Anyone tried to use a PATA-to-SATA adapter yet with the 250GB or larger 2.5 inch SATA drives?
My attempt has been unsuccessful so far, using a WD2500BEAS SATA drive + adaptor.
The attached is the output immediately after running builder_bigdisk_v6.upgrade - are there any obvious errors?
Output following builder_bigdisk_v6.upgrade.txt (378 downloads)
Edited by jarob10 (02/06/2010 06:11)
A coward you are, an expert on bulls you are not.
