#108410 - 30/07/2002 13:04 charcoalgray99's empeg web interface v1.3
charcoalgray99
"empeg web interface" is a add-on that provides a web interface to control various features of your empeg via Hijack's built-in khttpd server.
New in this version:
  • Popup windows for the remote, display, and now playing info
  • Support for the new Insert/Enqueue/Append serial commands
  • Popup Tune Info shows detailed information for a single tune (click the music note icon)
  • Now playing info automatically refreshes (thanks Aragon!)
  • Now playing shows an appropriate error message if notify=1 is not enabled
  • Almost all files moved to /drive0/opt/khttpd/charcoalgray99/ for a cleaner root directory
Please visit the website to download, read the requirements and installation notes.
empeg web interface
Tom
#108411 - 30/07/2002 16:51 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Rod
Loc: Australia
VERY nice update .
Thanks.
#108412 - 30/07/2002 16:58 Re: charcoalgray99's empeg web interface v1.3 [Re: Rod]
Yeah, this essentially kicks butt. I especially like the tear-off remote control, quite spiffy.
Yesterday he was sending me preview builds of the files and we ironed out some things. Was fun...
#108413 - 30/07/2002 17:11 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
matthew_k
Sweet, I'll have to haul my player inside. The only thing the last one really needed was insert/append, as the web interface rocks for finding the song you were looking for.
#108414 - 30/07/2002 17:19 Re: charcoalgray99's empeg web interface v1.3 [Re: matthew_k]
And this feature wasn't available to external apps until beta13, hence the fact that it didn't appear until now.
#108415 - 30/07/2002 17:40 Re: charcoalgray99's empeg web interface v1.3 [Re: tfabris]
matthew_k
Yeah, I know it wasn't Charcoalgray's fault... I'm just glad it's there now :-)
#108416 - 31/07/2002 07:28 Re: charcoalgray99's empeg web interface v1.3 [Re: matthew_k]
Yuh, that feature was my fault. It's what I asked for (from SB) in trade for the "jiffies fix" in the kernel.
#108417 - 31/07/2002 07:48 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Excellent - can't wait to get home and try this out. Wonder whether it'll fix my playlists issue with v1.2?
Here's hoping.
#108418 - 01/08/2002 00:34 Re: charcoalgray99's empeg web interface v1.3 [Re: frog51]
Hmm, I must be doing something wrong - I deleted all my old xsl stuff and ftp'ed this new set on. Everything works fine, including the detachable windows etc, but when I click on playlists I get the same error I used to get with 1.2 (well, it's a little bit more of the same error)
Can anyone think of a cause for this?
#108419 - 01/08/2002 01:04 Re: charcoalgray99's empeg web interface v1.3 [Re: frog51]
charcoalgray99
What version of IE is that?
Tom
#108420 - 01/08/2002 01:10 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Version 5.5. Whatever revision comes with Win2k. Re your comment in the other thread about XML core services 4.0 I will download it and check this evening if I have the latest version.
As I say, everything else works beautifully.
#108421 - 01/08/2002 01:12 Re: charcoalgray99's empeg web interface v1.3 [Re: frog51]
charcoalgray99
That should fix it.
IE5.5 ships with the "working draft", the update is required for documents using XSLT 1.0 spec.
Tom
#108422 - 01/08/2002 01:52 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Dava
Loc: Bucks UK
Just tried it and it looks great. Good effort.
I find that the update of the display is a little slower than my old version of a web interface so I took a delve into your Java refresh routine and changed the values. Is there a specific reason you chose 2500 as the default? I changed it to 200 and it works fine. Could this have implications I am not aware of?
MK2 smoked 32Gb S/n 090000949 MK2a Blue 20GB racked and out of sync
#108423 - 01/08/2002 03:33 Re: charcoalgray99's empeg web interface v1.3 [Re: frog51]
Aragon
Loc: Cape Town, South Africa
Hi frog51,
My Win2k shipped with IE 5.0 which needed the XML upgrade to be installed. I'm using MSXML 3.0 which works cool.
Regards,
Aragon
#108424 - 01/08/2002 07:11 Re: charcoalgray99's empeg web interface v1.3 [Re: Aragon]
This all sounds very positive. I'll install the XML core package tonight and give you an update tomorrow.
Cheers for the advice
#108425 - 01/08/2002 07:22 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Dava
Loc: Bucks UK
The playlists work fine on mine but I have problems with the FTP Browser. I get a "Page cannot be displayed" error. If I type ftp://empegip/ into the address bar then no problem.
What could this be??
I am on IE 6.0.2600.0000.
#108426 - 01/08/2002 10:00 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
Tom, may I suggest that your web page be more strongly worded with regard to the XML parser.
Perhaps a little warning box along these lines:
"If you are running IE 5.5 and you see strange code on the screen such as EEEEEE FFFF ?fid=&ext.m3u, then you do not have the proper XML core services installed. Please click here to install them."
#108427 - 01/08/2002 11:04 Re: charcoalgray99's empeg web interface v1.3 [Re: tfabris]
charcoalgray99
Thanks Tony, I added that.
