finally i've decided it's time for the empeg to stop hiding under the tv and for it to go in the car instead, in the past i've installed plenty of stereo's but, normally stuck with amp'd rear speakers and sub or, 4 head unit driven speakers and an amp'd sub. easy, however, it's been far too long since i've done anything other than plug in a head unit!
so, i have a toyota lucida (estima, previa etc), a big mpv basically. i want sound front and rear + sub. i've got a pair of amps to run the front and rear speakers and i can see how they connect to the car cage phono plugs, but, how do i connect the 10" sub which has it's own amp too? i'm guessing the aux cable but, i'm not sure if that's aux in or out!
before ice got technical i used to run a pair of 6x9's off a 2channel bridgable amp, the sub also ran from the bridgable terminals via a crossover thing but, i was told later that this was not advisable, so i'm a bit stuck.
i'm not into all the mid range and tweeters, spare batteries and all that so simple will do! 1pr 6-8" front door speakers, pair of 6x9 rears (i think) and a sub,
i know there's a simple answer but my head isn't playing ball lately!
appreciate a simple answer!
thanks.
Hugh
www.dragon-signs.com
