And if you run it a second time? I seem to recall that your problem only seems to appear the second time.
Correct. If I get mspaint to open by running the batch file or by opening and closing mtpaint, it will only open once, after that it will not open again. Also, rebooting does not change things.
EDIT:
OK -- additional data: Running the batch file a second time does NOT open mspaint, and in fact the batch file stalls in the middle and the log file is only partially written. I am attaching the log file again, as the second log is appended to the first and you can see the point where the process quit while trying to start mspaint. Hopefully this will prove to be an "aha moment".
db
SECOND EDIT:
Now mspaint will not open no matter what I do. The mtpaint trick no longer works, nor does the batch file.
db
mspaint.log (233 downloads)
Description: Second mspaint log
Edited by tanstaafl. (20/05/2009 16:46)
Edit Reason: Additional Information
