The serial port on the car player works at 115200 bps when it's using the AC adapter (home power). When it is plugged into the car docking sled (car power), the serial port works at 4800 bps for compatibility with certain other in-car devices equipped with serial ports.
Unless you are doing something special with the serial port in a car installation, there is no need to change its speed. For what reason did you want to change the serial port speed?
