#295600 - 21/03/2007 02:09
Re: Laser Cutting/Engraving
[Re: hybrid8]
Quote: You can probably also start looking for water jet cutting which is good at least for profiles. I'm fairly certain you can't use a water jet to cut relief. For that you'll need a mill.
Or chemical milling. It's the exact same process as making a PCB, and there are kits everywhere to do that. The only additional step, if desired, is to black oxide the brass before stripping the photo resist.
