#147095 - 05/03/2003 17:52 WTF is this?!?!
lectric
Loc: New Orleans, LA
I was trying to install emphatic, edited everything, ran the FTP script, it failed because it said the directory I specified wasn't there, then it did this for five minutes: (had hyperterm hooked up)
c0d6fbe0: a35fbef9 00aa9210 c0d6e000 00000001 c00f2000 c0d6e000 c00f46e8 c00dd3
e8
c0d6fc00: c0d6fc38 c0d6fc3c c0d6fc1c c001d0c0 c001c9d4 00000013 ffffffff 000000
00
c0d6fc20: 00000000 00000001 c0d6e000 c0d6fc4c c0d6fc3c c001d0c0 c001c9b4 000000
0b
c0d6fc40: c0d6fc74 c0d6fc50 c0010298 c001cd38 00aa9280 c0d6e000 c00f46e8 000000
02
c0d6fc60: c0d6fcf8 00000002 c0d6fc98 c0d6fc78 c001164c c0010110 c0d6fcf8 000000
05
c0d6fc80: c0d6e000 c0d6fcf8 00aa9280 c0d6fcd0 c0d6fc9c c0011904 c00115ec c00f46
e8
c0d6fca0: c000ab0c c001e63c c0d6fcf8 00000005 00aa9280 00000003 00000002 000000
13
c0d6fcc0: c00dd3e8 c0d6fcf4 c0d6fcd4 c0011e00 c0011678 ffffffff c0d6fd2c 000000
01
c0d6fce0: c00f2000 c0d6e000 c0d6fd5c c0d6fcf8 c0009d88 c0011d28 c0d6e000 000000
00
c0d6fd00: 00000000 a35fbef9 00aa9210 c0d6e000 00000001 c00f2000 c0d6e000 c0fad1
60
c0d6fd20: c00dd3e8 c0d6fd5c c0d6fd60 c0d6fd40 c001d0c0 c001c9d4 00000013 ffffff
ff
c0d6fd40: 00000000 c0fb62e0 00000001 c0d6e000 c0d6fd70 c0d6fd60 c001d0c0 c001c9
b4
c0d6fd60: 0000000b c0d6fd98 c0d6fd74 c0010298 c001cd38 00aa9210 c0d6e000 c0fad1
60
c0d6fd80: 00000002 c0d6fe1c 00000002 c0d6fdbc c0d6fd9c c001164c c0010110 c0d6fe
1c
c0d6fda0: 00000005 c0d6e000 c0d6fe1c 00aa9210 c0d6fdf4 c0d6fdc0 c0011904 c00115
ec
c0d6fdc0: c0fad160 00000008 c016ac20 c0d6fe1c 00000005 00aa9210 00000003 000000
02
c0d6fde0: 00000093 00000000 c0d6fe18 c0d6fdf8 c0011e00 c0011678 ffffffff c0d6fe
50
c0d6fe00: 00000001 c0105760 c0105700 c0d6fe70 c0d6fe1c c0009d88 c0011d28 000018
00
c0d6fe20: c00f2000 00aa9210 46001a84 00000205 00000001 00000001 c0105760 c01057
00
c0d6fe40: c0d6fee8 00000000 c0d6fe70 c0d6fe74 c0d6fe64 c00162dc c0015c40 000000
93
c0d6fe60: ffffffff c0d6fe9c c0d6fe74 c00162dc c0015c24 00000205 c01153e0 c01153
a8
c0d6fe80: c0105760 c0105700 c0d6fee8 00000000 c0d6feb8 c0d6fea0 c001e6c8 c00162
8c
c0d6fea0: 00000000 00000003 00000060 c0d6fee4 c0d6febc c000ab0c c001e63c fa0500
00
c0d6fec0: c0d6ff30 00000001 c00d9cb8 60000013 ffffffff 00001200 c0d6ff80 c0d6fe
e8
c0d6fee0: c0009dc0 c000a9dc c01c360c be3faa50 00001200 c0000000 c01c360c c01137
74
c0d6ff00: 00000003 c01c480c 00000018 be3faa50 00001200 c0d6ff80 00000018 c0d6ff
30
c0d6ff20: c00c3a18 c00d9cb8 60000013 ffffffff c01c360c 00001200 c01c360c c01137
74
c0d6ff40: 00000003 c01c480c c00c3a18 00000000 c0d6e000 c01137a4 c09568cc c0fb05
00
c0d6ff60: ffffffea 00000000 00001200 00000002 be3faa50 c0d6ffb0 c0d6ff84 c0030a
6c
c0d6ff80: c00c3818 021426f0 c000a1a8 00000022 c000a1a8 00000004 c0d6e000 c0d6ff
f4
c0d6ffa0: be3faa50 00000000 c0d6ffb4 c000a000 c0030928 00000022 00000022 be3faa
50