Tom
#108428 - 01/08/2002 11:10 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
#108429 - 01/08/2002 13:04 Re: charcoalgray99's empeg web interface v1.3 [Re: Dava]
FlibblE
Loc: UK - NE Wales
I get strange things in the ftp bit too. In the root I've got a file with a name made up of three unprintable characters. Also I seem to have a file called 'D' in my /usr/local directory.
Any ideas what these are? do they really exist!
#108430 - 01/08/2002 13:53 Re: charcoalgray99's empeg web interface v1.3 [Re: FlibblE]
Yeah, we went back and forth with Mark on that one for a while.
It's Microsofts' bug. When using their FTP browser enhancements, every folder will have a nonexistent file that looks like a shortcut, but with random characters in its file name.
Microsoft isn't following the standard for communicating with the FTP server. Mark's FTP Daemon is following the standard, which is somehow confusing Microsoft and there's that extra entry appearing. At least that's how I understand it to be.
Tom, you might want to mention THAT on the web page, too.
The fact that the characters in the icon name are random hunks of memory makes me think that the potential for a buffer overflow exploit exists there somewhere....
#108431 - 02/08/2002 03:55 Re: charcoalgray99's empeg web interface v1.3 [Re: tfabris]
FlibblE
Loc: UK - NE Wales
'Microsoft isn't following the standard for communicating with the FTP server'
Hehe, sounds like Microsoft!
#108432 - 03/08/2002 17:47 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
AndrewT
Loc: Oxford, UK
I have a problem streaming via the web interface. Windows media player doesn't play any audio and after approx. 30 seconds the playlist sidebar displays what appears to be the .mp3 file in text form as shown in the attachment.
At the same time as WMP starts displaying the .mp3 data I get khttpd messages on the serial port:
khttpd: open(/à) failed, rc=-2
khttpd: open(/B) failed, rc=-2
khttpd: open(/ý
!À) failed, rc=-2
khttpd: open(/€) failed, rc=-2
khttpd: open(/ Z+å“Ÿ>ŠbUs¤k) failed, rc=-2
khttpd: open(/I
ØÏQ¥Èè,QçG÷LŽNAgËœU.F­Æ’(ISD¡â€¢Ð”) failed, rc=-2
khttpd: open(/jpˆ/(„%) failed, rc=-2
I am using 2.0b13, Hijack291 & empeg web interface 1.3. The PC uses XP, IE6.0, MSXML4.0 & WMP8.0.
I have added the following lines to a stock config.ini:
[output]
notify=1
[serial]
car_rate=115200
[hijack]
suppress_notify=1
Does anyone have any idea why this isn't working?
#108433 - 03/08/2002 19:15 Re: charcoalgray99's empeg web interface v1.3 [Re: AndrewT]
charcoalgray99
Do you notice the same problem when streaming from the regular hijack interface? http://empeg/?playlists
Tom
#108434 - 04/08/2002 15:21 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
AndrewT
Loc: Oxford, UK
I'd never tried that before. Yes, it's exactly the same - so the web interface obviously isn't a part in what's going wrong?
#108435 - 04/08/2002 16:19 Re: charcoalgray99's empeg web interface v1.3 [Re: AndrewT]
charcoalgray99
It seems like a bug in the way media player is requesting the stream, or the way hijack is sending it. I'm sure Mark doesn't test with Media Player. I've always used winamp, but I just fired up WMP8 to test this out. Everything seems to work fine for me.
Just thinking out loud... Could it be a problem with file associations? Maybe install winamp, test that out, then reinstall WMP and see if the problem goes away.
Tom
#108436 - 04/08/2002 16:40 Re: charcoalgray99's empeg web interface v1.3 [Re: tfabris]
djc
Loc: chicago
hmm, i don't think this is the solution. i'm running win2k pro, sp3, ie5.5, and the latest MSXML parser. i still get the symptoms shown above.
any other ideas?
thanks,
--dan.
#108437 - 04/08/2002 17:24 Re: charcoalgray99's empeg web interface v1.3 [Re: charcoalgray99]
AndrewT
Loc: Oxford, UK
Excellent, it worked straight away with Winamp To be honest I loathe WMP and had already made a mental note to install Winamp at some stage anyhow.
While I didn't re-install WMP, I did remove Winamp's associations thereby allowing WMP to become the default streaming app again and it was the same as before.
It now also works with your web interface so for my part, the problem is fixed and I'm VERY HAPPY with the outcome, thanks for all your help
In the wider scheme of things I'd be happy to help diagnose this further but I think I was the only person who experienced it so there's no need I guess.
#108438 - 05/08/2002 00:03 Re: charcoalgray99's empeg web interface v1.3 [Re: djc]
charcoalgray99
I'm not really sure what to say. Did you double check to make sure your running a 3.0+ xml parser? Maybe try upgrading to IE6?
Tom
#108439 - 06/08/2002 00:39 Re: charcoalgray99's empeg web interface v1.3 [Re: frog51]
Took me a while to get it sorted (Microsoft issue) but upgrading XML has got me sorted. No EEEEEEEEE errors
Thanks guys.
