(gulp)
I haven't had the need to make any player changes until today. I tried Emplode ... and ... got a sync error (this is through ethernet, which I never have a problem with).
It already rebooted, so I went into Hyperterminal and dropped to shell. Then I rebooted again and got this (insert shudder here).
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux....................................... done, booting the kernel.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v269 (root@tbird.localnet) (gcc version 2.95.3 20010315 (release)) #2 Fri May 24 13:37:12 EDT 2002
empeg-car player (hardware revision 9, serial number 30103046)
Command line: mem=16m
Memory: 14952k/16M available (1040k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004b80).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: ÉBÍ-ÄJÓA­2²0                           , ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: ÉBÍ-ÄJÓA­2²0                           , 24191MB w/18258kB Cache, CHS=49151/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:e6
Partition check:
hdb: hdb1 < > hdb2 hdb3 hdb4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Mounting proc
VFS: Can't find an ext2 filesystem on dev ide0(3,68).
Tried to mount /dev/hdc4 but got error 22
No secondary hard disk
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting player
hijack: removed menu entry: "Hard Disk Detection"
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
-- JD - SN# 040104008 (120GB Blue, Digital Out)
