I'm having difficulties with reformatting a hard drive. My wife decided she didn't want her MKII anymore so I snagged her hard drive. I followed the procedures for adding a 2nd drive, and I want to blow away the contents of the drive. Here's where I'm stuck. I have the standard 10gig drive that came with the unit. I used builder_bigdisk_v3.upgrade because car2-builder.upgrade gives me the dreaded "pump error". When builder completes, I launch hyperterminal to monitor status but the kernel doesn't start the reformat procedure. Says "drives already built" and gives me a bash prompt. I'm a linux newb so I didn't want to snoop around the drive looking for the reformat executable(if there is one??)
So not sure what the best way to proceed.
hda: IBM-DJSA-210, ATA DISK drive
If there is anyone
ide_data_test: wrote 0x0000 read 0x0000 let them speak now,
ide_data_test: wrote 0xffff read 0xffff
or forever hold the
ide_data_test: wrote 0xaaaa read 0xaaaaguins of Linux!
ide_data_test: wrote 0x5555 read 0x5555
e000 v1.04
Copyin
hda: IBM-DJSA-210, ATA DISK driveng linux kernel...
ide0 at 0x000-0x007,0x038 on irq 6.............................. don
hda: IBM-DJSA-210, 9590MB w/384kB Cache, CHS=19485/16/63
l.
NetWinder F
empeg-pump v0.03 (19980601)
Freeing unused kernel memory: 4k init+ /bin/mount -n /proc
+ log 'Builder image'
+ echo 'Builder image'
Buildeshow_message("Builder image")
r image
+ echo 'POPUP 9999 Builder image'
+ DRIVE1=
+ '[' -e /proc/ide/hdb -a -e /proc/ide/hdc ']'
+ '[' -e /proc/ide/hdb ']'
+ '[' -e /proc/ide/hdc ']'
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0
+ '[' -d /drive0/fids ']'
+ log 'Drives already built'
+ echo 'Drives show_message("Drives already built")
already built'
+ echo 'POPUP 9999 Drives already built'
+ exec /bin/bash --login
bash-2.01#
empeg-flash driver initialized8 (order 2, 16k)
smc chip id/revision 0x3349
Buffer cache hash tabl
Page cache hash table entr
SMC9194: SMC91C94(r:9) at 0x4008000 IRQ:7 INTF:TP MEM:6144b MAC 00:02:d7:26:0b:0onformance testing by UNIFIX
Linux NET4.0 for
5i
Partition check:
hda: hda1 < hda5 hda6 > hda2 hda3 hda4Society NET3.039
RAMDISK: ext2 filesystem found at block 0ux TCP/IP 1.0 for NET4.0
TCP: Hash tables configured (ehash 16384 bhas
IrDA (tm) P
empeg-pump v0.03 (19980601)Brattli)
Press Ctrl-A to enter pump...VFS: Mounted root (ext2 filesystem) readonly.100 serial driver version 4.27 with no serial options ena
Tried to mount /dev/hda4 as reiserfs but got error 19 0x98f74
Tune
show_message("Hija
empeg display init
Error mounting partitions (possibly already mounted)iti
empeg dsp mixer
Remounting first music partition read-onlyeg dsp initialised
em
Remounting second music partition read-only0
No secondary hard diskrol/panel button initi
Press 'q' now to go into development mode. You Have Zero Secon initialised, PDIUSBD12 id
q
Restored terminal settings
RAM disk d
Remounting first music partition read-onlyize
Probing primary inte
ide_data
Player exited normally: 0x0080
Switching to shell-player loopst: wrote 0xffff
Starting bash.
empeg:/empeg/bin# rebootrote 0xaaaa read 0x0080
WARNING: could not determine runlevel - doing soft reboote 0x5555 read 0x0080
(it's better to use shutdown instead of reboot from the command line)
ide_data_test: wrote 0xffff read 0x0080
shutdown: warning: cannot open /var/r 0xaaaa
-k: don't really shutdown, only warn.
-r: reboot after shutdown.0
ide_data
-h: halt after shutdown.
ide_data_test: w
-f: do a 'fast' reboot (skip fsck).data_test: wrote 0x5555 read 0x5555
-F: Force fsck on reboot.e
ide_data_test
-n: do not go through "init" but go down real fast.test: wrote 0xffff read 0xffff
hda: IBM-DJSA-210,
-a: use /etc/shutdown.allow_data_test: wrote 0x0000 read 0x0000
-k: don't really shutdown, only warn.ffff
ide_data_test: w
-h: halt after shutdown.IBM-DJSA-210, ATA DISK drive
-c: cancel a running shutdown.6
hda: IBM-DJSA-210
-t secs: delay between warning and kill signal.
