Alright, D10. So, I need to lift pin 9 on the LAN91C96. Thanks again.
I think I might even have come ChipQuik left over from another project, but I usually put in ~$200-$300 worth in a Mouser order almost quarterly. Couldn't hurt to have more.
Here's the whole log. No other glaringly obvious issues to me, but you're the pro. It even seems to recognize the extremely fragile CS4231A...
e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg55-hijack-v518 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Tue Jun 3 14:28:51 EDT 2014
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102293) 16MB DRAM
Command line: mem=16mCalibrating delay loop... 207.67 BogoMIPS
Memory: 15000k/16M available (996k code, 20k reserved, 364k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 206f6972 'rio '
Tuner: loopback=0, ID=-1
show_message("Hijack v518 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg remote control/panel button initialised
empeg state support initialised 0089/88c1 (save to d0005b80).
empeg RDS driver initialised
RAM disk driver initialized:  16 RAM disks of 4096K size
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0400
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0xffff read 0x0400
ide_data_test: wrote 0x0000 read 0xfbff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xfbaa
ide_data_test: wrote 0x5555 read 0xff55
hda: SAISQNC IZIT@216HACM)00004, ATA DISK drive
hda: SAISQNC IZIT@216HACM)00004, 7559MB w/0kB Cache, CHS=15359/16/63
smc chip id/revision 0x3349
smc_init couldn't find card
Partition check:
 hda: hda1 < hda5 > hda2 hda3 hda4
RAMDISK: Loading 320 blocks [1 disk] into ram disk... |/-\|/-\|/-\|/-\|/-\done.
empeg-pump v0.03 (19980601)
Press Ctrl-A to enter pump...Kernel panic: VFS: Unable to mount root fs on 03:05
