Ok, redid this test without the hijack image... I also commented out the IR remappings from the INI file I was using with hijack.
This time it rebooted after being in standby for about 51 minutes and I saw the player go through the reboot sequence. This time, the player seems to still work normally after the reboot.
Hyperterminal output is below. Again, everything up to the line "Vcb: 0x4054d000" occurred during the regular boot sequence. The error after that occurred about 51 minutes later.
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.14-rmk5-np17-empeg50 (mac@aphex.internal.empeg.com) (gcc version 2.95.3 20010315 (release)) #7 Fri Feb 8 18:45:38 GMT 2002
empeg-car player (hardware revision 7, serial number 90001020)
Command line: mem=12m
Memory: 10968k/12M available (964k code, 20k reserved, 332k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 636f6972 'rioc'
Scheduling custom logo.
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0004680).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
hda: IBM-DJSA-220, ATA DISK drive
hdb: IBM-DJSA-220, ATA DISK drive
hda: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
hdb: IBM-DJSA-220, 19077MB w/1874kB Cache, CHS=38760/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:12:03:fc
Partition check:
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...
Mounting proc
Press 'q' now to go into development mode. You Have Zero Seconds To ComūStarting player
player.cpp : 385:empeg-car 2.00-beta11 2002/02/08.
Prolux 4 empeg car - 2.1434 Feb 7 2002
Vcb: 0x4054d000
player(21): memory violation at pc=0x0207a170, lr=0x02072800 (bad address=0x043474b0, code 0)
pc : [<0207a170>] lr : [<02072800>]
sp : bdfffc08 ip : bdfffc18 fp : bdfffc14
r10: 00000020 r9 : 00000000 r8 : 0214abf0
r7 : 02191558 r6 : 00000000 r5 : 021664e0 r4 : bdfffc64
r3 : 021a3760 r2 : 00000000 r1 : 021a3d50 r0 : bdfffc64
Flags: nzCv IRQs on FIQs on Mode USER_32 Segment user
Control: D038117D Table: D038117D DAC: 00000015
Function entered at [<0207a158>] from [<02072800>]
Function entered at [<020727d4>] from [<0201a564>]
r4 = 02115F3C
Function entered at [<0201a0c4>] from [<02066500>]
r10 = 0214AB4C r9 = BDFFFD0C r8 = BDFFFD20 r7 = 0214ABF0
r6 = 02164F04 r5 = 00000001 r4 = 02164E60
Function entered at [<02066470>] from [<020634c4>]
r7 = BDFFFD1C r6 = 0214AA70 r5 = 0214ABF0 r4 = 0214AA70
Function entered at [<02063468>] from [<02063c4c>]
r5 = 0214AB4C r4 = 0214AA70
Function entered at [<02063c20>] from [<02063f68>]
r4 = 00000000
Function entered at [<02063d2c>] from [<02063c84>]
r10 = 020A9A14 r9 = 0214AA70 r8 = 0000340E r7 = 00000080
r6 = 0000000E r5 = 0214AA70 r4 = BDFFFD64
Function entered at [<02063c74>] from [<020a9acc>]
Function entered at [<020a9a14>] from [<020aecc8>]
r5 = 0214AA88 r4 = BDFFFE40
Function entered at [<020aec00>] from [<020e3fec>]
r4 = 00000000
Function entered at [<020e2760>] from [<020aea44>]
r8 = 0215044C r7 = 02150438 r6 = 020A9A14 r5 = 00000007
r4 = 00000000
Function entered at [<020ae994>] from [<020e3fec>]
r5 = 00000000 r4 = 00000000
Function entered at [<021a2394>] from [<00000003>]
Unable to handle kernel paging request at virtual address 0000fff4
memmap = D0380000, pgd = c0b80000
*pgd = d0392801, *pmd = d0392801, *pte = 00000000, *ppte = 00000000
Internal error: Oops: 2
CPU: 0
pc : [<c00dfba4>] lr : [<c0019670>]
sp : c0641f44 ip : c0641f00 fp : c0641f90
r10: 00000000 r9 : c0baf0e0 r8 : 0000000c
r7 : 00000000 r6 : 021a2394 r5 : 00010000 r4 : 00010000
r3 : 00004342 r2 : 001d25bb r1 : 021a1100 r0 : bffffbf8
Flags: nZCv IRQs on FIQs on Mode SVC_32 Segment user
Process player (pid: 21, stackpage=c0641000)
Stack:
c0641f20: c0019670 c00dfba4 60000013
c0641f40: ffffffff c0baf0f8 c0bae2a0 c0640000 c0641fb8 043474b0 c0011948 02072800
c0641f60: 043474b0 00000000 c0641fb8 00000005 043474b0 00000000 00000000 00000000
c0641f80: 00000020 c0641fb4 c0641f94 c0011e80 c00116f8 c00fc978 021664e0 00000000
c0641fa0: 02191558 0214abf0 00000000 c0641fb8 c000a008 c0011da8 bdfffc64 021a3d50
c0641fc0: 00000000 021a3760 bdfffc64 021664e0 00000000 02191558 0214abf0 00000000
c0641fe0: 00000020 bdfffc14 bdfffc18 bdfffc08 02072800 0207a170 20000010 ffffffff
Backtrace:
Function entered at [<c00116ec>] from [<c0011e80>]
r10 = 00000020 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 043474B0 r5 = 00000005 r4 = C0641FB8
Function entered at [<c0011d9c>] from [<c000a008>]
r8 = 0214ABF0 r7 = 02191558 r6 = 00000000 r5 = 021664E0
r4 = C00FC978
Code: e1140007 1afffff7 (e814000f)
Abnormal player termination
Player received signal 11
Starting player
Vcb: 0x4054d000
