Hi.
I agree that we should install additional software on /drive0/<something>, I also agree that we should find a way to set up different programs depending on the different physical environments (in car/at home etc.). I don't know wether the different tuner-module-IDs will be available before the player gets first started, but that could be handled by starting a background job that first waits a certain amount of time (e.g. 10 seconds) and than checks for the ID. I will try to suggest a certain layout now, based on my thoughts about this subject. One thing though: I do think that we don't need any kill scripts, because in my opinion, this would simply be overkill. The environment does not change while the empeg is powered up, so a different startup, based on the current environment should be enough. Ok, here is my suggestion:
locationdescription
/usr/locala link to /drive0/local
/drive0/local/init.dcontains all startup scripts that are currently installed
/drive0/local/init.d/car/links to each startup script that should be called on bootup when in car
/drive0/local/init.d/car/<id>/links to each startup script that should be called on bootup, but only when the <id> is already read from the tuner module
/drive0/local/init.d/car/delayed/links to scripts that should be run when in car, but only after the player got started already
/drive0/local/init.d/car/delayed/<id>/links to each startup script that should be called on bootup, but only when the <id> is already read from the tuner module and the player has already been started
/drive0/local/init.d/home/links to script that should be started when on AC power (at home)
/drive0/local/init.d/home/delayed/links to scripts that should only be started after player startup, when at home
/drive0/local/reconfiga script that re-enables this layout after a player upgrade
/drive0/local/<package>/directory that contains all files of a certain package, layout below this directory is up to the respective packages developer, but should use .../bin/ for the executables, .../etc/ for the configuration files and .../lib/ for everything else.
/sbin/init.origa backup of the original init script
/sbin/initour custom init script that supports the above layout
/drive0/local/bin/contains generally available tools such as sort, tr, wc, du,...
The links to the real init scripts should be named <id><package>, where <id> is a two digit decimal number, where the lowest <id> gets started first.
What do you think?
proud owner of MkII 40GB & MkIIa 60GB both lit by God and HiJacked by Lord