c0d6ffc0: 00001200 00000000 00000022 be3faa50 00001200 00001294 00001200 000000
02
c0d6ffe0: be3faa50 be3faa10 be3fa9f4 be3fa9f4 020b55a0 020e4b84 60000010 000000
22
Backtrace: frame pointer underflow
Function entered at [<c002a7b4>] from [<c0012fb8>]
r7 = C0D6E000 r6 = C0105B40 r5 = C0115460 r4 = 00000004
Function entered at [<c0012f68>] from [<c001d098>]
r6 = 00000001 r5 = C0D6E2A4 r4 = 00000000
Function entered at [<c001cd2c>] from [<c0010298>]
Function entered at [<c0010104>] from [<c001164c>]
r10 = 00000000 r8 = C0D6E2C8 r7 = 00000000 r6 = C0011E00
r5 = C0D6E000 r4 = 00000011
Function entered at [<c00115e0>] from [<c0011904>]
r8 = 00000011 r7 = C0D6E2C8 r6 = C0D6E000 r5 = 0000000F
r4 = C0D6E2C8
Function entered at [<fffffff4>] from [<c00f46e8>]
Code: e129f003 e3a02000 (e5822000) e91ba8f0 e1a01005
Aiee, killing interrupt handler
Unable to handle kernel paging request at virtual address 000a63de
memmap = C0004000, pgd = c0004000
*pgd = c0120801, *pmd = c0120801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c001c9d4>] lr : [<c001d0c0>]
sp : c0d6e0ac ip : c0d6e0cc fp : c0d6e0c8
r10: c00dd3e8 r9 : c00f46e8 r8 : c0d6e000
r7 : c00f2000 r6 : 00000001 r5 : c0d6e000 r4 : 000a636e
r3 : 3230300a r2 : 00000000 r1 : c0d6e0b8 r0 : c0d6e000
Flags: nzcv IRQs on FIQs on Mode SVC_32 Segment kernel
Control: C000517D Table: C000517D DAC: 00000015
Process (pid: 0, stackpage=c0d6d000)
Stack:
Backtrace:
Function entered at [<c001c9a8>] from [<c001d0c0>]
r7 = C0D6E000 r6 = 00000001 r5 = 00000000 r4 = 00000000
Code: e1540003 0a000013 (e5943070) e1530005 1a00000d
Kernel panic: Attempted to kill the idle task!
In interrupt handler - not syncing
I grabbed the tail end of it. The empeg screen said remounted in read only mode, and did nothing else. I cycled power, and all appears well. But is it really?
#147096 - 05/03/2003 18:13 Re: WTF is this?!?! [Re: lectric]
lectric
Update... It happens everytime I "quote site ro" in FTP.
#147097 - 05/03/2003 18:23 Re: WTF is this?!?! [Re: lectric]
Sounds similar to a bug in an old version of Hijack. What Hijack version is running on there now?
#147098 - 05/03/2003 18:34 Re: WTF is this?!?! [Re: tfabris]
genixia
If you're running HJ < v300, and you have 2 drives in your empeg, and you have both /dev/hda4 and /dev/hdc4 set up to mount on /programs0 and /programs1 then you will encounter a buffer overrun when remounting ro from kftpd or khttpd. You can work around it by using the serial (or telnet) prompt to run the binary 'ro' (and 'rop') and not using kftpd or khttpd to 'ro'. Simpler and better is to upgrade HJ to the latest and greatest.
#147099 - 05/03/2003 18:48 Re: WTF is this?!?! [Re: tfabris]
lectric
Hmm... was running 292. Am running 320 now.
Lesse if it happens again.
#147100 - 05/03/2003 18:50 Re: WTF is this?!?! [Re: lectric]
lectric
Nope... all fine. Phew... Thanks guys. Just freaked for a sec.
