e000 v1.04
Copying kernel...
Calling linux kernel...
Linux version 2.2.17-rmk5-np17-empeg52-hijack-v488 (hijack@rtr.ca) (gcc version 2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
Checking for extra DRAM:
c1000000: wrote ffffffff, read e28cc001
empeg-car player (hardware revision 9, serial number 30102438) 16MB DRAM
Command line: mem=16m
Memory: 15000k/16M available (992k code, 20k reserved, 368k data, 4k init)
Linux NET4.0 for Linux 2.2
IP Protocols: ICMP, UDP, TCP
Starting kswapd v 1.5
Signature is 20706d65 'emp '
Found custom animation at offset 0x9bb84
Tuner: loopback=1, ID=-1
show_message("Hijack v488 by Mark Lord")
empeg display initialised.
empeg dsp audio initialised
empeg dsp mixer initialised
empeg dsp initialised
empeg state support initialised 0089/88c1 (save to d0005080).
empeg RDS driver initialised
empeg power-pic driver initialised
empeg single channel IDE
Probing primary interface...
ide_data_test: wrote 0x0000 read 0x0000
ide_data_test: wrote 0xffff read 0x0000
ide_data_test: wrote 0xaaaa read 0x0000
ide_data_test: wrote 0x5555 read 0x0000
ide_data_test: wrote 0x0000 read 0xffff
ide_data_test: wrote 0xffff read 0xffff
ide_data_test: wrote 0xaaaa read 0xffaa
ide_data_test: wrote 0x5555 read 0xff55
hda: TS32GSSD25-M, ATA DISK drive
hda: TS32GSSD25-M, 30560MB w/0kB Cache, CHS=62090/16/63
smc chip id/revision 0x3349
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:09:86
Partition check:
empeg-pump v0.03 (19980601)
Trying to unmount old root ... Freeing unused kernel memory: 4k init+ /bin/mount -n /proc
+ log 'Builder image'
+ echo 'Builder image'
Buildeshow_message("Builder image")
r image
+ echo 'POPUP 9999 Builder image'
+ DRIVE1=
+ '[' -e /proc/ide/hdb -a -e /proc/ide/hdc ']'
+ '[' -e /proc/ide/hdb ']'
+ '[' -e /proc/ide/hdc ']'
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0
+ '[' -d /drive0/fids ']'
+ /bin/umount /drive0
+ /bin/mkswap /dev/hda6
Setting up swapspace version 0, size = 16994304 bytes
+ /bin/swapon /dev/hda6
Adding Swap: 16596k swap-space (priority -1)
+ /bin/mkswap /dev/hda3
Setting up swapspace version 0, size = 17027072 bytes
+ /bin/swapon /dev/hda3
Adding Swap: 16628k swap-space (priority -2)
+ log 'Tuning hda5'
+ echo 'Tuning hda5'
Tuning show_message("Tuning hda5")
hda5
+ echo 'POPUP 9999 Tuning hda5'
+ /bin/tune2fs -c -1 -i0 /dev/hda5
tune2fs 1.17, 26-Oct-1999 for EXT2 FS 0.5b, 95/08/09
Setting maximal mount count to -1
Setting interval between check 0 seconds
+ makedrive hda4 /drive0
+ dev=/dev/hda4
+ log 'Making hda4 filesystem'
+ echo 'Makishow_message("Making hda4 filesystem")
ng hda4 filesystem'
+ echo 'POPUP 9999 Making hda4 filesystem'
+ /bin/mkfs.ext2 -v -s 1 -i 131072 -m 0 /dev/hda4
mke2fs 1.14, 9-Jan-1999 for EXT2 FS 0.5b, 95/08/09
ext2fs_check_if_mount: No such file or directory while determining whether /dev/hda4 is mounted.
Linux ext2 filesystem format
Filesystem label=
243840 inodes, 31210200 blocks
0 blocks (0.00%) reserved for the super user
First data block=1
Block size=1024 (log=0)
Fragment size=1024 (log=0)
3810 block groups
8192 blocks per group, 8192 fragments per group
64 inodes per group
Superblock backups stored on blocks:
8193, 24577, 40961, 57345, 73729, 204801, 221185, 401409, 663553,
1024001, 1990657, 2809857, 5120001, 5971969, 17915905, 19668993,
25600001,
Writing inode tables: 258/3810Dead temp.sensor, status=0x00
done
Writing superblocks and filesystem accounting information: done
+ log 'Tuning hda4'
+ echo 'Tuning hda4'
Tuning hda4
+ echo 'POPUP 9999 Tuning hda4'
show_message("Tuning hda4")
+ /bin/tune2fs -c -1 -i0 /dev/hda4
+ /bin/sync
+ /bin/sync
+ log 'Mounting hda4'
+ echo 'Mounting hda4'show_message("Mounting hda4")
Mounting hda4
+ echo 'POPUP 9999 Mounting hda4'
+ /bin/mount -n -o rw,nocheck /dev/hda4 /drive0
+ /bin/sync
+ /bin/sync
+ log 'Making directories'
+ echo 'Making dishow_message("Making directories")
rectories'
Making directories
+ echo 'POPUP 9999 Making directories'
+ /bin/mkdir /drive0/fids
+ /bin/mkdir /drive0/var
+ echo '[hijack]'
+ log 'Remounting ro'
+ echo 'Remountingshow_message("Remounting ro")
ro'
Remounting ro
+ echo 'POPUP 9999 Remounting ro'
+ /bin/mount -n -o remount,ro /dev/hda4 /drive0
+ /bin/sync
+ /bin/sync
+ log 'hda4 completed'
+ echo 'hda4 completeshow_message("hda4 completed")
d'
hda4 completed
+ echo 'POPUP 9999 hda4 completed'
+ /bin/swapoff /dev/hda3
+ log 'Zeroing hda3'
+ echo 'Zeroing hda3'
Zeroing show_message("Zeroing hda3")
hda3
+ echo 'POPUP 9999 Zeroing hda3'
+ /bin/cat /dev/zero
/bin/cat: write error: No space left on device
+ /bin/swapoff /dev/hda6
+ log 'Done! Testing disk..'
+ echo 'Done! Testing disk..'
+ echo 'POPUP 9999 Done! Testing disk..'
show_message("Done! Testing disk..")
+ /sbin/hdstress
hdstress.cpp 189 ( 33): Poll result=0 on fd=5
Stressing /dev/hda: Spinning down.
Stressing /dev/hda: Spinning up.
Speed checking /dev/hda3
Read/write of 8Mb took 9.65 seconds
Drive length is 62586880 blocks, seek testing
Seek test complete: 2.01 seconds.
hdstress.cpp 189 ( 33): Poll result=1 on fd=5
hdstress.cpp 194 ( 33): Read a button press
Read/write of 8Mb took 3.92 seconds
Seek test complete: 2.02 seconds.
Read/write of 8Mb took 6.78 seconds
Read/write of 8Mb took 3.98 seconds
