#133046 - 04/01/2003 09:32 PHP Gallery, just a quickie....
I want to move a gallery from one linux machine to another, can I achieve this by simply tarring the gallery folder and putting on the other, suitably apached and PHP'ed machine?
#133047 - 04/01/2003 09:45 Re: PHP Gallery, just a quickie.... [Re: andym]
Probably, gallery just stores it's data in simple files.
#133048 - 04/01/2003 09:53 Re: PHP Gallery, just a quickie.... [Re: andy]
the file structure on both machines will be identical (ie everything in a /www/htdocs folder) if gallery uses flat files for its config then there shouldn't be a problem.
#133049 - 04/01/2003 13:35 Re: PHP Gallery, just a quickie.... [Re: andym]
I'd recommend putting it in "config" mode before you do this, then when untarring it on the other machine, put it back in "secure" mode. That way file permissions are set correctly, and also you won't need to be root to tar it up.