** the "time" argument is mandatory! (try "now") **
empeg:/empeg/bin# shutdown-r
SMC
bash: shutdown-r: command not found:7 INTF:TP MEM:6144b MAC 00:02:d7:2
WARNING: could not determine runlevel - doing soft rebk:
e000 v1.04
Tryi
Copying kernel...root ... okay
Calling linux kernel...
Freeing unused
+ echo 'Builder
l.
Command line: mem=16ms already built")
ves already built'
Dr
Memory: 15024k/16M available (964k code, 20k reserved, 372k data, 4k init)ilt'
Dentry hash table entries: 2048 (order 2, 16k).01#
empeg-car bootstrap v1.02 20001
Buffer cache hash table entri
NET4: Linux TCP/IP 1.0 for NET4.0g linux kernel...
IP Protocols: ICMP, UDP, TCP............................
IrDA (tm) Protocols for Linux-2.2 (Dag Brattli)-hijack-v488 (hijack@rtr.ca) (gcc version
2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 200
ircomm_tty: virtual tty driver for IrCOMM ( revision:Wed May 26 00:49:11 1999 )ongARM-1100 revision 11
Checking for
Starting kswapd v 1.5
Signature is 67706d65 'empg'IPS
Scheduling custom logo. 15000k/16M available (
empeg display initialised.8k data, 4k init)
empeg dsp audio initialised
empeg dsp mixer initialised entries: 2048 (order 2, 16
empeg dsp initialised
empeg audio-in initialised, CS4231A revision a0der 4, 64k)
empeg remote control/panel button initialised.: 4096 (order 2, 16k)
empeg usb initialised, PDIUSBD12 id 1012ce testing by UNIFIX
RAM disk driver initialized: 16 RAM disks of 4096K sizeash 16384)
empeg single channel IDEls for Linux-2.2 (Dag Br
Probing primary interface...
Sta
SA1100 serial driver versio
hda: IBM-DJSA-210, ATA DISK driveled
ttyS00 at 0xf8010000 (irq = 15)
tt
hda: IBM-DJSA-210, ATA DISK drive SA1100 UART
hda: IBM-DJSA-210, ATA DISK drive at 0xf8030000 (irq = 16) is a SA
Signature i
Mounting proc
No secondary hard disk_data_test: wrote 0x00
Press 'q' now to go into development mode. You Have Zero Seconds To ComðStarting read 0x0080
player080
player.cpp : 385:empeg-car 2.00 2003/04/01.ote 0x5555 read 0x0080
Prolux 4 empeg car - 2.1434 Mar 26 2003ad 0x0080
Vcb: 0x4086d000ta_test: wrote
ide_data_test: wrote 0xaaaa read 0x0080
e000 v1.04
Copying kernel...
ide_data_test:
Calling linux ker
empeg-flash
Checking for extra DRAM:c:v0.12 03/06/96 by Erik
c1000000: wrote ffffffff, read e28cc001
NetWinder Floating Point Emulator V0.94.1 (c) 1998 C
empeg-car player (hardware revision 9, serial number 30102821) 16MB DRAMhda6 > hda2 hda3 hda4
hdb: hdb1
Command line: mem=16m3 hdb4
Page cache hash table entries: 4096 (order 2, 16k) pump...VFS: Mounted root (ext2 filesystem) readon
Linux NET4.0 for Linux 2.2t has d_count=1
Based upon Swansea University Computer Society NET3.039okay
Freeing unused
NET4: Linux TCP/IP 1.0 for NET4.0lantic/South_Georgia
hijack: removed menu entry: "Hard D
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTd000
Dead temp.sensor, status=0x0
ttyS02 at 0xf8030000 (irq = 16) is a SA1100 UARTap v1.02 20001106 (hugo@empeg.com)
If there is anyone
Found custom animation at offset 0x98f74et them speak now,
Tuner: loopback=0, ID=-1
show_message("Hijack v488 by Mark Lord")seems not. Let fly the Penguins of Linux
empeg dsp audio initialised v1.04
Copying ke
empeg dsp mixer initialisedling
empeg dsp initiali
empeg state support initialised 0089/88c1 (save to d0005280).3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008
empeg RDS driver initialised
Proces
Checking for e
RAM disk driver initialized: 16 RAM disks of 4096K sizeff, read e28cc001
empeg single channel IDE Emulator V0.94.1 (c) 19
ide_data_test: wrote 0x0000 read 0x0080peg-car player (hardware revision 9, se
ide_data_test: wrote 0xaaaa read 0x0080em=16m
ide_data_test: wrote 0x5555 read 0x0080s: 16384 (order 4, 64k)
ide_data_test: wrote 0x0000 read 0x0000ge cache hash table entries: 4096 (orde
POSIX conformance t
ide_data_test: wrote 0x5555 read 0x5555nsea University Computer Society NET3.0
NET4: Lin
ide_data_test: wrote 0xffff read 0xffff Hash tables configured (ehash 16384 bh
ttyS01 at 0xf80500
hda: IBM-DJSA-210, ATA DISK drive a SA1100 UART
ide_data_test: wrote 0x0000 read 0x0000is 67706d65 'empg'
ide_data_test: wrote 0xffff read 0xffff 0x98f74
empeg display init
ide_data_test: wrote 0x0000 read 0x0000nitialised
e
hda: IBM-DJSA-210, ATA DISK driveDE
Probin
ide_data_test: wro
empeg-flash driver initializeddata_test: wrote 0xaaaa read 0
ide_data_t
Partition check:
hda: hda1 < hda5 hda6 > hda2 hda3 hda4590MB w/384kB Cache, CHS=19
r image
+ DRIVE1=
+ /bin/mount -n -t ext2 -o ro,nocheck /dev/hda4 /drive0144b MAC 00:02:d7:26:0b:0k@rtr.ca) (gcc version
5
Partition
+ echo 'Drives already show_message("Drives already built")a1 < hda5 hda6 > hda2 hda3 hda42008
built'
Drives already builtdb5 hdb6 > hdb2 hdb3
+ exec /bin/bash --login1)=16m
bash-2.01#
C
Pres
þC
empeg-car bootstrap v1.02 20001106 (hugo@empeg.com)stem) readonly.
