Hi all. Wanted to post this to the group to see if anyone else has had a similar problem.
After reading a load of posts about Displayserver, I wanted to fire it up on my mk2. (Background: have had empegs since Mk1 serial: 00042. Recently started getting back into the cool extras of the hardware / software). I originally had Developer image 1.01 and installed ds2b2 with no problem (didn't add custom kernel). I found that I was having a problem with the getfid function, which are what the Index test1 and test2 links call. I upgraded to the developer image 1.03 and tried again (with the custom kernel), got the same results. Haven't tried the 2.0 beta images yet... Here are details of the problem.
When I click on Index test1 or Index test2, I get a blank page in the browser and error messages on the empeg over the serial line as follows:
ds2: memory violation at pc=0x40073894, lr=0x40073638 (bad address=0x00000000, c
ode 2)
pc : [<40073894>] lr : [<40073638>]
sp : bfffd688 ip : 400ff764 fp : bfffd69c
r10: 00000000 r9 : 00000000 r8 : 00000000
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : 00000000
r3 : 00000000 r2 : 020086c0 r1 : 00000000 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode USER_32 Segment user
Control: C823D17D Table: C823D17D DAC: 00000015
Function entered at [<40073624>] from [<02004414>]
r5 = 00000000 r4 = 00000000
Function entered at [<0200416c>] from [<02006808>]
r10 = 400FF128 r9 = 02007F08 r8 = 02008230 r7 = 02000CB0
r6 = 4000C2A8 r5 = 00000001 r4 = 02011EE4
Function entered at [<02004a14>] from [<020073a4>]
Function entered at [<020072a4>] from [<02007eb0>]
Function entered at [<02007b54>] from [<02008148>]
Function entered at [<02007f08>] from [<40037040>]
r4 = BFFFFE24
Function entered at [<40036ee4>] from [<0200111c>]
r10 = 4001D858 r9 = 00000000 r8 = 00000000 r7 = 00000000
r6 = 020010F8 r5 = 00000000 r4 = 4001E5EC
I'm attaching the html output (actually just javascript). Interestingly, the next Playlist that was to be setup in the script was called
_Singles. I wondered about the _, so I took it out, then the output changed, in fact, it ended even earlier at fidinfo[18][8], which it got past before, not sure if that helps.
Thanks,
Chris
49547-getfid[1].txt (219 downloads)
