Hi Muzza.
As far as I understand it, this happens as a result of a timing problem. The controller for the buttons is the same chip that also controlls the backlight LEDs. When a button is pressed, any other task this controller is, well, controlling gets delayed. And as the leds' brightness level is controlled using a pulse length modulation, a button press leads to a flicker of the led.
cu,
sven
proud owner of MkII 40GB & MkIIa 60GB both lit by God and HiJacked by Lord
