Possibly the FAQ needs updating regarding
How do I edit the 'config.ini' file on the player? now 2.0b13 has arrived?
In the FAQ it explains you should add a
New DWORD value named allow_edit_config with a value of 1 to:
HKEY_CURRENT_USER
Software
SONICblue
emplode
2.0
Settings
With 2.0b13 you also now have to create the key
Settings below
2.0 before you create the key
allow_edit_config beneath it. This is not to be confused with the new key at a higher level named
Settings - creating the sub-key
allow_edit_config there doesn't work.
