edit: Don't bother now, I'm not getting them with v263
Oops, sorry, here's the whole log of that session:
e000 v1.04
Copying kernel...
Calling linux kernel...
Uncompressing Linux...................................... done, booting the kern
el.
Linux version 2.2.14-rmk5-np17-empeg50-hijack-v262 (root@tbird.localnet) (gcc ve
rsion 2.95.3 20010315 (release)) #2 Mon Apr 22 09:16:18 EDT 2002
empeg-car player (hardware revision 9, serial number 40104087)
Command line: mem=16m
Memory: 14984k/16M available (1012k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 67706d65 'empg'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005100).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IC25T048ATDA05-0, ATA DISK drive
hda: IC25T048ATDA05-0, 45780MB w/1806kB Cache, CHS=5836/255/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:28:0f:f
7
Partition check:
hda:hda: set_geom(16383,16,63)
hda1 < hda5 hda6 > hda2 hda3 hda4
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init
empeg-preinit starting...
empeg-preinit complete
empeg init 0.8
Mounting proc
No secondary hard disk
Starting player
khttpd: listening on port 80
kftpd: listening on port 21
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4086d000
serial_notify_thread.cpp: 116:@@ N37
serial_notify_thread.cpp: 117:@@ F0xd520
serial_notify_thread.cpp: 118:@@ TBlack Mage Village
serial_notify_thread.cpp: 119:@@ ANobuo Uematsu
serial_notify_thread.cpp: 120:@@ GSoundtrack
serial_notify_thread.cpp: 180:@@ #d520 0:01:02
serial_notify_thread.cpp: 170:@@ S0
! mp3_decoder.cpp :1049:Failed to find valid sync after seeking to offset 1350
148, error=0xc0044000
h
Adding Swap: 16028k swap-space (priority -1)
e2fsck 1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/
hda4 is mounted.
Unable to handle kernel paging request at virtual address c1001f40
memmap = C0F14000, pgd = c0f14000
*pgd = 00000000, *pmd = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c0045164>] lr : [<c004512c>]
sp : c07b7ec4 ip : 00000001 fp : 00000000
r10: 00000100 r9 : c052a400 r8 : 01a32c7a
r7 : 00000d19 r6 : c0ffea00 r5 : 00002000 r4 : 01a32c79
r3 : c0ffeadc r2 : 60000000 r1 : 00002000 r0 : 00000c79
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Control: C0F1517D Table: C0F1517D DAC: 00000015
Process player (pid: 21, stackpage=c07b7000)
Stack:
c07b7ea0: c004512c c0045164 600000
13
c07b7ec0: ffffffff c0030bfc c0ffea30 00000000 00000c79 0000000c 01a32c79 000000
00
c07b7ee0: 01a32d79 c0e20660 c023c980 00000100 00000100 c036f3fc c004d294 000000
00
c07b7f00: 00000002 00000100 01a32c7a 00000000 00000000 c0e2072c 00000000 c0e206
60
c07b7f20: 00000000 c0e20730 c0e2072c be3ffcd4 c012bbe8 c004d6a8 c0e20660 c0e206
60
c07b7f40: c0e20660 00000000 c0e187c0 c0365000 021a87e0 c0047edc c010c4c4 c00406
0c
c07b7f60: c07e8440 c0e20660 c004aba8 c0e187c0 c023cb60 c036b02c c07e8440 c0e187
c0
c07b7f80: 00000000 c07e8440 c0039c80 c0e18c40 fffffffe c0e187c0 c0039d34 be3ffb
f0
c07b7fa0: c000a108 0000000a c07b6000 c07b7ff4 c0009f60 be3ffbf0 0210cd28 000000
01
c07b7fc0: 00000000 00000000 be3ffbf0 0210cd28 00000000 be3ffcd4 be3ffd30 be3ffc
d4
c07b7fe0: 021a87e0 be3ffc08 be3ffb8c be3ffbf0 02015734 020e2744 60000010 0210cd
28
Backtrace: no frame pointer
Code: 1a000004 e28630dc (e7932107) e3520000 13a02000
Restored terminal settings
Edited by BAKup (28/04/2002 19:43)
--Ben
78GB MkIIa, Dead tuner.
