I am having a problem getting a new 48gig hard disk to install. The old 10gig still works fine in this Rio v2a, and I just upgraded it to 2.00b3 without a problem. With (only) the new disk installed, I ran the new builder program ( 20011022 ) and that appeared to run ok ( left it testing disk for >1 hour ). But now when I try and install either consumer or developer images, it runs for a while, but during one of the final reboots I get :
Error "Bad pump response to device select" occurred during stage 0x20
On the Rio display ( after the above error ) the player finishes rebooting and says
Builder Image
Drive(s) appear to be already built.
Below is a log from a boot of the drive now :
to upgrade the flash, let them speak now,
e000 v1.04
Copying kernel...
Calling linux kernel...
l.
Linux version 2.2.14-rmk5-np17-empeg49 (mac@aphex.internal.empeg.com) (gcc versi
on 2.95.3 20010315 (release)) #127 Wed Oct 17 16:02:35 BST 2001
empeg-car player (hardware revision 9, serial number 10101911)
Command line: mem=16m
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg usb ive to d0005000).
empeg RDS driver initialised
empeg single channel IDE
Probing primary interface...
e
ve
hda: IC25T048ATDA05-0, ATA DISK drive
e
hda:
nter pump...tDrive(s) appear to be already built. Skipping.
Press return to continue anyway - anything else to start a shell.
q
bash-2.01# ls -l
total 24
1024 Nov 26 1999 dev
drwxr-xr-x 5 0 0 1024 Feb 9 11:38 drive0
drwxr-xr-x 2 0 0 1024 Jun 2 1999 drive1
drwxr-xr-x 4 0 0 1024 Jul 12 1999 empeg
drwxr-xr-x 2 0 0 024 Jun 19 1999 etc
drwxr-xr-x 2 0 0 1024 Jun 7 1999 lib
drwxr-xr-x 2 0 0 12288 Oct 22 2001 lost+found
drwxr-xx 2 0 0 1024 Jun 2 1999 mnt
drwxr-xr-x 2 0 0 1024 Jun 2 1999 proc
drwxr-xr-x 2 0 0 1024 Au 8 2000 sbin
drwxr-xr-x 2 0 0 1024 Apr 13 1999 tmp
drwxr-xr-x 3 0 0 1024 Jun 1 1999 usr
bash-2.01#
Any suggestions ?
Rod, UK
