So, i guess my time to replace the drive has come too
(I get i/o errors and irq timeouts on the screen.)
Any limit on the drivesize on a mk1? (Will the big disk builder have enough memory?)
./smartctl -a /dev/hda
smartctl version 5.33 [arm-empeg-linux-gnu] Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model: FUJITSU MHT2040AT
Serial Number: NN58T4215RUE
Firmware Version: 0022
User Capacity: 40,007,761,920 bytes
Device is: In smartctl database [for details use: -P show]
ATA Version is: 6
ATA Standard is: ATA/ATAPI-6 T13 1410D revision 3a
Local Time is: Tue Jan 13 03:29:44 1970 /usr/local/armtools
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 293) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
No General Purpose Logging support.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 40) minutes.
Conveyance self-test routine
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x100f 100 100 046 Pre-fail Always - 113545
2 Throughput_Performance 0x0005 100 100 030 Pre-fail Offline - 14680064
3 Spin_Up_Time 0x0003 100 100 025 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 099 099 000 Old_age Always - 4707
5 Reallocated_Sector_Ct 0x0033 100 100 024 Pre-fail Always - 8564165181446
7 Seek_Error_Rate 0x070f 100 100 047 Pre-fail Always - 1406
8 Seek_Time_Performance 0x0005 100 100 019 Pre-fail Offline - 0
9 Power_On_Seconds 0x0032 099 099 000 Old_age Always - 755h+50m+56s
10 Spin_Retry_Count 0x0013 100 100 020 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 2042
192 Power-Off_Retract_Count 0x0032 094 094 000 Old_age Always - 1672
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 6032
194 Temperature_Celsius 0x0022 100 095 000 Old_age Always - 34 (Lifetime Min/Max 61/65535)
195 Hardware_ECC_Recovered 0x001a 100 100 000 Old_age Always - 11692
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 286785542
197 Current_Pending_Sector 0x0012 099 099 000 Old_age Always - 2
198 Offline_Uncorrectable 0x0010 099 099 000 Old_age Offline - 3
199 UDMA_CRC_Error_Count 0x003e 200 196 000 Old_age Always - 117
200 Multi_Zone_Error_Rate 0x000f 100 100 060 Pre-fail Always - 11122
203 Run_Out_Cancel 0x0002 100 100 000 Old_age Always - 433776361662
SMART Error Log Version: 1
Warning: ATA error count 0 inconsistent with error log pointer 3
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 37892 hours (1578 days + 20 hours)
When the command that caused the error occurred, the device was in an unknown state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
02 11 e0 59 00 00 03 Error:
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
00 02 e0 c4 fa 6e 00 73 00:00:16.384 NOP [Reserved subcommand]
00 02 e0 c4 ca 5b 00 73 00:00:00.000 NOP [Reserved subcommand]
00 02 e0 c4 af 5b 00 73 00:00:00.000 NOP [Reserved subcommand]
00 02 e0 c4 93 5b 00 73 00:00:00.000 NOP [Reserved subcommand]
00 02 e0 c4 75 5b 00 73 00:00:00.000 NOP [Reserved subcommand]
Error -1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in standby mode.
a0 00 73 02 e0 59 00
5b a0 73 02 e0 c4 ca 04 17d+19:46:04.928 [RESERVED]
5b 9c 73 02 e0 c4 af 04 17d+19:16:35.456 [RESERVED]
5b 98 73 02 e0 c4 93 04 17d+18:46:00.448 [RESERVED]
5b 94 73 02 e0 c4 75 04 17d+18:13:14.368 [RESERVED]
5b 90 73 02 e0 c4 58 04 17d+17:41:33.824 [RESERVED]
Error -2 occurred at disk power-on lifetime: 755 hours (31 days + 11 hours)
When the command that caused the error occurred, the device was active or idle.
40 59 02 a2 73 02 e0 Error: UNC at LBA = 0x000273a2 = 160674
c4 00 02 a2 73 02 e0 00 38d+05:30:39.624 READ MULTIPLE
c4 00 04 a0 73 02 e0 00 38d+05:30:34.598 READ MULTIPLE
c4 00 04 9c 73 02 e0 00 38d+05:30:34.570 READ MULTIPLE
c4 00 04 98 73 02 e0 00 38d+05:30:34.543 READ MULTIPLE
c4 00 04 94 73 02 e0 00 38d+05:30:34.515 READ MULTIPLE
Error -3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
00 00 03 11 00 00 00
a0 4e 00 00 00 40 04 e6 31d+01:43:37.331 PACKET
a0 4e 00 00 00 00 04 ca 31d+01:43:37.331 PACKET
9c 4e 00 00 00 00 04 af 30d+07:05:08.467 [RESERVED]
98 4e 00 00 00 00 04 93 29d+12:26:39.603 CHECK POWER MODE [RET-4]
94 4e 00 00 00 00 04 74 28d+17:48:10.739 STANDBY IMMEDIATE [RET-4]
Error -4 occurred at disk power-on lifetime: 627 hours (26 days + 3 hours)
59 00 00 00 03 11 00 at LBA = 0x00110300 = 1114880
40 c4 04 9a 00 00 00 e0 12d+10:16:23.298 READ VERIFY SECTOR(S)
00 c4 87 85 00 00 00 e0 00:00:41.474 NOP [Reserved subcommand]
00 c4 69 85 00 00 00 e0 00:00:40.964 NOP [Reserved subcommand]
00 c4 4c 85 00 00 00 e0 00:00:39.940 NOP [Reserved subcommand]
00 c4 30 85 00 00 00 e0 00:00:38.916 NOP [Reserved subcommand]
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
