Configure Player" (emplode) does not appear when connected via ethernet.
Easiest way to fix this would be to configure the IP when connected via USB or setup HiJack so that you have one set of Network settings for "@Home" and another for "@work" so you don't have to change them that often. (Looking back now, it would have been nice to have @Home use DHCP and @work use an assigned IP - but I've switched jobs now so it's mute.)
#151339 - 29/03/2003 08:49 Re: changing IP address [Re: SE_Sport_Driver]
jane
Ah. I was looking for the network options tab, and thought it must never have been there... I have no way of connecting via USB at the momen.. .but restarting emplode worked well. (I don't do this very often either)
Marius (Escort Cab + Mark II)
#151340 - 29/03/2003 09:34 Re: changing IP address [Re: SE_Sport_Driver]
Happy Birthday wfaulk
so it's mute
moot
#151341 - 29/03/2003 09:35 Re: changing IP address [Re: jane]
Is this a bug?
No. It's a problem that you induced yourself, immediately after answering a clear warning box that you might do precisely that.
You can work around this problem next time by connecting via serial or USB when you want to change the IP address.
#151342 - 29/03/2003 10:08 Re: changing IP address [Re: tfabris]
xanatos
Loc: Denver, CO
Actually on this same note.
I use DHCP for my empeg. When I upgrade the Hijack kernel it gets a new lease on a different IP. Prolly a problem with my router tho
So jemplode just sits there and goes "la la la, waiting for reboot" So I have to cancel the window and connect to the empeg on the new address.
For some reason it always get 169 first, and then gets 110.
- Damien - Mk2a 24G Blue SN: 120001043
#151343 - 29/03/2003 10:41 Re: changing IP address [Re: xanatos]
Most DHCP servers will give a device the same lease as long as there's not a big lag between connection attempts (and by big lag I mean like days or weeks). Lease duration is often configurable on the DHCP server, can you check to see?
#151344 - 29/03/2003 11:44 Re: changing IP address [Re: tfabris]
jane
Warning box? Oh. I stopped reading those ages ago ;-)
Marius (Escort Cab + 2CV + Mk2+Mk2a)
#151345 - 29/03/2003 15:55 Re: changing IP address [Re: xanatos]
SE_Sport_Driver
On my router, I locked the empeg's MAC address to a certain IP. So THAT empeg always gets THAT IP. Maybe you can do the same?
Bitt, thanks for the correction on that. It didn't look right when I wrote it but it's one of those things you hear in conversation all the time buy never actually use in writing.