If there is anyone present who wants to upgrade the flash, let them speak now, 20k reserved, 368k data, 4
Trying to unmount old root ... okay: 2048 (order 2, 16k)
e000 v1.04
Copying kernel...
2.95.3 20010315 (release)) #2 Fri Feb 15 10:29:26 EST 2008 tables configured (ehash 16384
Vcb: 0x4086d000
Dead
Timezone: Atlantic/South_Ge
SA1100 serial
player.cpp
Prolux 4 empeg car - 2.1434 Mar 26 2003 is a
Command line: me
NET4: Linux TCP/IP 1.0 for NET4.0pp : 385:empeg-car 2.00 20
IP Protocols: ICMP, UDP, TCP12 id 1012
ttyS00 at 0xf8010000 (irq = 15) is a SA1100 UART1.19, 13-Jul-2000 for EXT2 FS 0.5b, 95/08/0
ttyS01 at 0xf8050000 (irq = 17) is a SA1100 UARTc4 is mounted.te 0x5555 read 0
ide_data_test: wr
Signature is 67706d65 'empg'k: intercepting config.ini
Found custom animation at offset 0x98f74 player.cpp : 385:empeg-car 2.00
show_message("Hijack v488 by Mark Lord")a rea
Pro
empeg display initialised.r 26 2003
empeg dsp audio initialisedata_test: wrote 0x5555 rea
Vcb: 0x4086d000
empeg dsp initiali
empeg state support initialised 0089/88c1 (save to d0005300).
hda
empeg RDS driver initialisede
empeg power-pic driver initialised (first boot)10:29:26 EST 2008read 0x0000
RAM disk driver initialized: 16 RAM disks of 4096K sizet
ide_data_
Probing primary interface...for extra DRAM:
ide_data_test: wrote 0x0000 read 0x0080ad e28cc00155 read 0x5555
ide_data_test: wrote 0xffff read 0x0080NetWinder Floating Point Emulator V0.94
ide_data_test: wrote 0xaaaa read 0x0080order 4, 64k)aa read 0xaaaa
h
ide_data_test: wrote 0xaaaa read 0xaaaata_test: wrote 0x00
hda: IBM-DJSA-210, ATA DISK drive9
ide_data_test: wrote 0x0000 read 0x0000rote 0xaaaa rea
ide_data_test: wrote 0xffff read 0xffff0
smc
hda: IBM-DJSA-210, ATA DISK drive hda1 < hda5 hda6 >
ide_data_test: wrote 0x0000 read 0x0000set 0x98f74
Tuner: loop
ide_data_test: wrote 0xaaaa read 0xaaaaow_message("Hijack v488 by Mark Lord")k
RAM d
hda: IBM-DJSA-210, ATA DISK drivesks of 4096K sizeDRIVE1=
ide_data_test: wrote 0xaaaa read 0xaaaa interface...]'
ide_data_test: wrote 0x5555 read 0x55550x0080
hda: IBM-DJSA-210, ATA DISK driveaaaa read 0x0080
ide0 at 0x000-0x007,0x038 on irq 6st: wrote 0x5555 read 0x0080
bash:
bash-2.01#
r image
+ DRIVE1=
+ echo 'Drishow_message("Drives already built")
ves already built'
bash-2.01#
I've got 2 options, I could use emplode to remove everything (easy but not the cleanest) or I can bug you guys to help me through this difficult transition ;)' --which I am --
In all seriousness & gratitude -- thank you in advance for your help, any suggestions would be greatly appreciated!!!!!
Best Regards,
Mark.c
