Right had a good look at the board, a couple of joints re-done, but still no joy. Are there any diagnostic tests I can do, managed to get a serial connecter in,
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg51-hijack-v291 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Wed Jul 31 10:10:42 EDT 2002
empeg-car player (hardware revision 9, serial number 10101731)
Command line: mem=16m
Memory: 15076k/16M available (928k code, 20k reserved, 356k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Found custom animation at offset 0x9877c
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005780).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25N040ATCS04-0, ATA DISK drive
hdb: TOSHIBA MK2018GAS, ATA DISK drive
hda: IC25N040ATCS04-0, 38154MB w/1768kB Cache, CHS=4864/255/63
hdb: TOSHIBA MK2018GAS, 19077MB w/0kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:22:06:c
3
Partition check:
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
Starting player
empacman running as pid 21
/etc/preinit.d/M20emptris: /programs0/emptris: No such file or directory
/etc/preinit.d/M30emptriv: /programs0/emptriv/emptriv: No such file or directory
Vcb: 0x4086d000
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 5673
33, error=0xc0044000
