That signal in the most recent dump seems pretty noisy.
Possibly that's due to only grounding to the empeg chassis. Is it still in this case?.
I was still using the chassis for that capture, but just now I did it again, with the ground lead clipped to the chassis screw that is less than 1cm from the trace I was probing. Same result.
Maybe the empeg is noisy. I would think it is though. Very hard to tell unless you have another CRO nearby to compare with.
Edited by Shonky (28/03/2008 04:05)
Edit Reason: Corrected typo
