Originally Posted By: aTTila
One thing I wish mhddfs would do by default, is to keep leaf nodes grouped together on the same underlying drive/filesystem. Eg. If I have a directory called "Top Gear", then ideally all Top Gear episodes should be kept together within that directory on a single underlying drive, rather than potentially being scattered across multiple underlying drives.
Dunno, why, but that's just how I'd like it to work, and so I've patched my copy here to do exactly that.
Hi mlord, are you able to provide your patch changes? I would also like mhddfs to function like this and only write a new directory path to another drive when the original source drive is full
Patch attached.
01_group_files_on_same_fs.patch (315 downloads)
Description: mhddfs patch to group leaf files from same subdir onto same drive.
